Results 1 to 4 of 4
    Registered Member One Ring seldon57's Avatar
    Feb 23 2010
    St. Louis
    Symphony II+, Problems when using iPhone Charger
    I currently have a 2008 A4 with the Symphony II+ radio. I also have a Belkin micro auto charger:
    http://www.belkin.com/IWCatProductPa...duct_Id=489423
    My radio reception is fine with the little charger and cable plugged in, however, once I attach my iPhone my radio reception takes a crap. Does anyone have any idea why charging my phone would cause this?
    Active Member One Ring D-two's Avatar
    Oct 20 2009
    1995 lexus sc400 2001 A8L 1993 GMC k1500 suburban
    VA
    does your car have blue-tooth capabilities
    or is the Belkin unit you have have a built in FM modulator
    Feb 23 2010
    St. Louis
    I neither have bluetooth of anysorts in my car not is the belkin unit an FM modulator. It is a simple cigarette lighter adapter charging cable. If it makes a difference, I get the same interference if I plug it into either the socket next to the ash tray or the socket under the arm rest.
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Turn off wifi? Use 3g speed instead of edge
