Here is a brief list of all mods being installed in this build:
1. PES S/C
2. Snow Performance Water/Meth Injection
3. HKS Camp 2 (ECU data & boost display on RNS-E screen)
4. Kufatec video converter for RNS-E to display HKS Camp 2
5. KMD Tuning Oil Catch Can
6. Ram-Air ducting to stock airbox bottom opening and removal of flap (Not Possible)
7. Carbon Deposit cleaning
8. Custom KMD open-air intake with heat shield
1) PES G4 RS4 Supercharger
- Powder Coated Daytona Grey
- Roots Eaton M90
- PES Tune
- 5 psi
- Intercooled
- Ported for Water/Meth injection to each individual intake port. (will also be useful to insert a bore scope to check valve deposits)
- Water/Meth nozzles
- New Fuel Rails for hood clearance
- Coolant Pump
*MISSING IN PICTURES: Bracket connecting S/C to throttle body, MAF module, Intake manifold flap module (fools ecu to think oem flaps are still there)*
New Fuel Rails:
Water/Meth Ports:
Water/Meth Ports:
2) Snow Performance Meth Kit
- Controller (monitor & control flow, warns if system is malfunctioning)
- Pump
- Using the windshield wiper resevouir as main water/meth container
3) HKS Camp 2
- http://www.hksusa.com/info/?id=3474
- Plugs into OBDII and displays all ECU readings as gauges on RNS-E screen
- Live monitor or record and playback data
- Boost reading
4) Kufatec Video-IN
- Adds Video-IN feature to RNS-E (needed to display HKS Camp 2)
- IMA Multimedia Adapter w/ Control - "Basic-Plus"
- IMA - Harness - Audi RNS-E - "Basic"/"Basic-Plus"
5) KMD Tuning Oil Catch Can
- Eliminate carbon deposits
- No image available, still in the works
6) Ram-Air Ducting To Stock Airbox (Not Possible)
*- After doing research, there is virtually no vacant area to run piping for this setup -*
- Install a scoop from bumper opening
- Run ducting to the bottom opening of stock airbox
- Remove flap at bottom opening
7) Carbon Deposit Cleaning
- It's severe! Currently being cleaned.
8) Custom KMD Intake
- Had to eliminate stock intake airbox to fit oil catch can in appropriate position
- Hopefully improve performance (haha)
PRE-INSTALL BENCHMARKS
1/4 Mile
First time at the drag strip with the RS4. (confirmed: I had carbon deposits at this time and running around 280 whp instead of 325 whp)
Youtube Vid:
Me vs 370z (my best friend who has never launched a RWD at a track)
http://www.youtube.com/watch?v=_tq_e...&feature=email
Dyno Charts
- K&N Air Filter
- Revo Tune
- Milltek Header-back Exhaust
With 800 miles on the odometer:
With 23,000 miles on the odometer:
I'm figuring the best way to compare before and after dyno #'s will be with my first run ever at 800 miles and no carbon. I'll use 320 whp as the base # to compare against the after-install #. I guess the base 1/4 mile time is kind of invalid since I ran underpowered due to carbon deposits.
Stay tuned for updates!
UPDATE! Video Walkthrough Part 1
