Results 1 to 2 of 2
Thread: MAF Question?
    Dec 10 2009
    new york
    MAF Question?
    I found my MAF Sensor, unfortunately i could not find any DIY(IF YOU HAVE SOME YOU COULD SEND LINK, APPRECIATED GREATLY). My question is about the little pin which is connected to the MAF (like a USB) how do you remove that and how do you put it back? Is there like a small thing underneath(on the down side of it) that you press in order to unclip it or not?
    Thank you guys
    Veteran Member Three Rings BerNur's Avatar
    Jan 31 2009
    Brandon FL / Astoria NY
    you just have to pull it out then unscrew the clamp from the hose and pull the hose back toward the front of the car there is 2 star screws you can take them out with a tiny flat head screw driver fairly simple it will make a lot more sense once your in there picking through it
    EDIT:
    you can also take a look at this post no pics but its the first post that came up in my search
    http://www.audizine.com/forum/showth...hlight=maf+diy
