Results 1 to 28 of 28
    Veteran Member Four Rings csre9's Avatar
    Feb 03 2008
    Stage 100 b5s4 hooked on meth, other money pits
    At work
    How long did it take you to install your meth
    Once the front end was off? Trying to work out some labor with my buddy.
    TIA
    -Sebastian
    Veteran Member Three Rings DaveS4's Avatar
    Apr 12 2009
    Nova Scotia, Canada
    Shouldn't take long at all, I'm doing mine soon and am looking at like an hour once the front end is off plus wiring, which would rake another half hour or hour if you know what you're doing.
    2001.5 VAST Stage3 **** Silver * 6 Speed
    2001.5 Completely Stock * Imola * Automagical
    Veteran Member Three Rings M.S4's Avatar
    Mar 04 2008
    '11 S4
    MN
    The vast kit took my an hour to install everything. Now i have an HFS-3 waiting to go in but I doubt it will take me that much longer. 2 hours or so.
    EPL Stage 3 with a bunch of other crap.
    Nov 23 2004
    B5 S4 Built Motor GTX28's
    NH
    About an hour, front end stayed on.
    B5 S4 Built motor GT28X's
    08 3.2 A3 DSG DD
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Took me a half-day to install my HFS-6 system. Depends on how/where you're installing your tank & pump, and where you're installing your nozzles.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by csre9 View Post
    TIA
    -Sebastian
    Front end off?? For what?
    Anyway, took me about 2.5 hrs or so from start to finish, taking my time.
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Midwest
    A long time.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Veteran Member Three Rings as4driver's Avatar
    Mar 28 2005
    2001 Audi s4, audi a4 avant
    Vast Kit took about 2 hours. The HSF3 is going to take me way longer.
    GL
    Evan
    CURRENT:
    2007 Audi S4 Sprint 6-Speed
    2004 Porsche 996 Turbo
    1999 Mazda Miata (Track)
    1991 Mazda Miata
    PAST:
    2000 Audi S4 Imola 524 WHP 527 WTQ
    1999 Audi A4 Avant
    2001 Audi S4 EPL Stage 3+
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    If you have any questions on the Aquamist kit, feel free to drop me a PM.
    Aug 27 2009
    spare audi parts, broken audi parts, and shit loads of audi crap
    new york
    why take off the front end? mine took forever and a day but i took my time so it is not .01% visible.
    Jan 29 2009
    Quote Originally Posted by pit viper View Post
    Now that is sexy! I just might have to do that once I go stage 3(+)... what size nozzles are you running in each runner of your IM?
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    0.3 mm
    Jan 29 2009
    ^^ thanks!
    I like that setup a lot!
    Mar 28 2005
    OH DAMN!!! Sweet setup Do u have a decent write up for the install.
    Thanks
    Evan
    CURRENT:
    1991 Mazda Miata
    PAST:
    1999 Audi A4 Avant
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by s vier View Post
    A long time.
    you sir win the epic mod of the day award.
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    front end off? why would you need to take your front end off?
    The Best Things in Life Are Free... Or Heavily Discounted!
    Dec 06 2007
    Calgary, AB, Canada
    It's more fun that way
    Dec 10 2006
    Midwest
    Quote Originally Posted by blmlozz View Post
    Thanks! I was pretty proud of how it worked. EVERY-PART of the visor/mirror/Homelink works. Here's another:
    Wings
    Carbs
    Titaniums
    Feb 03 2008
    At work
    Thanks guys. To answer the question why are you taking the front end of?, Were pulling the motor so it will all be apart and the quote he wrote me up for didn't include installing the meth.
    Gracias amigos
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    wow for the aquamist. do you get six nozzles in that setup or was that optional or custom mod you did for that one? talk about efficiency.. what psi at 1/4 inch flow does the pump put out??
    RS6 hybrids and corn
    Senior Member Two Rings S4jet's Avatar
    Aug 08 2009
    owde
    Neither here nor there
    I don't like taking my hands off the steering wheel without meth, I don't think I would ever use it like that lol.
    #VhatIsProblem?
    [sbsc]
    GCCRSTFTMFW!
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Quote Originally Posted by bigern45 View Post
    I ordered the extra nozzles & fittings to run it direct-port. I did the same when I had the hfs-5 on my SRT-4. It uses a 150 psi pump, and sprays based on injector duty cycle..
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    snow performance is what op has fyi
    Dec 10 2006
    Midwest
    Quote Originally Posted by S4jet View Post
    You clearly don't have a meth injection kit.....You set it once and don't touch it. You do want to see that it is working though. I also assume you have a Tiptronic then?
    Wings
    Carbs
    Titaniums
    Mar 04 2008
    '11 S4
    MN
    +1
    Stage 3 with meth is awesome.
    Veteran Member Four Rings gmx's Avatar
    Mar 01 2008
    '12 1M
    Sydney, AU
    Quote Originally Posted by newbies4 View Post
    pics?
    Be interesting to see the different setups/installs for B5s in general.
    00 A4 1.8TQ MT (AJL)
    12 1M
    18*8 RPF1 | Vogtland GT 575F/675R | H-Sport Sways | 320mm B8 Brakes, 300mm S4 rear |
    GT2871R Elim | QMS tuned AJL 627cc EV14 @ 4.3bar | 034 3" DP (8psi backpressure!) | Milltek | JHM SSK
    3090lbs
    Dec 10 2006
    Midwest
    I get a lot of PMs about my Homelink/Vast Meth controller mod. So here is the step by step I have been sending people:
    Go for it. It was pretty time consuming but the results speak for themselves.
    First you want to remove the visor assembly from the car.
    Use your fingers and pry off the Homelink cover. It snaps off.
    Take apart the Vast Meth controller and get rid of the back piece (eventually)
    Use my pictures in the email I will send you to copy the placement of the top of the controller onto the Homelink
    Send me your Email
    Get a Dremel tool
    Get a snake bit 3 feet longish
    Make a stencil of the inner edge of the controller top on the top of the Homelink with a black marker.
    Dremel out the Homelink SLOWLY (I think I spent the most time on this to get it perfect)
    Test fit it ever few passes (mine snapped into place it was so exact.
    Put the guts of the controller into the homelink cover under the buttons. It screws into the top of the controller you snapped into place on the Homelink top. SEE PIC
    Trim any excess homelink material that is in the way when routing the wires
    Route the wires up through the homelink section to the top of the mirror that is closest to the windshield when in its standard position.
    Pull the wires out the top of the visor after you drill a small hole
    Part two: Running wires
    Get a metal coat hanger and open it up
    GENTLY pull the hangar through the visor anchor hole into the A-pillar
    Tape or loop the hanger to the wires and slowly/carefully pull them through
    Put the visor back on after drilling a small access hole for the wires to slip through in the visor anchor piece that attaches to the roof/A-pillar
    turn the wires so they are all next to each other between the visor and the hole
    Electrical tape the wires together
    sharpie them black so they blend in better
    You will never see the wires unless you put down the visor, even then you barely see them
    Open the mirror.....still work?
    Flip down the visor....still work?
    Move the visor to the left position...still work?
    Good! Chase the wires into the fuse panel/knee bolster area and hook that bitch up using the provided directions/forum knowledge.
    Watch the meth dance light up your night life right in front of your eyes.
    Wings
    Carbs
    Titaniums
    Aug 08 2009
    owde
    you're right with both assumptions
    I knew meth can be run all the time but I also thought it could be used occasionally like nitrous. And while I don't have a manual transmission, I usually drive in Tiptronic mode. I just don't like moving much while at speed.
    #VhatIsProblem?
    [sbsc]
    GCCRSTFTMFW!
