Results 1 to 12 of 12
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    RS6 Turbo Install Issues and Questions
    Doing an RS6 turbo install right now. However, there is a big issue. On the passenger side, the turbo does not fit. As you can see fmor the picture, the wastegate actuator is hitting the motor mount, the motor mount bolt, and the starter. I can remove material from some stuff, but I am not going to shave down the starter...
    Is this normal? The turbos are used, and the previous owner does not know if any modifications were needed. It is more then 6mm off, so a fair amount of material would need to be removed, and this doesnt seem normal. We've tried a couple manifolds to see if there was a discrepancy.
    The Best Things in Life Are Free... Or Heavily Discounted!
    Veteran Member Three Rings sparkyvw's Avatar
    Feb 11 2008
    B8 avant,964,B5 wb s4, mk2 vr, mk3 vr
    Palm Beach Gardens FL
    look nothing like my rs6s at all. Not BW actuators thats for sure.
    Cloud9Helicopters South Florida
    ROTIFORM AIRLIFT
    Mar 22 2009
    Norcal
    Ok but the turbos were installed on the car... so how were they installed on the car? Did they just remove a huge amount of material and not use the 4th bolt in the motor mounts? Custom starter? They are Antoan's, but since he didn't install them, he apparently has no clue. Can this wastegate be replacing with a standard wastegate? or does it have different opening characteristic?
    the wastegate actuator has been modified to fit into there, its a very tight fit, material has been removed from it... but its not removed in the problem areas.
    Any ideas? Antoan has no idea.
    Feb 11 2008
    you could most prob get bw actuators to fit. They got them to fit but god knows how looking at them pictures. Have you got any pictures further out so i can see the hole turbo bolted up ? See what the gap is like from the turbo flange to the manifold flange.
    ROTIFORM AIRLIFT
    Dec 06 2007
    Calgary, AB, Canada
    You could get some BW actuators and it would be plug-n-play. Otherwise, you could shave off a bunch of metal and make those ones work. I'd personally get some of those shiny brass-looking ones, and not compromise the structural integrity of the mount support if I were you
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    yeah, my RS6's were very tight but nothing is rubbing.. get some K04' wastegate actuators and youll roll with the rest of the build.. and btw the k04's are actually stronger than the RS6's.. (wastegate actuators)
    RS6 hybrids and corn
    Mar 22 2009
    Norcal
    Quote Originally Posted by bigern45 View Post
    Thanks gentlemen. We decided to get some K04 actuators, which we can hopefully get quickly. I am still confounded by how these would ever fit on anyones car, without at least a custom starter or something and heavy modifications to the motor mount bracket. They are clearenced for vertical space, but not horizontal space.
    People have told me K03 and K04 use different actuators. But they actually have the same part number sometimes, and a different one sometimes. Anyone want to comment on this? They apparently start at the same pressure (around 6-7psi) (according to ATP and to my home tests (t valve, they open equally and the same at the same pressures). And they are interchangeable as far as bolting them on. So... anyone reason I can't use a pair of these? Lot easier and cheaper to find then brand new K03/K04 actuators, which run between $80 and $150 each. 034 also sells the same actuator for both K03 and K04's.
    Quote Originally Posted by The_Jerbel View Post
    I also agree. And I am not comfortable removing material from the starter either... I don't know how thick it is or anything like that, and it would essentially be touching. As I am sure we all know, metal expands a huge amount at the heat levels our engine bays see, especially near the turbo, and if there is no clearence @ 55 degrees... there is going to be negative clearence at 350 degrees. This car sees track duty, can't be having that.
    Veteran Member Four Rings TweetsS4Estate's Avatar
    Mar 30 2008
    NYC auditioning.
    Yes k03 and k04 are the same P# Make sure you have them set right call mike at vast and see if you can send him the turbo's and have him set the acuator's it is very important that they are set right i hope you have a built motor because those turbos are capable of making 700CHP so about 550-600whp.
    Veteran Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    Anything metal in your engine bay shouldn't be expanding by more than 3-5 thousands of an inch in any direction at 350 degrees.
    01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
    I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
    Active Member Three Rings antoanS4's Avatar
    Jul 05 2008
    miami
    You could ask Ivan or David at Novitech Tuning they didnt do the install but they have work on my car so many times that they know my car from A to Z, send them a pm they are here on Audizine
    Jul 05 2008
    miami
    The guy that did the install on the turbos is nowhere to be found, changed his number and the shop is no longer where it used to be, sorry, this turbos are amazing i bought them used and i used them for about a year or 8-10K miles and they still dont have play shaft, i hope you dont race the boost on those turbos cause you are going to blow that motor w/o doing rods
