Page 28 of 35 FirstFirst ... 182627282930 ... LastLast
Results 1,081 to 1,120 of 1389
  1. #1081
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    For the DRL errors on DIS, on my B8 I resolved that problem by changing the DRL brightness with VCDS to '30'. It may be different on the facelift models.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
  2. #1082
    Dec 13 2013
    Audi A1 sline tdi, Audi Q3 SE Tdi
    Newport
    thanx for the reply booost, thing is the error is saying my side lights not working and they are not lol. so people who have changed byte 00 from 69 to 23 rather then 26 are they having the same problem ? what i might do is have a look at what pin on the car loom is the side lights and see what pin they are on the new lights and see if the kufatec adaptors have anything in those pins, when we ordered the adaptors were were told that the b7 and b8 adaptors are the same is this true?
  3. #1083
    Senior Member Three Rings PKaudi's Avatar
    Aug 21 2013
    Canada/ON/Oakville
    Quote Originally Posted by A6tyy View Post
    [IMG][/IMG]
    You fit a 8.5 headlights to a 8...?
    I thought that wasn't possible.. :S
    2010 A4 Premium Ibis
    2007 Civic LX Teffeta White - Sold
  4. #1084
    Dec 13 2013
    Newport
    Quote Originally Posted by PKaudi View Post
    its def possbile lol was a few things i had to change which i didnt think i would, but its mainly headlights and headlight supports, wings (yes you have to as the new wings were about 1-2 cm longer which really wound me up) and bonnet. to finish it off need to get the cover that cover over the grill/slam panel. ummm then there was things like the wings supports and a few other plastic things. took me 8 months to get all the bits most of them i bought off ebay so the cost wasnt great, people used to say would cost too much but i didnt think so.
  5. #1085
    Dec 13 2013
    Newport
    just been looking at the website (kufatec)
    and the part numbers listed as follows:-
    33872 = B7
    40485 = B8
    are they really the same lol ?
  6. #1086
    Aug 27 2014
    Houston, TX
    Can someone direct me what kind of wire I need to get to route to the firewall ? The wires on my adapter are trimmed already ...
  7. #1087
    Oct 21 2012
    Earth...
    Quote Originally Posted by longvo55 View Post
    it should be separated wire, which is coming out from new xenon plug pin11 if im correct.
  8. #1088
    Aug 27 2014
    Houston, TX
    Quote Originally Posted by Gunnark100 View Post
    Thanks for the input, I know the wire, just mine is trimmed down so short. I don't know what kind of wire to get to extend it. Not sure if Kufatec can provide me a replacement for the single wire only
  9. #1089
    Aug 21 2013
    Canada/ON/Oakville
    Why are they short? Mine were plenty long that I had to zip tie the remaining and tuck it in somewhere.
    You need to call the vendor.
  10. #1090
    Aug 27 2014
    Houston, TX
    DIY Halogen to Bixenon- Conversion Complete.
    Previous owner took the short cut and trim it off to remove for sale ...
    2011 Audi A4 Black on White:
    Gloss Dipped 17 inch 7 spokes OEM | Gloss Dipped grille and splitter | 15% all around | VCDS | Matching Foglight & License Plate |
  11. #1091
    Jun 14 2009
    GA
    Quote Originally Posted by greg_617 View Post
    Finally got the conversion done and am curious if I've got a problem or if I'm just overly worried. When I first turn on my new xenons I get a quick bright flash that's a little red and then they quickly settle in to steady light. I've done the coding and I don't have any flickering and the lights stayed on for an hour drive with no problems. Is this normal?
    Quick bright flash, faint pinkish hue? Yep. Normal. Bugs me, too -- but it is what it is.
    2018 IA6 3.0T Sport | Glacier White Metallic | Black Optics | Carbon Atlas | XPEL PPF | Gyeon Quartz
    Gone, but not forgotten:
    2014 A6 P+ Quattro, Quartz Grey Metallic
    2010 A4 P- 2.0T Quattro 6MT, Quartz Grey Metallic
    2007 A4 S line 2.0T 6MT, Phantom Black Pearl
  12. #1092
    Aug 21 2013
    Canada/ON/Oakville
    You probably shouldn't have bought it in that case but I guess it's too late.
    See if you can extend it by hard wiring it with similar diameter of electrical wires, just make sure to tape it well.
  13. #1093
    Aug 27 2014
    Houston, TX
    I got a quote from a shop to do the wiring for $250 here in Houston. I don't think it justifies . I can get new adapters for $80 alternatively. I'll probably stick with low beam for now..
  14. #1094
    Aug 21 2013
    Canada/ON/Oakville
    $250 is a robbery.
    Yes, do get a new kufatec wire and diy...
    Even if you get the wiring fixed, you still have to wire it yourself anyways.
  15. #1095
    Oct 23 2014
    Mississippi
    Hey guys! Just chiming in. I recently purchased everything needed to do the conversion (been religiously on Ebay for the the past 3 weeks to find the best deals possible). Hopefully I won't have a hard time installing everything; especially never having experience in coding. I also wanted to thank everyone in advance for all the help and useful information.
    2010 Premium Phantom Black A4 with Sport Package Suspension and Wheels
  16. #1096
    Jul 17 2008
    Quote Originally Posted by domamei View Post
    Nice man, good luck. I was able to swap everything over with the exception of the high beam wire, in about an hour.
