Results 1 to 22 of 22
    Sep 23 2006
    2002 A4 1.8TQ 5spd
    Machine shop that can work on Inconel?
    So one of the studs has broken on the APR manifold from the stage 3 kit...
    We have sent it off to APR to have it repaired, but I have very little hope that they will get to it anytime soon, as it seems the only person that can repair it is away this week. Even after that, it is not likely I will see it for a couple of weeks.
    So does anyone know of a machine shop anywhere in the U.S. that is able to work on Inconel?
    Or does anyone have an APR manifold for sale?
    We have looked at a variety of other manifolds (ATP,PAG,etc.) but it does not seem like you can retain the stock airbox with any of these?
    Would appreciate any info as this is really starting to aggravate me...
    APR Stage 3+
    Sep 23 2006
    2002 A4 1.8TQ 5spd
    Bump...
    APR Stage 3+
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    You mean something like this?
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Jeff, is your dp done yet?
    Veteran Member Three Rings Lou_B5's Avatar
    May 22 2009
    06 Sequoia
    Apopka, FL
    PM SpeedWorksAuto down in Renton area. He raves about his local machine shop and the prices are fair.
    Saint Cloud, Fl
    Lookin good Jeff, I assumed it was going to be top mount
    instagram ------------> low_enforcement
    Jun 21 2005
    Milton, Ontario
    Jeff, what turbo is that?
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Jeff View Post
    No love for my pics?
    You have to email me that postage tag so I can get it back to you.
    Quote Originally Posted by SleeperAvant View Post
    GT3071 I believe.
    GT3076 also fits on that manifold. Fits very nicely too and you have room to run a stock-like TIP with the 4inch ported shroud compressor inlet. I like this manifold a lot. Casting quality is also top notch. A lot of work was put into this and it clearly shows relative to other products on the market.
    OP. Contact any machine shop that specializes in the aerospace industry (there are a ton is Seattle). Inconel is used extensively in the aerospace industry and those machine shops are familiar with this material. It is a lot more difficult to machine than mild/stainless steel and aluminum which is why most shops won't touch it. If they don't have the right drills and end mills then they will just destroy their tooling.
    -Doug
    Sep 23 2006
    2002 A4 1.8TQ 5spd
    Very interested in this...sent you a PM.
    APR Stage 3+
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    Very interested in this as well............ info please.....
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Feb 18 2004
    Los Angeles, CA
    Quote Originally Posted by mrbacardi35 View Post
    Yes, DP is done. :)
    Feb 18 2004
    Los Angeles, CA
    Quote Originally Posted by 7speed View Post
    Thanks. No, this basically sits as a bottom mount in the stock location (pushed slightly back in between #2 and 3 to allow room for a inlet pipe). With the wastegate outlet capped off (on T25 with internal WG), you can even run a stock airbox. :)
    Feb 18 2004
    Los Angeles, CA
    3071 is correct.
    I thought I'd get your permission first to post your pics Doug. But if you have them handy, post them up!
    I've been so swamped at work, I literally forgot about the call tag. I will have it sent this week though.
    GT3071 I believe.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    3071 is correct.
    You had my permission when I emailed you the link
    Here is a 3076 on the T3 flanged PSI Concepts Manifold.
    Note: you can clock the compressor housing more to gain more clearance with the framerail.
    (don't mind the missing and incomplete T3 bolts. I was trial fitting when I took these photos).
    -Doug
    Nov 29 2005
    Edmonton, AB
    The timing on this most may have just been perfect. Doug i assume that's your avant this is going in?
    ~Chris
    Tumblr
    Sep 18 2006
    Yes, DP is done. :)
    Got any pics of that thing installed?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by MmmBoost View Post
    That is my car that I did some test fitting since I had a 35R and 3076 handy (35R doesn't fit due to the larger compressor housing). I am not running this manifold for the timing on when this was available did not work with the plans I had in place.
    -Doug
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    Like that manifold a lot!
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Nov 29 2005
    Edmonton, AB
    Ahhh.... i was going to ask about what happened to your ASP stuff.
    How do you like your ASP setup? Any problems with the Treadstone mani?
    ~Chris
    Tumblr
    Dec 03 2005
    2 pedals 1FG
    connecticut
    The only thing I have left from the ASP GT28RS kit are the turbo oil and coolant lines and the MAF housing. I'm now using the stainless steel Treadstone T3 flanged manifold and we welded a 38mm 2-bolt to 38mm V-band WG adapter to the manifold so I can run the new TiAL MV-S 38mm V-Band wastegate.
    The ASP GT28RS kit and software is solid. It makes a consistent 275-285awhp on 93octane and it just plain old rips and is fun to drive. The bulk of that 'kit' is not feasible for the goals of my car so I slowly sold it to good homes.
    -Doug
    Feb 18 2004
    Los Angeles, CA
    I will shortly.
    Sep 23 2006
    2002 A4 1.8TQ 5spd
    We received the PSi concepts manifold from Jeff and did a test fitting but unfortunately there were problems with the wastegate actuator clearance on the GT28RS.
    Since I am having a shop do the repair work it was just too expensive to have them make the necessary modifications to the downpipe / actuator. So it makes more sense for me to wait for APR to repair my manifold than to try and make this work.
    It seems like I may finally get it back this week after a 2+ week wait.
    But dealing with Jeff was great, he was very helpful in getting everything shipped ASAP, answering my questions, etc., so someone should definitely give this manifold a try!
    APR Stage 3+
