Page 1 of 3 123 LastLast
Results 1 to 40 of 113
    Active Member One Ring 4ringcircus's Avatar
    Aug 01 2009
    2005.5 A4 Quatro 2.0T
    minneapolis
    Theory on combating carbon buildup:
    I've read all the threads on the carbon buildup problem and there is little to no consensus on how to preempt the initial build up. From time to time, someone mentions running the engine hot to burn off the carbon, but this theory hasn't had much debate: If it is true that hotter engines burn off the carbon, a possible solution might be chipping, resulting in more heat from the turbo and quicker burning off of carbon.
    Most 2.0T's I've read about have experienced carbon problems between 25K and 75K. I bought my 5.5 2.0T with 90K; the previous owner drove 75 high way miles per day so I know that engine was good and hot every time he turned it on. I've had no carbon problems. Conversely, many 3.2's experience carbon problems earlier than the 2.0T's, at about 5K to 20K. These engines are direct injection, but not turbo, so they likely take more time to heat up as the intakes are not blasted by hot air off the turbo.
    So, would a stage 1 or 2 APR upgrage for example, help heat up our intakes faster, resulting in carbon being burned off and delaying carbon buildup to the possible equivalent of a non-direct injection engine?
    Veteran Member Four Rings vortexjunkie's Avatar
    Sep 12 2009
    Manteca/Lathrop
    Re: Theory on combating carbon buildup:
    I think you have come up with a logical theory
    Veteran Member Four Rings nramsey's Avatar
    Dec 09 2004
    Interesting theory, but I doubt the intake air just from the turbo would be hot enough to burn off the carbon. Seems like you'd need to to be well above 300 degrees f, which even the stock intercoolers probably prevent.
    - Nathan
    http://www.flickr.com/photos/nramsey
    2008 A4 2.0T Quattro Avant - Dolphin Gray
    Eibach Pro-Kit - Koni FSD - Rotiform MIAs
    Oct 12 2009
    a meth kit would do the trick. it should burn off any carbon build up.
    2015 Audi A3 TDI
    1971 VW Squareback
    Veteran Member Three Rings Nikoman's Avatar
    Feb 04 2008
    2015 Jeep Grand Cherokee
    Chicago, IL
    What about seafoam through the air intake temp sensor hole? I've done that 3 times along with BG induction cleaning service once over the last 6 months. I'm at 47k. Am I wasting my time with seafoam? Nope. I use a whole bottle each time and do it just like I did my GTI in the past. It takes me less then 10 minutes for the whole process. I make sure she sucks the whole thing fast rather than taking time like some people like :) This way there is much more liquid depsoted in the intake for the soaking process.
    Seafoam $6x3 = $18
    rubber hose = $3
    misc stuff = $15
    BG induction service at Audi dealer = $160 (with Xmas gift certificate they sent me)
    Total for 6 months of carbon build up maintenance = ~$200
    My car idles perfectly and there is no carbon build up. I know this, saw the valves with a borescope. I would rather not have to spend my valuable time doing this maintenance though....
    2017 A4 Premium Plus Mythos Black + Sport + Cold Weather
    Jan 13 2009
    Jaguar XK, Galant VR4, Mitsubishi Starion, GMC Beau James, Yamaha 650 Turbo
    Pacific Northwest, USA
    OP...Sorry, cant support the theory and think that heating your motor outside normal specs is a recipe for damage. In fact, I think you will find just to opposite. Carbon LOVES high heat, and can survive intact it in environments ranging in the thousands of degrees. It is considered one of the highest temp elements in existence. Adding a few extra degrees to your engine will not faze it in the least.
    Nikoman is probably more on target, although I remain on the fence with the Seafoam product.
    I'll offer a little crude knowledge, more from a common sense angle, and let you science whiz's debate how any of it relates to Audi's engine design. This has probably been discussed among similar threads here before.
    Carbon forms on the valve for a couple reasons. Impurities of the combustion process is the primary culprit, (which has existed in internal combustion engines since the beginning), and high temperatures of the valve easily allow the carbon to deposit itself on the metal surface. A colder valve surface rejects carbon deposits as is evident by most "normal" engine tear-downs (Intakes are always cleaner than exhaust as they run cooler due to incoming air/fuel mix, whereas the exhaust valve site in the heat at all times.) Valve overlap is another contributing factor. This basically means the combustion processes is still in progress when both intake and exhaust valves leave their seats and begin the exhaust/intake stroke of the 4 cycle process. With the burn still in progress, the intakes expose themselves and allow carbon residue to adhere.
