Results 1 to 10 of 10
    Veteran Member Four Rings VegasAIV's Avatar
    Feb 25 2009
    B7 A4
    Las Vegas
    5mm spacers/ need extended bolts?
    Just posting to see what people say. Ive read that its not that big of a deal to get extended with 5mm, or should I do it anyways? Im not planning to track it with the wheels im putting on, just for DD. TIA fellas!
    F.T.W.L.T.B.D.W.I.C.T.W
    Turbo lag is just foreplay...
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    i would get new bolts
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Quote Originally Posted by plokm View Post
    i got new ones with mine
    Established Member Two Rings remOOOO's Avatar
    Jul 10 2008
    A4/B7 Avant 2.0T Quattro
    Naples FL
    so what size would You guys go with 5mm spacers?
    and what size would You go with 10mm spacer? will 35mm bolt be ok? or maybe 40mm?
    http://www.ecstuning.com/Audi-B7_A4-...ts/ECS/ES8629/ wil those bolts be long enough for ET45 +10mm spacer?
    thanks!
    Jul 10 2008
    Naples FL
    really? no one knows? :(
    Veteran Member Four Rings Vorsprung's Avatar
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    It says right on the site....
    To determine the correct bolt size, add the width of the spacer to your stock lug bolt size (28mm for OEM applications)
    -Ian
    Jun 14 2005
    Anaheim, CA
    5mm and thicker would need extended lug bolts. The stock lugbolt shank is 27-28mm long, just add 5mm to that and that's what you need for the spacers.
    Brandon @ VMR Wheels
    Feb 19 2007
    Louisiana
    33-35mm bolts should be good
    Veteran Member Four Rings pw211's Avatar
    Dec 14 2008
    Bay Area
    its extremely important you get the extended bolt. I know someone who's wheel fell of due to a lack of correct bolts and he's still paying for the lawsuit that ensued after the wheel hit a car..
    Pat
    P.I.I.T.B
    IG: pwwhite
    "I bet if Sean posted a picture of toast it would get 50 likes. And more than 3 people would say 'specs?'" - Solarsuplex
    Veteran Member Four Rings xULx's Avatar
    Jan 20 2010
    07 Brilliant Black A4
    San Diego
    Quote Originally Posted by pw211 View Post
    wow sucks for the other person
    -Jesse
