Results 1 to 4 of 4
    Dec 02 2008
    2009 Quartz B8 A4 2.0T
    Long Guy-land
    Disassemble Dash Trim Question
    I would be greatly indebted if anyone could give some advice for removing the silver trim off of the black piece on the dash, it might be glued, as i dont see anything that could be unclipped or unscrewed.
    Btw, this is the next piece that i am wrapping and will post pics/guide once its completed.
    Thanks as always!
    Established Member Four Rings matt@oCarbon's Avatar
    Oct 19 2004
    Glendale, AZ
    Quote Originally Posted by ZomgZombies View Post
    Thanks as always!
    Its just glue. Stick a screwdriver in between the two pieces and pry them apart.
    Dec 02 2008
    Long Guy-land
    Quote Originally Posted by matt@oCarbon View Post
    Thanks matt!
    money is tight currently, but soon as its not, you will be seeing these pieces for the REAL fiber and epoxying, your work is amazing!
    Oct 19 2004
    Glendale, AZ
    Thanks matt!
    Thanks. Just take it slow and you'll be fine on these two, its pretty tough to screw it up unless you rush.