    In the past, intakes were very easy to keep clean, as the airstream passing by them entering the cylinder carried both air and fuel. This mixture often kept the carbon on the intake valve in a much softer state, and the addition of cleaners would even help break it down further.
    Our Audi's eliminated both the added cooling of an air/fuel mix, and the softening of the carbon deposits thanks to the direct cylinder injection system. This is why adding a intake cleaner to our fuel system no longer works for our engine design. Softening and cleaning of the carbon must now be done as Nikoman points out, by injecting a cleaner into the airstream that flows past the valve and valve stem.
    Of some interest may be an "old school" process we used in carburated engines way back when... We often ran an engine till it got up to temp, then used a squirt bottle with ice water to pump shots of cold into the intake. Quite often the thermal shock would shatter carbon off the valve surface and expel them out the exhaust (puffs of black smoke). Recall that this was "pre catalytic converter" days so I would have reservations trying it on a modern motor less I plug a cat or something. A cleaner may clear the deposits in a slower/safer manor.
    My 2 cents for today
    Hope some of you find it of interest.
    Vince
    Current = 2007 Jaguar XK
    RIP Brilliant Red 2005.5 A4Q 2.0T, TIP. Premium, Lighting, Shade, Cold weather, and Audio packages.
    Mods: Shift Paddles added, Enkie PF01, Eibach Pro, Koni FSD, H&R 20mm Sway, USP Stainless brake lines, Tint, APR stage 1, K&N, Stern Adjustables.
    MP3 is the McDonnalds equivalent of music. Both have their place, but neither cater to quality.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    if you think about how the carbon buildup is occurring (crap from the pcv) then it would make sense that the higher intake temps burn off that crap before it gets a chance to turn into carbon deposits?? Just a guess bc i have personally seen the same correlation with carbon buildup from N/A vs FI engines
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Established Member Two Rings RightonRed's Avatar
    Aug 14 2008
    Nothern Virginia
    Agree with RTV on this one, valve overlap and lack of fuel in the intake makes it the prefect breeding ground for carbon crystalization. Heat will not remove the carbon buildup... That's the reason that cabon is used in high temp applications ie: Carbon ceramic brake discs and space shuttle tiles. Note that this issue hasn't shown up until the FSI engine was introduced (with the two major changes being direct fuel injection and valve overlap), don't get me wrong I love my car....
    A better solution might be a dumpable catch can for the PCV system like the BSH kit and a secondary fuel injection system, like the systems used in high power autos. Having a secondary spraying fuel into the intake would help clean the valves on a regular basis, and reduce the duty cycle on the primary injectors, but i have no clue on how to program that into the ecu so that it can manage added fuel into the system. Also you would likely loose the benefit of the FSI engine with regards to mileage.
    One of the questions I posed last year was what about a Nitrous wet kit, key in on the wet part... I do not know if this would add enough fuel into the intake to clean/maintain the valves but it might be a start... Also see the new VAST kit and note the secondary injector system that was mentioned...
    http://www.audizine.com/forum/showthread.php?t=338492
    Conversations like this are the way these problems get solved. Keep up the ideas and maybe one of these vendors can find solution. I know several are attempting this as we speak...
    Red
    Tango Red 2018 RS3 - Tech, Dynamic, RS, Driver Assistance, Black Optics
    Brilliant Red 2008 A4 2.0TQ Tip S-line KOR Turbo (sold)
    Aug 01 2009
    minneapolis
    I agree that heat won't do anything once the carbon is caked on the valves. I am specifically interested in knowing if heat could 'delay' or mitigate the speed at which it builds. Once it is hardened, yes it is like a carbon ceramic brake. Once our engines get to that point, we all will have spend a fortune to tear down the engine and fix.
    I'm more interested in preemption. If the impurities come from the PVC, they are in a liquid emulsion; if the engine is cold, they sit and solidify. But if it is hot, they burn off. If my assumption is correct, one could observe more carbon problems on cars used for short commutes. And correspondingly, high mileage commute cars like mine could hit 100K without any carbon problems.
    Am I still off the mark? Anyone with carbon problems care to state how many miles on average you drive per day, and when you first experienced carbon problems? I'm at 100K, 75miles per day, and haven't had a problem yet.
