Results 1 to 12 of 12
Thread: Airbox Removal
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    Airbox Removal
    Ok, quick easy question. How do i get the airbox out of the car? Once the hoses and wires are removed, do i just pull it away from the fender? There is some rubber grommet holding it on.
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Senior Member Two Rings mainer0311's Avatar
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    There is a plastic pin that goes into the fender that you have to pull out. Then there are 2 rubber grommets that hold it down to the frame rail, it just takes some force to pull it out and up.
    Cooper
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    Yup just pop out that plastic pin at the top and give it a wiggle and a yank straight up.
    make sure the steel hard line from the EVAP system is disconnected.....
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Dec 27 2009
    Edmonton/Alberta
    Ok so pop, wiggle and yank. Got it.
    Kyle
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    Yep, pull it off the grommet and then out of the two tabs at the bottom. It's a PITA to get back in though...
    Veteran Member Four Rings 3vom's Avatar
    Aug 26 2009
    Quote Originally Posted by Matt@EuropaParts View Post
    I agree completely. It's a job to get that thing sitting in right after you remove the bugger.
    I love boost.
    Dec 27 2009
    Edmonton/Alberta
    Yea I'll give it a whirl tomorrow. I'm going to remove all the emissions crap right away, so I might as well learn how to remove this stuff now. And the whole thing needs a good cleaning anyhow.
    Kyle
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    Quote Originally Posted by KFizz View Post
    LMFAO
    Oct 08 2009
    1966 mustang sprint
    Atlanta
    Do you have to take it out to replace the filter? or can you just slide the filter in?
    Dec 27 2009
    Edmonton/Alberta
    I think you can just remove the upper half to change the filter.
    Kyle
    Dec 22 2009
    Piscataway, NJ
    Quote Originally Posted by bode View Post
    The top part kind of hinges up so you can slide the filter in. It doesn't need to come off.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    you can slide the filter in but it will take some force and the occasional pinched finger. don't forget swearing.
