Results 1 to 4 of 4
    Active Member One Ring dgeqsgv3's Avatar
    Mar 04 2010
    York, Pa
    Getting ready to finally lower my car...
    Ill be putting coilovers on in about 2 weeks and plan on dropping it 2 to 3 inches. But I was wondering if i will need spacers to clear my tires from the inner wall. I bought 17x7.5 b6 sport wheels off of my friend with 235/45 tires. I know thats a little bigger than I should have but i needed tires quick and it was a good deal. I believe the offset of the wheel is 43. I heard the fronts should be alright, but the rears would rub...Is that true? And Would i be able to just space the rears 15mm and be fine? Thanks in advance.
    Veteran Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    Nope you are all set my friend. I have same tires and just bout same specs on my wheels and am at 24.5" GTF. Will be getting 10mm for front and 15mm for rear for better stance tho.
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Yea I think you should be fine as well, with those width tires on those wheels.
    Lets see some before & after pics! I was so happy when I finally got rid of my 4x4 stance.
    ~Brian
    1998.5 A4 2.8QT
    Mar 04 2010
    York, Pa
    Awesome. Thats what i like to hear. Thanks to both of you for your help. Ill take some pics and post em then....And yes im very happy to finally drop it. Its been 3 years since i bought the car, so its now 3 years over due.
