I was wondering on the Koni/Stasis setup, which half of the bumpstop do I leave? Stasis says to cut off the upper half, and use the bottom half. However, the upper strut cap has sorta a cup to hold the bump stop. It seems that I should leave half connected into that cup, but I installed it so the bottom half is there. Will there be any negative effects of having that upper cup hit the bumpstop instead of it traveling and hitting the shock body?
Also, does this setup settle? If so, how much, should I set them a tad higher because of this?
Chris
