Results 1 to 8 of 8
    Deactivated Three Rings
    Oct 07 2008
    Santo Domingo, Dom. Rep.
    Iridum vs. copper plugs/ pros & cons?
    Just like the title states.
    Jul 14 2009
    Pasadena
    i believe iridum lasts way longer
    IG: @matthewee
    Established Member Two Rings josh160's Avatar
    Feb 18 2009
    A4 1.8TQ
    That is true
    Aug 17 2009
    Pittsburgh
    FWIW i ran champion copper plugs in a colder range on several different 400+ whp builds. They are way cheaper to replace after track days. If you want longevity and aren't going to make big power, get iridiums. and change them every 25000 or so. if you're going to make big power and need to do required mx more often, get something cheap. I also ran conventional dino oil a filter can with replaceable element filters in each of those cars. It is way better for bottom end builds and turbos, and way cheaper to replace twice a month during track season. All in all, its up to you. Iridium or copper is just fine, and neither will yield any better result than the other on the same engine. I wouldn't go with platinum is the only thing. Turbos seem to kill platinum plugs more often.
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    Copper plugs give a better spark, but you must replace them every 5,000. They are very cheap though. like < $2.00
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    I like copper plugs. Cheap, and I just make them part of my basic maintenance.
    I've had the best luck with copper, it seems.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    -Doug
    Veteran Member Four Rings Undisputed's Avatar
    Jun 28 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Good read and I go with the copper also.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
