    Dec 02 2008
    Help with (G28 engine speed sensor) replacement.
    I need help Swapping out the engine speed sensor replacement. I tried to take out the sensor and it was very hard. I tried to get the sensor from the bottom like it says in the DIY but was unsuccessful. does anyone know how to replace the sensor from the top and could help me with pictures?
    Senior Member Two Rings ems173's Avatar
    Jan 17 2009
    03 A4 1.8TQ M
    Old Bridge NJ
    You did unbolt it right? Just asking the obvious first, also, there is an oring on it so you might have to put some force into it....
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Unbolt, pull and replace. Like mentioned above, the o-ring makes it tough...just muscle it.
    Dec 02 2008
    Is there a way you could show me how to reach the sensor from the hood. Instead of under the car?
    Jun 21 2008
    Here's the only writeup I've seen...hope it helps: Click Click
    If you want to get it from up top, you are prob going to have to remove your oil filter.
