Results 1 to 12 of 12
    Active Member Four Rings CrtchRktRcr's Avatar
    Feb 25 2009
    CRF50
    Scottsdale AZ
    VAG- will not read my car, ideas?
    I have a 99 a4 1.8t. A fellow ziner tried to scan my car and it wouldn't read anything. The only part that it could get a signal from was my dash. Has anyone had a similar problem or have any ideas on how to troubleshoot this issue? thanks.
    AEB B5 A4, QUATTRO MANUAL SPORT-H&R,FORGE,1BAR,5BAR,BOOM
    xbox live: Cr0tchf4i
    ["im in the computer lab and some dude with about 8" just sat down next to me -S4Jet"
    WWW.ASKMY2CENTS.COM
    Veteran Member Four Rings dcampana's Avatar
    Nov 01 2006
    04 Allroad, 01a41.8Q
    Nor Cal
    do you have an aftermarket radio in your car? that can cause issues from what i have heard. i have an aftermarket in my car with no issues, bt i have read there are communication errors. i am looking for the wor around in case:)
    my ride: 2001 A4qtm... 2871r, 440cc, 3 bar, turbo xs dv, custom 3" exhaust, test pipe, Cm fx400 billet LWFW...
    2004 AR... stage 1 DAZ tune
    Timing belts, clutches, and all done in the North Bay. Pm me.
    Nov 21 2006
    san francisco, ca
    Is your ABS light on when the car is turned on?
    --dillon
    1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
    2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    pull the fuse to your dashboard
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Feb 25 2009
    CRF50
    Scottsdale AZ
    Quote Originally Posted by dcampana View Post
    do you have an aftermarket radio in your car? That can cause issues from what i have heard. I have an aftermarket in my car with no issues, bt i have read there are communication errors. I am looking for the wor around in case:)
    nope, stock head unit. Level line converter and amp in trunk but the amp shouldn't change anything. I forgot to post that though! I have also heard about that before.
    WWW.ASKMY2CENTS.COM
    Feb 25 2009
    CRF50
    Scottsdale AZ
    Quote Originally Posted by nunya View Post
    --dillon
    SURE IS.
    WWW.ASKMY2CENTS.COM
    Feb 25 2009
    CRF50
    Scottsdale AZ
    Quote Originally Posted by maxspeed View Post
    just the fuse for my cluster?
    WWW.ASKMY2CENTS.COM
    Nov 21 2006
    san francisco, ca
    unplug the abs module, there is a connector on the top and bottom. A faulty abs module will keep you from connecting to everything on your ecu, and even keep you from being able to do a TBA.
    --dillon
    Feb 25 2009
    CRF50
    Scottsdale AZ
    Sweet dillon thanks. I know there is the big female plug on top. Do i get to the other through the wheel well? Or can i just reach underneath?
    WWW.ASKMY2CENTS.COM
    Nov 21 2006
    san francisco, ca
    Sorry, not sure. I have all my windshield washer stuff ripped out so its easy. You may need to go through the wheel well.
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    just pull the one on top. should work
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Feb 25 2009
    CRF50
    Scottsdale AZ
    sorry, not sure. I have all my windshield washer stuff ripped out so its easy. You may need to go through the wheel well.
    ooo i'd like to do that also. My wiper resovoir has a crack in it and i'm sick of it beeping at me.
    WWW.ASKMY2CENTS.COM
