Results 1 to 13 of 13
    Senior Member Three Rings dirtyb5a4's Avatar
    Jan 02 2010
    99.5 1.8t 5spd quattro(rolled) 97 1.8t 5spd quattro
    lowcountry, sc
    2.8 trans in a 1.8t
    ive heard they bolt right up and the 2.8 transmission will allow over 140mph. if im going to spend the money for BT then i want a respectable top end and not the pathetic almost 130mph that the 1.8t trans gives. are there any other options?
    RIP 99.5 1.8t quattro, test pipe, full 2.5 exhaust, 17" rs4 reps, forge splitter DV, drilled and slotted rotors, redstuff pads, and finally running GIAC
    NOW- 97 b5 a4 1.8t quattro, 17" rs reps, and forge splitter, test pipe and 2.5in straightpipe with no muffler and now with clear corners, clear smoked side marker lights, and facelift tail lights.
    the gf- your breaking up with me over a car??
    me- yes i like it more
    Co-owner and automotive tech at Flying Wrenches Automotive
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    They do bolt right up. I never heard of the top end being greater. The 2.8 has taller gears which gets you better fuel economy in 5th.
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    The 1.8t tranny will take you to 150+mph, if you have the power....
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Aug 13 2008
    Indiana
    I'll trade my 2.8 trans for a 1.8t. Hell I'll let you have most of the bad one in my car too
    -Nic
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Where did you hear that the 1.8t tranny will only go to 130mph? I know it will go farther than that if you have the power.
    Senior Member Two Rings capea4's Avatar
    Jul 11 2007
    Cape Cod
    Last I remember hearing, it was 160 n change at 7000 rpm range for the 1.8T tranny, do a search.
    1998.5 A4
    My B5 A4
    2002 S8
    My S8
    Mar 24 2009
    98.5 A4 1.8TQ Tip
    Carlisle, PA
    I did a little searching as this has been discussed nearly every month, almost religiously. Here's a little info you may like.
    http://www.audizine.com/forum/showth...=1#post1899666
    Edit: Here's a DIY I found on Audiworld for clutch replacement with some good info though it's from 2004. http://forums.audiworld.com/showthread.php?p=1869055
    Here's Bitetsai's DIY in case you missed it. Very good read. http://www.audizine.com/forum/showth...ual-Conversion
    This is another short thread with a little info in it. http://www.audizine.com/forum/showth...pd.-trans-swap
    "gutting the cat makes the turbo loudddd.. everyone in my work complex thinks i'm bt. little do they know a minivan could dominate me." - CrtchRktRcr
    Mar 24 2009
    98.5 A4 1.8TQ Tip
    Carlisle, PA
    Quote Originally Posted by capea4
    Almost exactly 160 actually.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    The stock ecu is limited at ~127, that's probably why he's confused.
    because racecar.
    Mar 24 2009
    98.5 A4 1.8TQ Tip
    Carlisle, PA
    Quote Originally Posted by Kyle H View Post
    He has a full 2.5" exhaust, test pipe, and forge splitter so it should be safe to assume he's chipped. If I remember there wasn't an actual top speed limit but rather 127 was as fast as you could go with the stock rev limit. Which chips raise.
    Jan 02 2010
    lowcountry, sc
    Quote Originally Posted by Altech75 View Post
    im actually not chipped as im going straight to BT. but i feel alot better now that i know i wont have such a horrible top end after investing so much money.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    No, the stock tires are only rated to ~130 so they electronically limit the top speed. You hit 130mph at around 5700rpm in 5th...
    because racecar.
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    LOL with only the mods in my sig I got the car to 150... Not sure on the stock speed limiter though as my car has never been stock.. :P
    Last edited by 2001A4QUATTRO; 03-07-2010 at 07:21 PM. Reason: The sideskirts added more hp.. LOL
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
