Page 9 of 31 FirstFirst ... 789101119 ... LastLast
Results 321 to 360 of 1389
Hybrid View
    May 31 2010
    Kansas City, MO USA
    very new here, so sorry for the n00b question... would it be possible to install these headlights into a different platform, like the C6?
    I'm about to purchase an A6, and I really like the look of the newer xenon HID's, but imo the A4's version are 1000x better looking than the A6's. so was just curious if it's at all possible.
    Veteran Member Three Rings ASU Daniel's Avatar
    Oct 03 2009
    2009 A4 2.0T
    Naples FL
    i doubt it
    Senior Member Three Rings a4_bob's Avatar
    Mar 13 2010
    Atlanta/GA
    So I just did my halogen -> xenon conversion and am somewhat pissed to find that the seller had sent RHD headlamps. They were ecodes advertised within the US, as upgrades for US cars. Anyway, in addition to the beam patterns being wrong I'm also getting a "Bulb Failure" message in my DIS every time I turn on the low beams. vcds scan does not report any faults.
    1) is it possible to "switch" these to LHD (i read on some other non-audi sites that some xenon headlamps could change projection pattern with a physical switch)?
    2) is the bulb failure message coming from the LHD/RHD mismatch? or is something else likely wrong?
    A little background, I did the prescribed codings and the lights do work, other than the above issues. I have not yet hooked up the high beam wires.
    Anyway, thanks to everyone here for all the great info & support!
    Sep 07 2008
    Sydney, Australia
    Quote Originally Posted by a4_bob View Post
    Would you want to sell your RHD lights? I'm from Australia and I'll be interested if you wanted to sell.
    Sep 21 2005
    2010 B8 A4 Qt
    Hey Bob,
    I'm sorry about the trouble.
    I can take care of the message on DIS for you by sending you a control module unit but for RHD vs. LHD, I guess the only solution is sending you a new set of headlamps.
    Imashy14u, you've got PM.
    current: 2010 Audi A4 2.0T - Blesk 5000K D3S bulbs, LED interiors, Blesk 3000K HID fogs, Blesk LED festoon on license plates, carbon fiber wrapped roof, + more upgrades may be on the way upon approval from the boss (wify)
    past: 99' Audi A4 2.8, 03' B6 A4, 2009 IS250, ACURA TL-S, 240SX, + 13 more...
    Jun 05 2010
    Kentucky
    HI guys,
    I have completed the installation of the headlights but my VAG com codes are wrong. My two large Xenons work but my LEDs dont work, and neither do my high beams. However, my turn signals work. Please help with me with the Vag Com Codes needed to fix all of these problems. I have been working on collecting everything for the last 7 months.. I beg you, help complete my project with the Vag codes.
    Oct 27 2009
    Miami, FL | Boone, NC
    Quote Originally Posted by sjeelani View Post
    HI guys,
    Ok - I must have posted this about 4 times in this thread, but whatever...
    After conversion, you must change:
    Module [09-Cent. Elect.]
    Byte 0: Change to 26 (for xenon lights)
    Byte 2: Change to 10 (enable LED DRLs)
    Byte 14: Change to 1D (bi-xenon highbeams)
    Byte 15: Change to 0D (bi-xenon highbeams)
    I hope you get it worked out...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Jun 05 2010
    Kentucky
    Does this correct all of the problems? I heard many users have problems with the high beams.. So for sure this should is tested and has worked right? I only ask because the techs at Audi said something was wrong from the VAG com codes I got from Kufatex with the adapter.
    Veteran Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    Wow, maybe we should have started this thread by saying " DO NOT TRY THIS UNLESS YOU ARE CONFIDENT IN YOUR ABILITIES TO WORK ON CARS"!!!
    Danger Danger Will Robinson.
    Seriously though, the VAG Com is a tool. Make sure you write down or do an Autoscan BEFORE doing any changes so you can get back to default. If you change specific BYTE coding, go slow and test a few before making lots of changes!!!!
    SJ: Post your coding and hardware and maybe we can help you. Tell us what you did. Did you land the trigger wire for High beams? Did you put in both lamp ballast & LED ballasts???? Help us to help you.