    Aug 01 2009
    minneapolis
    May 26 2009
    VA
    Nothing substantive to add, but I enjoyed reading the posts so far. Thanks. I Hope one of you smart guys can solve this problem.
    Senior Member Three Rings philaboy's Avatar
    Jul 24 2007
    (Black-on-Black) B6 04' 6mt with sport package | Apr tuned stage 1 | Debadged (Sold) (Lava Grey) A3
    Phila, Pa
    I guess fuel cleaner does nothing? I still use it every 4,000 miles in both cars. In my wifes 1.8T you can feel it after the tank in done. I think it works on the 2.0T, but it hard to tell! My Question to you guys is this- can it hurt the system?
    (Black-on Black) Q7 12'
    (Black-on-Black) B7 07' Avant 6mt every option ex- S-Line, But got MMI | Debadged | Euro Plate Holder | Oem Blue Tooth | more to come
    Established Member Two Rings doctorheine's Avatar
    Mar 26 2009
    B7 a4 3.2 Q 6speed :-)
    plano, tx
    Quote Originally Posted by 4ringcircus View Post
    I always noticed that my 2.0t tiguan reaches operational temperature 3x faster. My 3.2 "3.1" a4 takes along time to reach operational temp. Im pretty sure I have horrible carbon build up in my 3.2 right now, the ecu just went out and im waiting on audi to get my new one in. The power is not there anymore especially in the high rpms. It almost feels like it plateau's after 4800rpms. my 3.2 has just barely 23 thousand miles. but atleast I dont blow CBV's as much anymore
    Mar 26 2009
    plano, tx
    like the old saying.... If you let it sit it goes to sh*t
    Veteran Member Four Rings vbrad26's Avatar
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    redline once a day...nothing cleans things out like WOT
    /thread lol
    Junior Member Two Rings Boosted6Speed's Avatar
    Oct 12 2020
    2016 BTF Formula 1600
    MI
    Has anyone come up with a fix yet. What about the weld in tip that makes vacuum with the exhaust? I'm really tired of the epa dictating that we run waste through our engines.
    Account Terminated Four Rings
    Oct 15 2013
    Quote Originally Posted by colt45 View Post
    Agreed 100%. Even just using water without meth.
    Forced air helps to overcome the negative effects of carbon buildup too. So I'd never consider a NA DI unless it's hybrid port and DI.
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Quote Originally Posted by Boosted6Speed View Post
    Water methanol will help wash the back of the intake valves. A decent methanol kit costs as much as a walnut blast so it pays for itself over time.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Methanol will not clean it will only slow build up. There is nothing that will stop it on DI. Anyone who has have ever tried cleaning it would know this.
    Sent from my SM-G960U using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    May 20 2017
    New Hampshire
    Yes. Methanol or water will only help wash the valves. There’s no burning going on with meth like that poster from 10 YEARS ago posted. 🤣
    And yes, you can’t really eliminate carbon build up on these cars, just slow it down because the build up happens from carbon being deposited on the valves as they close. There’s no way to burn it.
    I’m explaining it badly so forgive me.
    But I agree with you. You can’t eliminate it. Only slow it down.
    Oct 12 2020
    MI
    So its not all to blame on emissions... Is this why I've seen a few instances of 1.8t swaps in B7s? Maybe a slow release seafoam injection could be fabricated. If we microdose seafoam constantly.....
    May 20 2017
    New Hampshire
    No parts store chemical cleaner works. None.
    Methanol works well because it is spraying the valves as it is running.
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    I did carbon cleaning in 2020 May by removing intake and all. Just for my satisfaction, I ran multiple bottles seaform and liquimoly valve clean to see it had made any difference before cleaning(you know it wont work but I gotta see result my self). after removing the intake, I didnt even see 1% cleaning done by them. It just waste of 50-70$.
    Also, make sure you fully clean intake manifold before reinstalling. I did the hard part of cleaning the valves and intake ports but never cleaned the intake as none of the youtube videos did. I still have intermittent and once in a blue moon cold misfires under 45 temp. Probably caked up carbon inside the intake runners and flap motor is causing this
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    if I can add, catch can wont do shit. I did a full carbon clean and 10k km after I got a injector leak. so I took apart the intake manifold, and valves were dirty af. Not as much like my previous 80 k km valve, but still.
    I have a meth kit, I will see if I have the motivation to look at my valves in 30k km. But technically, when water touch a over 100°C part, it steam, thus clean the metal part.
