Originally Posted by
storm4200
i doubt you have to remove the entire headlight, but then again, it IS an audi...lol. An in-line load resister is very simple. all you would have to do is splice it in line with the power wire that leads to the turn signal. The 'fast flash' happens when you have an all halogen flasher system, and then add LEDs. The LEDs dont draw enough current, and tricks the car into thinking that a bulb is out, thus the fast flash. Im not sure if the A4 has load resisters on all of the other LED turn signals, or if its all done by computer. someone figure this out damn it. lol
Well gonna take it out anyways because in case the flasher was caused by reasons other than load resistor not in place, i will have to buy that electronic LED flasher, and needed to know the type, etc, etc, etc.