    Go slow and write clearly what you did on here. It's OK, you can reverse anything on here. Trust me. I have been where you are now, but it can all be reversed if something doesnt work.
    Mar 20 2004
    90' 964, 95' F355, 63' Coupe DeVille
    GV, CO
    Getting this error. Any ideas?
    Monday,14,June,2010,16:57:51:17168
    VCDS Version: Release 908.2
    Address 09: Cent. Elect. Labels: 8K0-907-063.clb
    Control Module Part Number: 8K0 907 063 N HW: 8K0 907 063 N
    Component and/or Version: BCM1 1.0 H25 0380
    Software Coding: 260010B1463C00010000080000001D0D4F1446080000002100 0000
    Work Shop Code: WSC 06335 000 00000
    1 Fault Found:
    01771 - Control Module for Headlight Range (J431)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 18
    Mileage: 8380 km
    Time Indication: 0
    Date: 2010.06.14
    Time: 16:54:00
    Sep 06 2009
    TX
    First grab the new version of the software v 10.3 beta... It should auto update you, if not manually grab at their site. Then clear it and see if it returns...
    Oct 27 2009
    Quote Originally Posted by Todeshandler View Post
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 18
    Mileage: 8380 km
    Time Indication: 0
    Date: 2010.06.14
    Time: 16:54:00
    I'm guessing that you enabled auto-leveling somewhere in the coding (did you change out the whole long coding, or did you change it bit by bit)
    We do not have the xenon range-control module hence the error...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Established Member Two Rings DB33's Avatar
    Mar 25 2010
    12 A4 Avant Prestige S-Line
    Scranton,PA
    I have also successfully done a Halogen to Bi-Xenon conversion (e codes). Few pics.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Lots of new converts. Looks good guys.
    Welcome to the club.
    -cW
    2023 X3 M40i Alpine White
    Jun 22 2010
    Sydney,Australia
    Looks great guys :) Inearly bought a non xenon A4 B8 but in the end I bought one that came with it in meteor grey. Picking it up tomorrow morning! Can't wait. The only other optiion is sunroof...
    Sep 07 2008
    Sydney, Australia
    Hi Guys,
    I've installed the xenon lights into a friend of mine's A4. The left light is a normal housing, while the right one has the AFS option on it and has the AFS controller (AFS = lights move left and right following the direction the steering wheel is turned).
    Now I've recoded the ECU accordingly and is the same as the coding I have for my halogen to xenon retrofitted car. But with my friends car, he gets a warning message on his DIS saying "Right side light / running light". Now given that the AFS is on the right light, I assume the error relates to that.
    Would anyone know what type of coding I should do in order to get rid of this error message?
    Here is a pic of the message
    Sep 07 2008
    Sydney, Australia
    Can no one help????
    Sep 07 2008
    Sydney, Australia
    Quote Originally Posted by imashy14u View Post
    Hi Guys,
    Still haven't sorted this out yet. Can anyone here help me on this or point me in the right direction???
    May 16 2010
    Perth, Western Australia
    imashy you have PM
    Jul 07 2013
    Ukraine
    Hi Guys,
    i have same error . can you help me please?
    Senior Member Three Rings PKaudi's Avatar
    Aug 21 2013
    Canada/ON/Oakville
    Hi Guys,
    So close yet so far, I got everything working including the high beams, but I'm getting this error as above pic.
    I didn't see an answer to this in the thread...
    I need your help experts!!!
    EDIT: Alright it is fixed now - I had to tone down the DRL brightness to 30%. Anything higher than that will give bulb out error.
    2010 A4 Premium Ibis
    2007 Civic LX Teffeta White - Sold
    Feb 06 2006
    munster, IN
    does this mod affect the amber indicator on the mirrors if we do this mod?
    Mar 13 2010
    Atlanta/GA
    Quote Originally Posted by mo0620 View Post
    No
    2011 BMW E92 M3 Competition
    Previous: 2011 B8 A4 Loaded | Meteor Gray, APR Stage 2
    Previous: 2009 B8 A4 Stripper | DeepSeaBlue, APR Stage1
    Feb 06 2006
    munster, IN
    No
    oh ok, because some people were saying the amber side markers stopped working, i thought they were referring to the side markers on the mirror.
