Results 1 to 9 of 9
    Senior Member Two Rings ABL2point0T's Avatar
    Nov 09 2006
    Charlotte, NC
    Oil filler cap suction, oil on coil packs
    Today I went to change the plugs and upgrade to NGK's. When i pulled the coil packs, 1 coilpack and plug was completely clean, the other 3 were covered in oil. #4 (the closest one to the firewall) was the only dry one. I swapped them out, obviously when I reinstalled coilpacks, and cranked up the car there was smoke from whatever dripped into the cylinders. Everything started fine, no hesitation. I went to check the oil filler cap, when i opened it, it was being pulled down by some type of vacuum. Not difficult to take out, but i found it puzzling. When i went to remove the dipstick, the car shuttered, and increased idle rpm's. I did not find this normal. I got into the car after the smoke was done (about 2 min). drove it, everything was fine. Went to dinner, everything is fine, but the car doesnt seem to be at full power.
    I have apr chip and exhaust, and it used to really put me in the seat. I have searched and think it might be the PCV, but am not 100% sure. Sorry for the long winded post, any ideas or same symptoms? I am planning on taking the car on a 4 hour drive tomorrow and dont want anything to come up, should i drop it at the dealer and get a loaner for the trip?
    2006 A4 2.0T Titanium 6 Spd Manual (Sold)
    2008 335i 6 Speed Manual
    PS3 Username: Wolfpack1
    Veteran Member Four Rings rxer311's Avatar
    Dec 27 2009
    Nissan Rouge
    Mount Joy, Pa
    Sounds like PVC, but sorry can't say for sure.
    If I helped you...Rep me!
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    PCV is supposed to put vacuum on the crankcase and therefore the oil cap. This misconception runs rampant on this forum. The only real tell-tale way to know is to watch for oil around the cap, or to take the hose off and try to suck/blow through it. It's easy to take off.
    I fear oil on multiple coilpacks runs deeper than a busted pcv valve unfortunately. It's hard for oil to get there. Even if your pcv valve was busted and oil was running from the cap to the packs, only the first one and MAYBE the second one would have oil on them, and it'd be minimum.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Nov 09 2006
    Charlotte, NC
    No CEL's or anything, I really hope this is as simple as the PCV.
    Jun 12 2008
    St. Louis
    When my PCV went out, the dealer tech was able to unscrew the oil cap while my car was running. He explained to me a normally functioning PCV would not allow this to happen.
    I never tried doing this before so I had to trust his expert opinion. When he did this, my car started to stall/misfire. The repair cost me over $200.
    Hope this helps.
    Veteran Member Four Rings LimiTed's Avatar
    Oct 13 2006
    Bay Area
    when my pvc went out i had oil all around the oil cap area. no CEL
    Veteran Member Four Rings Tusin's Avatar
    Mar 16 2009
    Anchorage, AK
    It is the PCV or head gasket. If you have a warranty just drop it off and get the loaner. It is not worth the risk.
    Sorry to go SOMEWHAT OT here. But I have always been told and have read 100% the opposite of what mellonhdz's dealer tech told him. I am not an expert so I cannot say if or why that information is wrong.
    To reiterate what I have read multiple times. Is if you CAN easily remove the oil cap while the car is running the PCV is working fine. But if you are unable to, or if it feels like it is being sucked into the engine the PCV is faulty.
    If I am reading Zebman correctly is he stating that the same as what mellonhdz's tech told him, that the PCV should be creating the vacuum if working correctly. But if there is supposed to be a vacuum, what creates the vacuum when you run a catch-can, or VTA setup?
    FYI not saying that either of you are wrong. I am honestly asking the question. Because if 90% of the information regarding this is incorrect on the 'Zine we should try to get the correct info out there.
    Veteran Member Three Rings CoDRoX's Avatar
    Nov 03 2009
    NoVA
    Quote Originally Posted by mellonhdz View Post
    Quote Originally Posted by Tusin View Post
    So which one is it?
    2014 Q5 3.0T | Lava Gray Pearl/Black | Prestige | S-Line Plus | Adaptive Damping Suspension | Driver Assist | Sport Interior Package | EPL Stg I |
    Sold, but not forgotten:
    2013 allroad | Glacier White Metallic/Chestnut Brown | Prestige | Sports Package | 19" Wheels | Audi Drive Select | Adaptive Cruise Control |
    2006 A4 2.0T quattro | Black/Black | S-Line | 6MT | Bi-Xenon AFS | Navigation | Bose | BlueTooth | Tint | APR Stg I |
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    I vote for valve cover gasket.
