Results 1 to 33 of 33
    Veteran Member Four Rings mattlqx's Avatar
    Dec 21 2006
    ‘16 F-150, '01 Jetta 1.8 Race Car, '05 Allroad 2.7T, ‘14 Fiesta ST
    Chandler, AZ
    APR joining the RS4 supercharger fray
    http://www.quattroworld.com/tunernew...er-for-b7-rs4/
    No real details yet... Thoughts?
    The first thing that springs to mind for me is "2 more weeks". ;) Just kidding guys. Thanks for throwing another option into the ring!
    APR's official thread is here. Please direct all your questions and comments there!
    Tons of Audis, Tons of Mustangs. That's just how I am.
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    wow! That is pretty sweet!
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    hahahaha mrperfect... youve just opened up the 2 week bag
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Dec 31 2008
    PA
    that looks well engineered, the integration of the oem intake, etc.
    http://www.harrop.com.au/company_pro...ackground.html
    http://www.harrop.com.au/root_folder...s/lsj-sch.html
    ~18000 rpm to get 1.35 x Q at 8000 rpm (~5 psi boost)
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    too bad we don't have a 2.0L 4cyl cobalt ss engine
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    Harrop HTV1320 supercharger. what the heck is that?
    Veteran Member Four Rings Silver B6 S4's Avatar
    Dec 08 2008
    2003 PT Cruiser GT Stage 2
    Petaluma, California
    Quote Originally Posted by drew View Post
    What is it? It's made for a 4 cylinder engine!
    Jul 27 2004
    Orange County
    i thought you guys were joking but checked the link....LMAO
    designed for 2.0L engines....hahahah....what a joke
    Feb 01 2009
    New York
    If you read the description its based on the Eaton M62 supercharger, which is apparently the stock blower on the cobalt SS.
    They are probably running 15+ PSI on those low compression 2.0L engines. So with a 4.2L high compression engine running 5-7 psi...the blower is probably more than adequate. It also means it will probably have excellent low speed efficiency due to the small volume.
    I'm interested to see how this plays out. PES and VF are all using much older M90 style superchargers.
    Account Terminated Three Rings JohnnyAlQaeda's Avatar
    Sep 22 2009
    Colorado Springs
    id take the "four banger" s/c'er over any of the others currently offered...
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    the TVS 1320 does seem efficient and flows surprisingly well for being a small supercharger...go figure
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
    Dec 31 2008
    PA
    neither look like a perfect application...
    say we want 1325 m^/hr (780 cf/min) at 1.35 Pr (5 psi boost) ~ 7800 rpm, good for 520 HP
    vol of na engine at 7800 ~ 580 cf/min so 780/580 ~ 1.35 ~ Pr
    blower.....rpm.....eff
    R1320....16500...<55%
    M90.......off the chart
    am I missing something?
    it's an Eaton http://www.eaton.com/EatonCom/Produc.../TVS/index.htm
    Veteran Member Three Rings pattrick02's Avatar
    Aug 22 2009
    South Florida
    that's one tiny s'charger -_-
    No more S4. :(
    World's quickest & fastest TSI in the works, and never ending.
    Aug 17 2008
    Southern NH
    Quote Originally Posted by ArthurPE View Post
    No, you nailed it.
    The R1320 is better than the M90 for said application
    Not perfect but a step in the right direction
    Veteran Member Four Rings KryptoniK's Avatar
    Jan 29 2006
    08 RS4
    Quote Originally Posted by JohnnyAlQaeda View Post
    What do you understand from those charts that made you come to that decision?
    From my understanding 1.34 pressure ratio = 5 psi. At that same PSI and at the air flow rate that is needed... there is minimal difference between the two. The R1320 is slightly better... not sure how the difference will translate into a real world scenario @ 5 psi.
    The R1320 is more appropriate for big boost applications, that's where it's really efficient. At 5 psi everything is sort of in the same area of efficiency.
    Jan 29 2006
    08 RS4
    I think there is something missing in all of our assumptions of how these S/Cers work. From doing my logs, I found out that at 6K rpm I'm at 5 psi, by the time I reach 8K rpm I'm at 6 psi. So that means the M90 is meeting the needs of the motor since it makes more boost up top?
    Also my dyno charts show HP increasing all the way up to 8K rpm with the M90.
    I tihnk the R1320 is going to be more efficient than the M90, but not by a whole lot... in a 5psi application that is.
