    Senior Member Three Rings rdwaldo's Avatar
    Aug 07 2007
    2000 audi s4
    Indianapolis,IN
    How often does n75 fail at stage 3? Failed last track event i was at, wondered if
    worth buying a mbc to have with me in case it happens again at the track. I have only had one fail which was the original.
    Sep 11 2009
    NE
    it is advisable to buy a new one when you go stage 3. As a matter of fact, Vast stage 3 kit actually includes one. Given that it lasted for about 10 years in your car, albeit at stock PSIs most of time, I would say that they don't fail that often...
    Aug 07 2007
    2000 audi s4
    Indianapolis,IN
    I replaced it not long after stage 3. just scared it will fail again at the track
    Dec 06 2007
    Calgary, AB, Canada
    I agree with julex. The N75 is just a solenoid, and isn't something that fails very often. It isn't uncommon for brand new N75 valves to be faulty, though.
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    Ive had one fail on my S4 and 2 on my 1.8T. Bad luck maybe? One of the bad ones on the 1.8T was bad from the dealership. Third worked like a charm. But they dont seem to fail very often.
    If your tune can allow for it, an MBC is simpler and allows more control. Spool faster too, as the wastegates stay shut for longer. That being said, majority of people run them with no issues. If you never care about adjusting your boost or anything, then I see no reason to use an MBC (aside from simplifying things, which I am all about).
    The Best Things in Life Are Free... Or Heavily Discounted!