    Oct 27 2009
    the amber side markers are the yellow reflector thingies in the side of the US-spec headlights...
    They are meant to light up at night, however, mine do not. I don't really care (I was going to turn them off anyway) I just wanted to throw it out there...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    May 28 2010
    Austin, TX
    Hello all,
    I just did attempted this install today, but I'm having a problem at the last step.
    The new housings are hooked up (including the wires for the high beams), and when I turn on the lights
    they both come on, but the right light flashes on/off 2 times and then just turns off and stays off. And then
    I get an error message that there is a light malfunction. Also, when I trigger the high beams, the LED's stutter
    flash. The left light stays on. Does anyone have any ideas?
    Thanks
    Oct 27 2009
    Quote Originally Posted by RedG3 View Post
    Hello all,
    Thanks
    It sounds like you haven't correctly changed your coding...
    I must have typed out (on this thread) what need to be changed at least 5 times, so I am not going to retype it here...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    May 28 2010
    Austin, TX
    Sorry about that, yeah I misinterpreted the DIY which mentions testing out the lights before securing them, which was before
    the vagcom part of the DIY.
    2009 A4 2.0T Quattro Tiptronic Sedan: Brilliant Black
    Mods: Halogen -> Bixenon Retrofit | Matte Black Filler Plate | Vag'd | OEM Chrome Exhaust Tips | Debadged
    Oct 27 2009
    ah ok - not correctly coding for them will create the results you experienced...
    Did you find the correct codes and get it worked out?
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    May 28 2010
    Austin, TX
    Yes, after correcting the coding it worked perfectly! :) I will post pics later today, I didn't have a camera with me.
    Thanks again for the help, and sorry about that, I felt so noob when it turned out to just be the coding. I was freaking out
    that I had crossed some wiring or something when only one of the lights stayed on and the high beams made
    the LEDs stutter.
    Oct 27 2009
    the LEDs stutter.
    Don't worry about it lol - that is what the forums are for...
    It is interesting though.. When I swapped out my headlights, I ran them for a couple mins to see what happens w/o the coding... I experienced the same thing as you - both light comes on, passenger light flickers, passenger light goes out... Did you noticed the red flash when you turned on the headlights without the coding?
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    May 28 2010
    Austin, TX
    Hm no I don't remember a red flash, was the flash in the LEDs?
    Oct 27 2009
    no - It's just when I turned on the xenon bulbs w/o the coding set, they flashed a really bright red color for a second...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    May 28 2010
    Austin, TX
    Nah I didn't see that, I think that would have freaked the shit out of me lol. Maybe an odd ballast discharge?
    May 28 2010
    Austin, TX
    Pics as promised...
    But first, I'd like to give a BIG thanks to Jens (lowestA4) and ChrisMT79 for getting me all the parts I needed at a great price. They were super helpful during the whole process and I received the parts very quickly, and in great condition...the packaging was top notch! I would also like to thank Bunn for being a huge help during the install and providing the vagcom cable (and also shout out to his neighbor for some very helpful tools!). And last but certainly not least, thanks to everyone who contributed to this DIY, especially ASU Daniel and NPuter!
    And without further adieu... :)
    Before:
    After:
    Once again, thanks to everyone I mentioned, I LOVE my car's new look!! :D
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Guys, does anyone know what the coding is for an A5 premium headlight to A5 Premium plus Bixenon w/LED?
    Helping out someone that wants to do the conversion.
    -cW
    Oct 27 2009
    -cW
    I would not be surprised if it was the same coding as the A4
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    I'm guessing there should be some instructions with the kufatec adapter.
    -cW
    Oct 27 2009
    Awesome!
    Are your high-beams working?
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    May 28 2010
    Austin, TX
    Awesome!
    Yes, I used the code in the original post (26001031063C00010000080000001D0D0F145208000000010 00000).
    Getting those wires through the firewall and connecting them to the clips was one of the longest parts of the install lol.
