Results 1 to 11 of 11
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    How much does the 2.7T engine weigh?
    I need to ship out my spare 2.7t engine. It does not have turbos on it and has everything from the fuel injectors down. I need an approximate weight to be able to get a shipping quote. I searched but could not find anything. Any help is appreciated.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Veteran Member Three Rings belittle's Avatar
    Oct 01 2008
    Vail, AZ
    Around 485 lbs for the longblock.
    Established Member Two Rings jettin123's Avatar
    Feb 03 2009
    Richmond, VA
    I thought I remembered reading somewhere that is was around 425 with the turbos. . .?
    Jan 11 2007
    Salt Lake City, Utah
    belittle would know better than I, but from the forklift scale at yellowfreight, mine was ~410lbs longblock with turbos, inlets, and on a weak pallet. But supposedly they reweighed it at a later station and it was more, around 500lbs? I'm not sure which scale was off.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    I weighed mine with turbos on an industrial scale, came in at 420 without pallet
    I don't think I care anymore
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I would get your quote based on 500lbs that way you wont get any surprises when it comes
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Account Terminated Three Rings pzp107's Avatar
    Dec 02 2007
    State College pa
    The full motor complete weights 489 pounds with a pallet. Shipped 2 already. probably subtract 30 pounds for the turbos.
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    Anyone know the approximate weight of the transmission?
    Figured to ask here since the 2 parts relate, and can't find that info anywhere else. Would be good info to add to the Wiki once found out.
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Dec 06 2007
    Calgary, AB, Canada
    I'd say ~150 lbs.
    Feb 15 2008
    Sacramento, CA
    Thanks Jerbel.
