Results 1 to 3 of 3
Thread: MAF Fault Code
    Feb 20 2007
    Hollis, NH
    MAF Fault Code
    Ok, just need some quick info. As always, my car is perfect right up until inspection month then something craps out. So, here I am, now past due with my inspection sticker because my check engine light is on with this fault:
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 002 - Lower Limit Exceeded - MIL ON
    Readiness: 0000 0000
    Need to know the quickest way to diagnose and fix. I am working on borrowed time now, so any help would be greatly appreciated!
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Try cleaning the maf. Its avail at local auto parts store also I got a brand new maf assy for sale. http://www.turnermotorsport.com/html...ODUCT_ID=05110
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    I've also got a MAF for sale if you end up needing one.
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