    But engine need to be hot af, and push the car so the meth kit spray.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by Jeevan View Post
    Well yeah, if you pull the intake to do carbon clean, ya clean everything. Don't do half the job, lol.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Veteran Member Three Rings BecksA3's Avatar
    Dec 20 2019
    2006 A4 Cabriolet 3.0l Quattro, 2100 Ram 1500
    Williamsport, PA USA
    What about the Hot Shot Secret stuff that’s out now?
    It’s supposed to be a in tank cleaner for injectors and carbon deposits.
    And since it’s in the fuel, should get to the heart of the matter.
    I wouldn’t expect it to deep clean years of build up, but maybe keep it clean after a carbon clean?
    '16 A3 Quattro S-line, Black on black, on black: Eurodyne Maestro Suite, DIY 3" intake, GFB DV+, ECS RS Ignition upgrade, and an ever growing wish list.
    "When this baby hits 88mph, you're going to see some serious shit!"
    May 20 2017
    New Hampshire
    Quote Originally Posted by BecksA3 View Post
    I meant what I said
    And being direct injection, being in the fuel means nothing since fuel NEVER passes over the valves. That’s sort of how the DI thing works.
    Dec 20 2019
    Quote Originally Posted by EvolutionArmory View Post
    Duh! Sorry, brain fart.
    I saw a commercial and didn’t do the math.
    May 15 2019
    Bellevue, WA
    As per my common sense, let's say if those cleaners actually work and clean the fuel tank, where would all that crud go? Fuel pump mesh filter, fuel filter wont it clog injectors. Most of them are snake oils
    Jan 21 2018
    frackville, pa US
    Well, it should dissolve it, not just loosen it. So if it actually works, it won't hurt anything. Some injector ckeaners work well, just don't help valve buildup on DI cars, thats all.
    May 15 2019
    Bellevue, WA
    Quote Originally Posted by Jayz691 View Post
    Lol you think all that rust and gum is going to be dissolved(only acids have that capabilities)? Kidding right? Either it's magic or you believe in fairies and pixie dust
    Dec 20 2019
    I’ll try pixie dust if it makes me faster.
    Oct 24 2015
    Perth, WA
    Solvents dissolve solids. If the solvent is correct, the materials should be passed in solution through the combustion chamber or solidify out in the tank.
    My respray thread
    Jan 16 2011
    Earth
    Edited
    Jan 16 2011
    Earth
    Quote Originally Posted by Okedokey View Post
    sorry no it doesn't work like that with carbon deposits.
    May 20 2017
    New Hampshire
    The only way you’re getting rust/gunk out of the tank is to drain the fuel and hand clean it and the only way you’re going to clean carbon out is with a media blast or manual removal with a pick or scraper.
    These are the facts of DI life.
    Fuel additives might help clean your fuel lines or the injectors but all they are is a fuel additive with more detergent. A higher concentrate of detergent. It will not break up large build up. And not only does carbon build up deposit on your valves but the unburnt carbon can also deposit on your injector tips and clog the jets. A cleaner won’t clean this.
    Jan 21 2018
    frackville, pa US
    Wow dude, not rust and gunk, "carbon", lol. Solvents do dissolve carbon, like carbon cleaners. Thought the thread was about carbon buildup?? Also, anything loose in the tank would be screened by the pump screen. Was talking about injectors and maybe any varnishes in the lines. Not chunks of rust..maybe you can put some brakecleaner in it
    May 20 2017
    New Hampshire
    Why doesn’t anyone understand that fuel never hits the valves?
    It’s literally the reason why we have this issue in the first place. Because there’s no fuel washing them...like at all.
    Putting anything in the tank will only be like putting a 5 dollar bill in there. You have no 5 dollar bill anymore and there’s something in your fuel tank that doesn’t belong in there and it won’t clean your carbon. 🤣🤣
    Jan 21 2018
    frackville, pa US
    We do understand, thats why I said injectirs and lines. Think "most" know it can't work for valves, but maybe not, lol.
    Feb 15 2016
    Cambridge,Ontario
    wasn't it Mercedes that resolved it by putting an auxiliary injector back behind the valves that they turn on under certain conditions ? ? I thought i remember reading that somewhere. ? to me thats the only real answer.
    edit : just found this .... worth a spot in this discussion i think.
    https://www.caranddriver.com/news/a1...ect-injection/
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