  17. #1097
    Aug 21 2013
    Canada/ON/Oakville
    Quote Originally Posted by booost View Post
    It's possible to do it in an hour but if you have never done it before, set aside a little more than an hour... my conversion took 3~4 hours...
  18. #1098
    Oct 23 2014
    Mississippi
    Thanks guys! I'll make sure to set aside 4 hours to do it. I've been doing some research on installing the headlight adapters. Whats the best way to run the high beam wires into the firewall and pinning it into the oem harnesses. I know this process takes the longest. I'll be doing this all by myself and is semi-mechanically inclined. I searched on youtube an found one video but heard people said it was terrible technique. Any pointers on that? please pardon my "newbieness" lol
  19. #1099
    Oct 21 2012
    Earth...
    I did more-less by the plan AsuDaniel(big thanks) - not hard, i had to change module as well - it was hardest part(not much space there and double check to pin new wires to the correct place). Coding my favorite part(nice, short and warm:)). Finaly found second new headlight - first- led color did not match. Take your time, especialy working under dash:)
  20. #1100
    Active Member Two Rings kwesi22's Avatar
    Jul 14 2013
    bronx ny
    boss can u call me 6466200115
    joe
  21. #1101
    Nov 23 2014
    Spain
    Hello,
    I have a 2010 audi avant b8 with halogens and I want to retrofit to bixenon/drl.
    My question is:
    I just only need these parts??
    - oem bixenon/drl headlamps
    - hid xenon kit http://www.ebay.com/itm/AUDI-D3S-OEM...-/250649586004
    - kufatec harness
    Do I have to code anything, or are just plug and play??
    Aug 21 2013
    Canada/ON/Oakville
    Quote Originally Posted by Challenger300 View Post
    Hello,
    My question is:
    - kufatec harness
    There is coding involved..
    So you'll also need:
    - VCDS
    - Laptop
  23. #1103
    Jan 16 2014
    United States
    Just installed Ecodes =) will code when I get back home =)
  24. #1104
    Oct 23 2014
    Mississippi
    Guys is this the gromet I'm suppose to feed the kufetec wire through? I think I'm making it harder than it is this the the first time I've worked on this car so bare with me
  25. #1105
    Aug 21 2013
    Canada/ON/Oakville
    It's hidden in the photo but it's the right area I think...
    You have to puncture the diaphragm in order to feed it to the cabin..
  26. #1106
    Nov 23 2014
    Spain
    hi guys, if i mak the upgrade to bixenon, what about the headlamp motor? I mean, do the bixenon headlamp has the same motor connector as the halogen headlamp?
  27. #1107
    Oct 23 2014
    Mississippi
    Ok thanks PKaudi I'll try that
  28. #1108
    Oct 23 2014
    Mississippi
    Damn it was a bitch routing the two wires from the kufatec adapters. Finally got them through. Took me over an hour lol. I ended up using a screw driver to puncture a hole big enough through both layers of firewall gromet from inside the car. Then fed the hanger from the bottom up. Then taped both wires with pins onto the wire hanger with electrical tape really tight. After that I pulled from inside the car and they came through. It took me about 3 tries. Next steps will have to happen tomorrow. Pinning etc...I'm doing this by myself by the way. Thanks again for the help PKaudi
  29. #1109
    Jan 16 2014
    United States
    Wow really took me less than 5 mins I just unscrewed the ecu cover and punctured a small hole on the boot and fed it threw and under the ecu and in the car
  30. #1110
    Oct 23 2014
    Mississippi
    Quote Originally Posted by Tm030512 View Post
    Damn..I wish I would of known of your technique. I went by the original posts' pictures and instructions.
  31. #1111
    Jan 16 2014
    United States
    When I was installing yesterday I was going to try it the way it shows in the beginning of this thread but remember on another thread on how to install my radar system and he said to go threw the ecu and oh man was soo easy
  32. #1112
    Jan 16 2014
    United States
    I have a fault code for my left drl and side marker?? Everything works perfectly...idk why I have a code anyone have this?
  33. #1113
    Jan 16 2014
    United States
  34. #1114
    Jan 03 2013
    Baltimore
    I posted some photos in this thread about the routing. Going through the ECU is the easiest. I used a coat hanger to go through the ECU grommet, pulled the wires through then they went down and into the cabin. Pretty easy. Take a look back through this thread for the photos.
  35. #1115
    Oct 23 2014
    Mississippi
    Quote Originally Posted by elscotto80 View Post
    Thanks man I didn't find all this out until I already ran the wires though the gromet lol. I'm now stuck on which wire to plug where for the highbeams and my lower dash won't come off. I've already taken the 3 bolts off including the one in the fuse area. Everything else works great! LEDs and hids worked after coding
  36. #1116
    Oct 23 2014
    Mississippi
    By the way I have the yellow wires that doesn't tell the numbers I have distinguished which wire goes to what headlight already
  37. #1117
    Jan 16 2014
    United States
    Let me know if you get any fault codes for the lights after u code...I have a left drl and marked code
  38. #1118
    Oct 23 2014
    Mississippi
    Yea I'm not throughly finished. I've coded the had 7 fault codes but I had the black under dash unplugged and still trying to get the lower dash off. Any suggestions?
  39. #1119
    Jan 03 2013
    Baltimore
    It doesn't matter. The car cant differentiate between the left and right. It simply moves the shutter in each light. All of this info is in this thread!
  40. #1120
    Jan 16 2014
    United States
    The lower dash comes out with 3 screws two under and the one on the side..open the fuse panel on the left..
