Results 1 to 4 of 4
    Mar 05 2010
    glrndale ca
    Central locking pump
    hello, just new here in audizine, just want to ask some question about the CLP and i also read some thread about the central locking pump here in the forums and now i tried to open the pump and found out that the graphite motor is still good but i noticed like little dust inside, black dust, and it looks like its burned ash and it smells like it too! is that what vagcom is referring to central control pump run time exceed? does it mean i shud replace it with a new CLP? thats all hope you can help me understand it. thank you so much!
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    Generally it means the pump is running longer than it should because there is a leak in the system so the locks aren't opening or closing properly. ie. longer than it should take. There will be dust inside of the box because that's the nature of the graphite, however, you have to check whether the inside section of the graphite is still intact. There are 3 pieces to the motor vane. Outside, inside, and the area that holds the vanes. The three pieces could be intact but the vanes themselves could be broken in which case the pump won't work.
    There are 2 situations for you.
    1. There is a break in the tubing to your locks somewhere on the car. The tubing is corrugated plastic and can break.
    2. The vanes in the pump are broken. This is the most likely culprit. The only fix to this is to buy another pump from online or a junk yard. The only way to know is to take the pump apart and look inside to see if the vanes are in tact. It's easy....just a few screws to take off. If you lock or unlock your doors and the pump whines for more than 5 sec., it's most likely the vanes are broken and no air is being pushed out.
    14 A4 allroad - stock
    05 allroad 2.7T Stock
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    Quote Originally Posted by hoganalley View Post
    what does it mean if your locks still work when u lock and unlock the car? But your remote no longer can control the CLP?
    does that mean you have a leak somewhere?
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Mar 05 2010
    glrndale ca
    thanks hoganalley,m gna try to ckeck it out,coz I only opened it and the graphite is stil intact,and yes I didn't check the vanes,I hope its just the vanes coz I think if there's a leak it would gna be a pain in the a** to look for the lines ryt? sorry m rily new at audis and I rily like the car! sorry but another qstion,if its not the vanes and there's leak somewhere,where can I start to look for it or how m I gna start? and I don't hear any whinning on the locks!! again thank you so much for the reply!!!
