Page 1 of 3 123 LastLast
Results 1 to 40 of 115
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    Thumbs up DIY - Fog Lights with High-beams and misc codes discovered.
    I've moved all the coding and write up to my website. Now you can get all my coding and others in one place, check it out here: http://www.audienthusiasts.com/VagCom.html
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at [email protected] I don't frequent this forum very often.
    Established Member Two Rings Superduke's Avatar
    Nov 23 2009
    Audi A4 Avant 2.0 tdi '10 - Mitsubishi Pajero LWB 3.2 Aut '07
    Netherlands
    David the VAGcom-specialist!!! You should sell your details to RossTech ;)!!
    Mitsubishi Pajero LWB aut.
    KTM SuperDuke990
    Wheelbarrow "Fort"
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Essex, UK
    "Rear fogs stay on with High Beams." Why would you not want that? Being able to turn it off is as useful as the "left fog light on" option !
    Good work again !
    What I don't get is it the descriptions are already in VCDS then this has already been worked out by someone else and hence I can't understand why the Ross-Tech wiki doesn't show it.....but then it actually doesn't seem to show anything in 09 Cent. Elect
    Nov 06 2009
    Quote Originally Posted by scottyuk View Post
    Good work again !
    The 09 is strange, sometimes it shows some for me and sometimes not, but nothing for high beams and fogs.
    Maybe my descriptions suck or I'm not understanding what your saying. You can turn the fog lights off and on, it's just that using the high beams wont turn them off. Which is what they do now. I can kind of understand the fronts turning off depending on local laws but why the rears go off I have no idea.
    Yeah that front left fog light one is a good one. I just don't get that one. I had a code and lost it, it turned the front turn signals into parking lights. I may try and find it again.
    Nov 06 2009
    Quote Originally Posted by Superduke View Post
    I don't know about specialist.. More like comacozie. You know a bit of an educated guess as to what bytes to work in and it takes a lot of time out. It just takes so much time committing bit by bit then checking the car for changes. Would go much faster if I had a partner to work with.
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    Good work again !
    And Ross Tech will never show any code online - ever again. You can't see the coding in the label files either.
    You can read Ross Tech's answer here: http://forums.fourtitude.com/zerothread?id=4424113
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 21.9.0 (HEX-V2)
    Mar 20 2009
    Copenhagen, Denmark
    I just need to understand how it works in US
    OEM you can have Fog lights staying on with Headlights, but not Fog lights staying on with High-beams - is that correct understood??
    Why would anyone have "Headlights on all the time" - as DRLs??
    Rene Larsen
    Senior Member Two Rings jabicho's Avatar
    Feb 02 2010
    Muchos Bandidos, Spain
    I have a car with halogen headlights, I´ve tried to change my halogen DRL to the high beams, but the problem is that the original DRL stay on with the high beams as DRL, any idea of how to set high beams alone as DRL? This is the coding I used:
    module 09:
    Halogen lights:
    Channel 1: Brightness of DRL
    Channel 2: Brightness of Mains with Highbeam on
    Channel 4: DRL as Positionlight Brightness
    In common for all above is a value from 0-100 where "100" is full intensity and "0" is off.
    Remember to choose "Secure Access" and enter the code "20113" before pressing "Adaptation"
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by jabicho View Post
    module 09:
    Halogen lights:
    It should be possible to set which lights to use as DRL under:
    Code:
    [09 – Cent. Elect.]
    [Coding - 07] -> Long Coding Helper -> Byte 2
    Bit 2 – DRL via Headlights
    Bit 3 – DRL via Fog Lights
    Bit 4 – DRL via LEDs
    Rene Larsen
    Feb 02 2010
    Yes, I know, but as I´ve said before mine has halogen headlights and this is what I get:
    I´ve tried "DRL via front side marker lights active" which is the only one that allows me to set high beams as DRL, but the problem is that the original DRL in my halogen version stay on with them.Besides, coding here by Ross Tech seems to be mistaken, because if I choose the option "High beams as DRL" the main beams are chosen as DRL. I´m not able to see the way to turn the original DRL off when I set high beams as DRL...anyway, thanx for trying to help
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    David would be a really good neighbor!
    Nov 06 2009
    Quote Originally Posted by rlarsen View Post
    That is Correct.
    Well the highbeams as DRL is the way it used to work on most cars, they just had a low intensity. Now full time headlights I have no idea why you would want that on a personal vehicle except for the safety aspect. I know where I used to work all company vehicles where set to have headlights on all the time on their vans for safety. It is supposed to reduce accidents. However I think with the Audi's if you have the LED lights, they work to attract attention more than headlights would.
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by DavidB8 View Post
    That is Correct.
    We also here in EU (not in all Countries) need to have some kind of DRL on (by law) - and on the A4 it is via the LEDs, but this can be changed in Byte 2 which Lights the DRL is used with.
    But what are the one you found meant for - the same as DRL or what?? why is there two options for the Headlights (Byte 2 and Byte 4)??
    Rene Larsen
    Nov 06 2009
    The one I found isn't just DRL. It turns on all the lights, the same as if you turned on your headlights at night.
    Quote Originally Posted by naemcivic View Post
    Or a really bad influence
    Deactivated Four Rings Kay15's Avatar
    Jun 12 2009
    Audi A6
    Norway
    can you get fogs to stay on as the same time as DRLs, In that menu can you check the DRL via Fogs and DRL via LEDs ?
    Nov 06 2009
    Quote Originally Posted by Kavan View Post
    yep. Look at post 10.
