Results 1 to 12 of 12
    Veteran Member Three Rings eboosted's Avatar
    Jul 17 2009
    lima
    Looking for more power for my B8
    Euroboost Stage II software installed
    3" downpipe
    K&N drop in filter
    Next step:
    AWE FMIC
    Water/Alcohol injection
    Need to get a bigger turbo somehow, any ideas?
    Veteran Member Four Rings Nght&Day-B8's Avatar
    Aug 05 2009
    Miami, Fl
    Well regarding the bigger turbo, you can either build your own kit and have a company build a tune for you. Or just wait for a company to do the R&D for you and just buy the whole thing as a kit from them.
    As for the next step, id pick one or the other. Water/meth and front mount will both just be lowering IAT, your not getting different gains from either one. And if your planning on going bigger turbo so soon id skip the w/m and go straight to a FMIC.
    Jul 17 2009
    lima
    Tune won't be an issue, custom remap will be developed locally.
    The main issue is the exhaust manifold, I'm pretty sure the B7 manifold won't fit, not 100% possitive though, need some pics for boths manis. Still looking for the first B8 that will take the BT route, otherwise I'll be the first one.
    A new manifold should delete the air filter box because of lack of space on the engine bay which could be filled with a bigger turbo, a good downpipe design could be worked locally.
    Aug 05 2009
    Miami, Fl
    If thats the case go for it, let me know what injectors you go with.. and by the way what turbo are you planning on going with?
    Jul 17 2009
    lima
    Injectors size would depend on the turbocharger flow rate, I'm thinking about going with a GT3071 0.64 a/r or maybe a smaller GT2871r 0.64 a/r as well, nothing too crazy, 300awhp @ 18psi with a fast spool up and room for improvement would be killer for a B8, this setup should work perfect on 630cc. The MED17 is a real nice ECU to develop a big turbo software.
    If an upgraded IHI turbo with the same OEM flanges can be swapped in I may jump on it just to keep the manifold and oil/coolant lines and downpipe, but I still don't have the picture of one out or the ETKA picture for the matter
    Aug 05 2009
    Miami, Fl
    Are you Manual or Tiptronic? IMO i would do the gt28rs, im even considering it for my B8 being that b7 tiptronic guys ran gt28's with no issues. Also b6 and b5 tip guys ran gtrs's with no issues either so i say go for it, theres just certain thing you want to really take your time with and have done right like the tune.
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    Quote Originally Posted by Nght&Day-B8 View Post
    I don't know exactly how water/meth injection works, but I think I remember reading somewhere that it also helps w/ preventing carbon buildup. True?
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hόper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Feb 04 2010
    Ottawa, Canada
    Quote Originally Posted by ItsDubC View Post
    some people say it helps, other people says it don't. Its 50/50. But water/meth helps with cooling the engine thus more performance..
    2014 Ibis RS5 w/ Ti. Package AWE Track Edition, ECS 15/10, 034 Transmission Mount, 034 Solid Sway Bar, 034 End Links
    2021 Nardo Grey RS7 w/Black Optics/RS Design
    2023 Daytona Grey RS6 w/BlackOptics/RS Design w/CTS Res Delete, CETE Lowering Mod, 034 Sways
    2025 Daytona Grey RS6 Performance w/AWE SwitchPath, CETE Lowering Mod, 034 Sways, 034 Strut, 034 Trans, etc
    Aug 05 2009
    Miami, Fl
    Correct, its been said that the meth helps keep intenals clean. But im not sure how true that is, i havnt found someone who has opened their motor after running 50k miles of running with it, i do know there is no worries though. Plenty of Audi owners from previous years have run it on their cars for years without issue.
    A buddy of mine just bought a B5 s4 with swapped with twin k04's and the car is tuned for running the water/meth and its has ~125,000k miles on it and runs absolutly perfect. The heads never even come off of the motor, so its never been opened up yet but once it does i'll be able to tell you the long term effects of it. I'll admit though the car runs like its only got 25k miles
    Quote Originally Posted by Runge View Post
    Same performance as a FMIC..
    Feb 04 2010
    Ottawa, Canada
    I'm sure running FMIC and meth/water doesn't hurt either :)
    Dec 29 2009
    Midwest
    Ever think about a S4?
    Aug 05 2009
    Miami, Fl
    No it wouldnt, but i wont unless theres a need to for example a big turbo.. or like my buddy who has a turbo mkv r32 and has front mount and w/m with two ports since theres so much heat soak. And theres a oil cooler also in the works, but this thing gets hot. After a run at night if you pop the hood right after you'll see the turbo cherry red, heres just a little video of the car for you guys
    Here the car wasnt running perfect yet, they actually had 3 ports for the water/meth but removed one port. Car was running at 14psi in this video.
    http://www.youtube.com/watch?v=gXUjxheYITU
    Heres the car with the old exhaust revving.
    http://www.youtube.com/watch?v=o59Wq...eature=related
