I have a Ross-Tech VAG-COM scan tool and I regularly scan my Audis for faults and when I do get a CEL, I make a scan to keep the warranty service techs honest.
Below is the CSV file of my maintenance history for the 2008 A4 B7 3.2 6MT. When I purchased the car, they gave me AudiCare (free scheduled maintenance through 50,000 miles), so the vehicle has always gone back to the dealer for maintenance and oil changes. I pay for the 5000 mile change between the scheduled 10,000 mile interval, again, service done at the dealer.
Between the 25,000 mile service (24,196 miles) in Feb and the latest CEL in July (27,426 miles), the car has been to the track twice (hundreds of miles of 4000RPM-redline runs, 20-40 minutes at a time), has had 3 bottles of Audi G-001-700-03 HD6-C additive through it and only the highest octane fuel I can find (91-93).
There are 23 TopTier gas stations within a 50 mile radius of me and the only convenient ones I've been to have not had any fuel over 89 octane, so I end up using BP 93 octane fuel.
"Date","Mileage","Subsystem","Audi Code","Text","SAE Code","Text"
31-Jan-2008,14,,,"Took Delivery (<dealer> Audi)",,
19-Feb-2008,528,"Address 01: Engine","001796","Clutch Switch (F36): Implausible Signal","P0704 - 008","Implausible Signal - Intermittent"
19-Feb-2008,528,"Address 36: Seat Mem. Drvr","00668","Supply Voltage Terminal 30","06-10","Signal too High - Intermittent"
19-Feb-2008,528,"Address 56: Radio","00857","CD Changer Unit (R41)","004","No Signal/Communication - Intermittent"
11-Mar-2008,1012,"Address 36: Seat Mem. Drvr","00668","Supply Voltage Terminal 30","06-10","Signal too High - Intermittent"
11-Mar-2008,1012,"Address 56: Radio","00857","CD Changer Unit (R41)","004","No Signal/Communication - Intermittent"
10-Apr-2008,1615,"Address 01: Engine","000278","Engine Coolant Temp. Sensor (G62): Implausible Signal","P0116 - 008","Implausible Signal - Intermittent"
10-Apr-2008,1615,"Address 01: Engine","001796","Clutch Switch (F36): Implausible Signal","P0704 - 008","Implausible Signal - Intermittent"
10-Apr-2008,1615,"Address 01: Engine","001089","EVAP Emission Control Sys: Incorrect Flow","P0441 - 008","Implausible Signal - Intermittent"
10-Apr-2008,1615,"Address 36: Seat Mem. Drvr","00668","Supply Voltage Terminal 30","06-10","Signal too High - Intermittent"
10-Apr-2008,1615,"Address 56: Radio","00857","CD Changer Unit (R41)","004","No Signal/Communication - Intermittent"
9-Jun-2008,5654,"Address 36: Seat Mem. Drvr","00668","Supply Voltage Terminal 30","06-10","Signal too High - Intermittent"
9-Jun-2008,5654,"Address 56: Radio","00857","CD Changer Unit (R41)","004","No Signal/Communication - Intermittent"
11-Jun-2008,5716,,,"5000 mile service (<dealer> Audi)",,
28-Jun-2008,6182,,,"no faults found in this scan",,
17-Jan-2009,11588,"Address 36: Seat Mem. Drvr","00668","Supply Voltage Terminal 30","06-10","Signal too High - Intermittent"
15-Mar-2009,12744,"Address 36: Seat Mem. Drvr","00668","Supply Voltage Terminal 30","06-10","Signal too High - Intermittent"
15-Mar-2009,12744,"Address 56: Radio","00532","Supply Voltage B+","001","Upper Limit Exceeded - Intermittent"
15-Mar-2009,12744,"Address 56: Radio","00857","CD Changer Unit (R41)","004","No Signal/Communication - Intermittent"
8-Apr-2009,14650,,,"15,000 mile service (<dealer> Audi)",,
17-Apr-2009,,,,"New OEM 22mm Rear Sway Bar Installed",,
17-May-2009,15627,"Address 08: Auto HVAC","01272","Positioning Motor for Central Flap (V70)","41-10","Blocked or No Voltage - Intermittent"
17-May-2009,15627,"Address 56: Radio","00857","CD Changer Unit (R41)","004","No Signal/Communication - Intermittent"
20-May-2009,15717,,,"New Summer Tires/Wheels/Tire Pressure Sensors installed (<dealer> Audi)",,
21-May-2009,15751,"Address 56: Radio","00857","CD Changer Unit (R41)","004","No Signal/Communication - Intermittent"
21-May-2009,15751,"Address 65: Tire Pressure","01521","Sensor for Tire Pressure","004","No Signal/Communication - MIL ON"
26-May-2009,15966,,,"Correct Tire Pressure Sensors Installed (<dealer> Audi)",,
29-Jul-2009,,,,"Balance & Rotate Tires/Wheels",,
30-Sep-2009,19653,"Address 01: Engine","000772","Cylinder 4: Misfire Detected","P0304 - 007","Short to Ground - Intermittent"
30-Sep-2009,19653,"Address 01: Engine","000774","Cylinder 6: Misfire Detected","P0306 - 007","Short to Ground - Intermittent"
30-Sep-2009,19653,"Address 01: Engine","000768","Random/Multiple Cylinder Misfire Detected","P0300 - 006","Short to Plus - Intermittent"
30-Sep-2009,19653,"Address 01: Engine","001110","EVAP System: Very Small Leak Detected","P0456 - 006","Short to Plus - Intermittent"
30-Sep-2009,19653,"Address 01: Engine","001796","Clutch Switch (F36): Implausible Signal","P0704 - 008","Implausible Signal"
30-Sep-2009,19653,"Address 56: Radio","00857","CD Changer Unit (R41)","004","No Signal/Communication - Intermittent"
30-Sep-2009,19653,"Address 65: Tire Pressure","02214","Tire Pressure Warning","000",
3-Oct-2009,20138,,,"CEL illuminates",,
3-Oct-2009,20138,"Address 01: Engine","000772","Cylinder 4: Misfire Detected","P0304 - 007","Short to Ground - Intermittent"
3-Oct-2009,20138,"Address 01: Engine","000774","Cylinder 6: Misfire Detected","P0306 - 007","Short to Ground - Intermittent"
3-Oct-2009,20138,"Address 01: Engine","000768","Random/Multiple Cylinder Misfire Detected","P0300 - 006","Short to Plus - Intermittent"
3-Oct-2009,20138,"Address 01: Engine","001110","EVAP System: Very Small Leak Detected","P0456 - 006","Short to Plus - Intermittent"
3-Oct-2009,20138,"Address 01: Engine","001796","Clutch Switch (F36): Implausible Signal","P0704 - 008","Implausible Signal"
3-Oct-2009,20138,"Address 65: Tire Pressure","02214","Tire Pressure Warning","000",
8-Oct-2009,20200,,,"20,000 oil change, Evap valve changed, TB 2019948/2 performed for carbon buildup/misfires",,
16-Feb-2010,24124,"Address 01: Engine","000772","Cylinder 4: Misfire Detected","P0304 - 007","Short to Ground - Intermittent"
16-Feb-2010,24124,"Address 01: Engine","000774","Cylinder 6: Misfire Detected","P0306 - 007","Short to Ground - Intermittent"
16-Feb-2010,24124,"Address 01: Engine","000773","Cylinder 5: Misfire Detected","P0305 - 007","Short to Ground - Intermittent"
16-Feb-2010,24124,"Address 01: Engine","000768","Random/Multiple Cylinder Misfire Detected","P0300 - 006","Short to Plus - Intermittent"
16-Feb-2010,24124,"Address 01: Engine","000771","Cylinder 3: Misfire Detected","P0303 - 007","Short to Ground - Intermittent"
16-Feb-2010,24124,"Address 36: Seat Mem. Drvr","00668","Supply Voltage Terminal 30","06-10","Signal too High - Intermittent"
16-Feb-2010,24124,"Address 56: Radio","00857","CD Changer Unit (R41)","004","No Signal/Communication - Intermittent"
22-Feb-2010,24124,,,"CEL illuminates",,
23-Feb-2010,24196,"Address 01: Engine","000772","Cylinder 4: Misfire Detected","P0304 - 007","Short to Ground - Intermittent"
23-Feb-2010,24196,"Address 01: Engine","000774","Cylinder 6: Misfire Detected","P0306 - 007","Short to Ground - Intermittent"
23-Feb-2010,24196,"Address 01: Engine","000773","Cylinder 5: Misfire Detected","P0305 - 007","Short to Ground - Intermittent"
23-Feb-2010,24196,"Address 01: Engine","000768","Random/Multiple Cylinder Misfire Detected","P0300 - 006","Short to Plus - Intermittent"
23-Feb-2010,24196,"Address 01: Engine","000771","Cylinder 3: Misfire Detected","P0303 - 007","Short to Ground - Intermittent"
23-Feb-2010,24196,"Address 01: Engine","001796","Clutch Switch (F36): Implausible Signal","P0704 - 008","Implausible Signal"
23-Feb-2010,24196,"Address 36: Seat Mem. Drvr",,"No Faults Found or DTCs not supported by controller or a communication error occurred",,
23-Feb-2010,24196,"Address 56: Radio","00857","CD Changer Unit (R41)","004","No Signal/Communication - Intermittent"
24-Feb-2010,,,,"25,000 service, TSB 2019948/3 performed for carbon buildup/misfires",,
11-Jun-2010,26725,,,"Balance and Rotate Tires",,
15-Jul-2010,27426,,,"CEL illuminates",,
15-Jul-2010,27426,"Address 01: Engine","000772","Cylinder 4: Misfire Detected","P0304 - 007","Short to Ground - Intermittent"
15-Jul-2010,27426,"Address 01: Engine","000774","Cylinder 6: Misfire Detected","P0306 - 007","Short to Ground - Intermittent"
15-Jul-2010,27426,"Address 01: Engine","000768","Random/Multiple Cylinder Misfire Detected","P0300 - 006","Short to Plus - Intermittent"
15-Jul-2010,27426,"Address 01: Engine","000773","Cylinder 5: Misfire Detected","P0305 - 007","Short to Ground - Intermittent"
Car is at the dealer today, again - 3rd time in ~8000 miles.