    Feb 02 2010
    anybody has any idea about this?? Or I´m afraid I´m just the only one with these old fashioned halogen DRL which I can´t get rid of !!!
    Feb 25 2010
    magimmeMVE
    Usa
    HI David, Great work. Do you have the parking lights option there? They come on when you park your car an leave your indicator on on any side. It will illuminate the front parking light (wedge bulb) and the rear light on one side only.
    Is there any way to enable these in vag com to come on with the DRL's?
    thanks
    Nov 06 2009
    Quote Originally Posted by morski View Post
    thanks
    Well I don't have the front parking lights anymore since I went with the Euro lights so I probably wouldn't have noticed if I hit that code. Pretty well what I've told others with requests is find me a model that can do it for sure so I have some ground work covered. I need an idea of the correct module or what byte it may fall in. Not always helpful but better than me chasing something that can't be done.
    There really is no magic to me finding this stuff it's just the time it takes to test bit by bit. So if anyone has any insight to the request let me know and I'll see what I can find the next time I attack the coding.
    Feb 25 2010
    magimmeMVE
    Usa
    I thought that having euro lights meant that you have the parking lights as i described? Maybe different on the A4 but i thought they were standard on euro cars?
    Nov 06 2009
    Maybe I'm misunderstanding then. When I installed E-Codes I lost my side orange lights so I am not sure what parking light would exisit on the side of the car. Unless it's the mirror.. Not sure. Think we need a new post and try and get the ROW guys in on it.
    Mar 20 2009
    Copenhagen, Denmark
    Parking Lights are the LEDs - just dimmed, and there are no lights on the side.
    Rene Larsen
    Nov 06 2009
    I've never noticed them... Hmm maybe I killed them in coding somewhere.. So Rene, since your here. Can you turn just one side of your parking lights on when you park your car?
    Jun 12 2009
    Audi A6
    Norway
    So Fogs lights on with High Beams = LEDs plus Fogs on? Because it doesnt say DRLS on via LED it says DRLS active etc. So you would need to run byte 2 right?
    Mar 20 2009
    Copenhagen, Denmark
    Yes... When the light switch is on "Parking Light" it is working
    Rene Larsen
    Nov 06 2009
    So you are you saying that one side of the parking lights stays on when the car is turned off? And you choose the side the lights work on with the turn signal stalk?
    Thats what was rumoured happens anyways.
    Mar 20 2009
    Copenhagen, Denmark
    Yes...
    Rene Larsen
    Nov 06 2009
    Yes...
    Cool, should be able to figure it out. Thanks again. Your coding will come in handy for this one.
    Feb 25 2010
    magimmeMVE
    Usa
    These are the ones im referring too...
    Nov 06 2009
    Are those white lights? Just noticed your in the UK.. So do you have this feature then? The parking one I mean with having them say on one side when you park?
    Feb 25 2010
    magimmeMVE
    Usa
    These lights are what 'I' we call the parking lights ie stay on one one side when we park on narrow roads. They are originally installed with W5W wedge bulbsbut the pic shows a led bulb.
    Thses are fitted on the A5/S5's as per the above pic but the feature of having one side on is on a big majority of cars here inc the A4's
    Nov 06 2009
    But you have this option correct? You were just asking if we had it here as well?
    Feb 25 2010
    magimmeMVE
    Usa
    Yes we have it here (UK) and have this standard on mine, do you have it there ( with the euro lights)?
    Nov 06 2009
    No Not active on mine. Pretty sure I have those bulbs though but they are orange. Could you send me a copy of your long coding for module 9? I have one already from a ROW car and with yours it may help narrow down the spot that it's turned on.
    Feb 25 2010
    magimmeMVE
    Usa
    Yep will do tomorrow. i hope your not sat in the car right now waiting to try this? lol
    Nov 06 2009
    Ummm nooo.. I'mm ummm in my living room.. Yeah thats it...
    Senior Member Three Rings MOLDOVANOS's Avatar
    Aug 10 2009
    michigan
    I wonder if this mod will work on b6...
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    I wonder if the Left Fog Light On will switch to the other side with 'Headlight Converter' ON/OFF in the Car Menu.
    Ryan - flickr
    Mar 20 2009
    Copenhagen, Denmark
    It would be nice is the car type in question was mentioned
    After looking at your profile deep down - I can see that you are driving a S5, but it would still be nice if it was mentioned more clearly.
    That is why I answered that it is the LEDs that is been used - the same as the DRLs.
    This is the A4 (B8) part of the forum, and here we have to expect that it is about the A4 - until different proven.
    Rene Larsen
    Nov 06 2009
    OK so what I found when looking into the programing tonight. I have not figured out how the Euro parking system works. I used rlarsens coding but could not make the parking feature work where you turn the car off and only one side of the parking lights stay on.
    Morski this answers your question about getting them on as DRL's....
    The lights circled in the picture were not turned on with my car. Even with Byte 2 bit 6 enabled. So a searching I went. I found that in order to turn the turn signals into parking lights you have to enable Byte 10 bit 0. Then you have front turn signals as parking lights and you can enable and disable them as DRL's (which is Byte 2 bit 6).
    There is no coding information on Byte 10 so it took a bit of guessing. I noticed on your coding Rene your Byte 10 was set to 00 which means those lights shouldn't be on even though you have Byte 2 bit 6 enabled. If they do work it maybe a clue to the ROW parking light feature that I haven't been able to enable yet.
    Boy I'm learning more about module 9 than I ever wanted to know. I may need adaptation coding to figure this one out.
    Question for you Morski, what bulbs did you use to swap out the orange turn signal lights or does the S5 come with them white (LED)?
