Quote Originally Posted by xdeymos View Post
The gray cables of the adapter kufatec, they are placed of the following form:
1. Net of on board (under the steering wheel) conector brown color of 17 poles to the pin 9 2. Net of on board (under the steering wheel) conector red color of 17 poles to the pin 3
Go into 09 Central Electronics
Click on Coding-07
Select Long Coding Helper
1) Change the first byte to 26 (Xenons will turn on properly after this)
2) Check Byte 02 Bit 4 (LED strip as DRL)
3) Change byte 14 and 15 to 5D (For the hi-beam to work)
ONLY, this conversion works if the net of I approach, is the version ended in "D" For example, in this photo the tests(proofs) have been realized by the net of I approach ended in 063 "A", since IT IS NOT COMPATIBLE, the long light does not work. And have fis error.
Only works 063 "D" revision, and no have fis errors
http://img121.imageshack.us/img121/7330/a55h.jpg
http://img266.imageshack.us/img266/7...1257456192.jpg
I hope that it you is of help, a greeting from españa
Greetings Espania. I've been there many times. My mother is from San Lucar de Baramedos. I love that country, and the food.
