Results 1 to 11 of 11
    Senior Member Two Rings Audi_A5's Avatar
    Apr 28 2008
    Belgium
    Koni FSD dampers
    Something that might be interesting to ask to other owners with springs only,
    I have the H&R Lowest version of springs, don't know wich one it is called in the US OE/OE sport?
    These FSD dampers should give an extra bit of comfort and handling to the car
    but is it worth the extra cost, aprox 700€ let's say +/-950$
    Or would it be best to say the extra money and install coilovers?
    Knowing that I do NOT plan to lower the car any more..
    SOLD - '09 A4 B8 Ibis White - AWE cat-back / H&R / S4 Titanium grill / Carbon Interior / 19" BBS LM F8.5 R9.5 / JD-Engineering ECU
    CURRENT - '11 Audi A1 8X Phantom Black
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    This is the 1st I've heard of Koni FSDs on B8 A4s. I wasn't aware that they were released yet, so this would be good news if it weren't for the fact that they are ~$950 That price + the cost of H&R springs brings you very close to the price of coilovers.
    I suppose if you already have the H&R springs, getting the Koni FSDs might save you some money over coilovers. That being said, consider the fact that you should be able to sell your H&R springs to recoup some money if you go for the coilover setup (even tho you won't ever be adjusting height).
    btw, the lowest H&R springs in the US are the Super Sports.
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hόper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Aug 10 2009
    Eu is more expensive than US.
    May 26 2009
    Houston, TX
    I think I remember Koni FSDs being less than $600 for the B7. Is EU really that much more expensive, especially considering that Koni products are from Germany (I think)?
    Jun 02 2009
    San Francisco
    Quote Originally Posted by ItsDubC View Post
    Simple answer, YES.
    Aug 10 2009
    Eu = different market. I sourced items from US before, that were actually made in by EU firms. It was actually cheaper to pay postage + duty than to purchase item in EU.
    Example. Bilstain B16 in EU 1700 Euros (without installation costs, and thats if purchasing via online from a German company).
    May 26 2009
    Houston, TX
    Wow, I guess I'll STFU about OEM part prices then
    Mar 19 2006
    B8 A4 Avant, 8P A3 Sportback
    Lone Star State
    I have the FSD's/Neuspeed springs on the A3. Hindsight tells me I should have gotten CO's. Will not make this mistake with the Avant.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    FSD's don't work well with ANY lowering spring. If you plan to use lowering springs, run with KONI Sports or Bilstein shocks instead.
    Veteran Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    At this point wouldn't it just be more cost effective to install some "economy" coilovers?
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ | AWE CB Exhaust | 034 HFC l EC HFIC Pipe | Forge DV Spacer | 3M Di-NOC Carbon Fiber Interior Trim | 3M Chrome Grille Trim | SG Supreme 28 | Debadged | Fly Eyes Kit (f&r) | Needle Sweep | Window/Moonroof control w/Keyfob | Seat Belt Chime Disabled | "Wink" Disabled | Double Unlock "Beep"
    Account Suspended Three Rings
    Oct 15 2015
    That's not completely true. I had the koni fsd on eibach pros and they rode mint! Rode better then stock and handled better then stock. I would run the again!