    Dec 31 2008
    PA
    what I found M90 vs R1320
    I printed the charts and made up a spreadsheet trying to keep parameters ~ the same, ie, boost ~5 psi, overspeed ~ the same (the M90 must be spinning >13500 to get the required air...
    my opinion, both are an engineering compromise, each designer must have had different priorities...and I won't second guess them:
    -the R1320 is more efficient, considerable so (avg over the range 62 vs 53, 17% more efficient)...meaning better thermal effciency...plus it's got an intercooler, so advantage R1320
    -the M90 turns much slower, peak 15.6k vs 17.1k at 7800 rpm engine speed (R1320 overspeed 1% over last chart value, M90 ~15%), advantage to each, less over-range R1320, slower = less parasitic losses for the M90
    I'm guessing the increase in efficiency should ~ offset the increase in parastic losses, so power should be ~ equal provided the M90 has an intercooler...
    I can't attach the ExCel spreadsheet, if someone wants it, PM me...
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Quote Originally Posted by MrPerfect View Post
    APR was actually the first company to successfully supercharger the V8 motor. Keith had cast intake manifolds from 2005? if I remember correctly. They were casted right around the time as the 1.8T intakes.Whatever the case finally good to see them come out with the kit.
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    I like options...this can only help us further our knowledge of the potentials, pros, cons and help us make educated decisions. I like competition, it benefits everyone imo.
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Nov 05 2006
    Fair Lawn
    ^^^ x2
    Jan 29 2006
    08 RS4
    I really hope this kit comes out in the market. Would love to see resutls of a different blower. It looks like APR's intake manifold uses a fairly large cooler core, noticed the coolant tubes exiting on the far sides of the IM... looks like a very efficient kit.
    Noticed they also scrapped the stock rubber intake tube and replaced it with a silicone type tube.
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    The Official APR RS4 Stage 3 (supercharger) Thread
    Please put all questions, comments and conversations regarding our new product in this thread. I will be back to update this first post with more information as I recover from this weekend's events.
    If Mr. Perfect sees this, I think it would be awesome if you could get Anthony to merge this thread with the one you've already started.
    FWIW, all questions and concerns will be quite handily satisfied with real data and performance results so please, let's get them out there. All APR critics and self taught engineers, GET IN HERE!!
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Two weeks?
    Jan 24 2008
    West Coast
    Quote Originally Posted by Keith@APR View Post
    As you requested, I merged the two threads. There's a few of of that can help out around here. lol
    Best of luck. We look forward to much more info.
    Moderator
    Dec 31 2008
    PA
    aren't all engineers self-taught? (in fact, isn't everybody self taught?)
    it's not like knowledge and understanding can be rammed into someone, they must seek it on their own, ie, self taught :D
    all an education does is give you the basics...the rest is up to the individual....
    Veteran Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    ArthurPE hit this one out of the park and johnnyalQ put up the maps that end the case. The M90 isn't a good choice for our cars the 1320 isn't the biggest blower
    for our cars but its a better choice. Its clear that the TVS blower isn't just more effiecent its a better choice and not the step I would like to see but a step none the
    less.
    For all of you who call us REAL world guys Supercharger hatters and say were JHM band waggon only guys who hate the Superchargers....Your going to have to
    eat your words.. This is what we have been asking for from the begining a real proper selected Supercharger... Im not going to do cart wheels just yet... You can
    show me 500whp and you still need to get this to a track or your just blowing smoke with a better cover..
    Also the boost argument... Boost is a measure of how innefficent the blower/unit is... such as the intake. Intercooler core. ETC ETC..
    APR nice step the first REAL dicent looking step for the RS4...Not a Supercharger hatter no more.. Now it looks like we have some hope.... Still need to get that to the
    track before Im going to be convinced
    the only issue I have is Quattro world???? seriously... FTL.. Post this where real interested people come to get good information
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Quote Originally Posted by jfunkey View Post
    All those guys over there do a lot of jogging in cl....
    Anways R1320 is an improvement, but I think a R1900 would've been amazing. The smaller blower will work well with a conservative and safe tune that APR is known for.
    Jul 11 2005
    Auburn
    Could you put my post first please? I would like to be able to edit it with product information specific to the thread so its easy to find for new thread participants.
    Jul 11 2005
    Auburn
    Nope, that's why they have teachers and our higher education market is a multi-billion dollar industry. If everyone was self taught, schools would be unnecessary.
    That's why every company spends lot's of money to institute training programs as well. Training = teaching. You of all people should understand this, no?
    I didn't say it was a bad thing by any means.
    Dec 21 2006
    Chandler, AZ
    I believe it will always be chronological.
    Create another and I'll lock this with a link to it.
    Jul 11 2005
    Auburn
    Quote Originally Posted by beemercer View Post
    Two weeks?
    We call that 13 days and 24 hours now, thank you.
    Dec 21 2006
    Chandler, AZ
    APR's official thread is here. Please direct all questions and comments there!
