- Oil and Filter
- Engine – check for leaks
- Cooling System – check and top off
- Exhaust – check for damage and leaks
- Check VAG
- Door Hinge Mechanisms – Lubricate
- Battery – Check Electrolyte, add if necessary
- Washer Fluid
- Auto Shift Lock – check
- Tire Pressure
- Reset Service Reminder
- Brake System – check
- Drive Shaft Boots – check
- Road Test
- Lights – check
- Front Axle – check dust seals, ball joints, tie rod ends
- Auto Tranny – check for leaks
- Auto Tranny Final Drive – check for leaks
- Power steering fluid – check, add if necessary
- Dust and Pollen Filter – replace
- Headlights – inspect, adjust if necessary
- Sliding Roof – clean lubricate rails
- Air Cleaner – replace filter element
- Spark Plugs – replace
- Ribbed Belt – replace (This will be part of Timing Belt Job)
Here is the list of parts I will be using, wanted to get some ideas if I should be looking to do anything else while I am in there:
