Results 1 to 25 of 25
Hybrid View
    Sep 17 2009
    miami
    Odd problem pumping gas.. Anyone else have this??
    OK, When i'm pumping gas no matter what angle i hold the nozzle in it stops pumping as if it topped off.. I have to barely depress the handle so that it wont stop.. It takes forever to fill the tank.. If i listen closely i can here like an escaping air noise building till it stops..
    Has this happened to anyone?.. any ideas?..
    2005.5 A4 Dakar beige - 18" VMR gunmetal v710 - Stage 1+ Unitronic
    Sep 13 2005
    B8 A4
    Califonia
    yeah, same thing happened to me. There's a hose on the driver rear side under the car that lets fume pressure exit the gas tank, in my case it collapsed. Check out the hose/tube, its one of the tubes running to the charcoal unit underneath the gas tank. I cut the the hose so that the pressure has somewhere to exit, not environmentally friendly solution but it worked.
    Sep 17 2009
    miami
    Quote Originally Posted by zboi View Post
    Wow thanx.. I'm not sure what im looking at under there.. Any way to get a picture or description?... So its the build up of pressure that triggers the gas pump?
    Senior Member Three Rings Barker29's Avatar
    Jan 19 2010
    2018 VW Atlas
    South Jersey
    If you dont want to do that i used to pump gas yes i live in that state haha but if you get a pen or something like that and stick in under the rubber part that covers your tank so that it kind of breaks the seal it does the same thing they were talking about it just gives the fumes somewhere to escape.
    Deactivated Three Rings
    Mar 17 2009
    None
    Charlotte/NC
    Quote Originally Posted by Barker29 View Post
    you theta ki? same here
    Jan 19 2010
    2018 VW Atlas
    South Jersey
    Its Theta Chi* my man, are you sure are
    Mar 17 2009
    None
    Charlotte/NC
    k well im not. *snaps fingers*. this thread title should be changed as well
    Jan 19 2010
    2018 VW Atlas
    South Jersey
    Well in that case nice to see a brother on AZ and i apologize for the thread jacking
    Apr 15 2007
    WNC
    The above was funny.
    2013 RS5, 2014 Q7
    Account Terminated Four Rings
    Aug 31 2009
    Short Hills, NJ
    lol two nerd frat boys going at it, lets see what happens!
    Oct 20 2008
    Denver
    Theta Pi Must Die
    Established Member Two Rings A4B7GA's Avatar
    Apr 20 2007
    A4 B7 5.5, 05 Exploder
    Bal Harbour, FL
    I had the same issue...I' CPO had both pumps replaced in the tank and still had issues...so they replaced my fuel tank as well.
    so far so good...but I doubt it will last. I will ask them to look at the charcoal fitler next.
    my mod list...really boring $!ht + APR
