Results 1 to 9 of 9
Hybrid View
    Senior Member Two Rings shaahid's Avatar
    Jan 06 2007
    Audi A4 1.8T
    Chicago
    What to replace discontinued Blizzak LM-22 with?
    So, last winter I picked up a set of Blizzak LM-22s from a member on Audizine. Well I hit a pothole and one of the tires ripped. The LM 22s are discontinued now and I can't find the size I need anywhere (225/45/17).
    Would it be ok if I picked up an LM-25 for that tire? Or maybe I should replace 2?
    2001 A4 1.8tQMS | RNS-e | Clear Cornered | 6000k HID Headlights and Fogs| Matte Black RS4 Grille | Independent Fog Light Mod | "Swiss Cheesed" Airbox | APR Snub Mount |
    Oct 06 2004
    Minnesota
    Re: What to replace discontinued Blizzak LM-22 with?
    How worn down are your other three tires?
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    if your tires are over 60% tread, i would replace the 1 with the newer model.
    If they were under 60%, its kind of iffy. i would probably replace the set and try to sell the remaining 3 on the classefieds.
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Jun 14 2005
    Anaheim, CA
    if you must only replace 2, put the grippier tires on the rear. Otherwise, your car may be prone to fishtailing.
    I would suggest just replacing all 4 to be safe.
    Brandon @ VMR Wheels
    Veteran Member Three Rings A4DRIVR's Avatar
    Sep 08 2009
    2001 Golf GLS 1.8T
    Loveland, OH
    ^^2x
    Plus, your don't want to have tires of different diameters on the same axle. This causes the differential to work overtime and can lead to premature failure.
    It's SOLD!... 2001 B5A4 QMT BAT: Used to be... My BAT Build
    "When life gives you lemons, paint that shit gold!"
    Mar 24 2009
    98.5 A4 1.8TQ Tip
    Carlisle, PA
    If they were relatively new then I'd buy something similar, but if they're not then bye bye three perfectly good tires. I would now like to take this moment and recommend you get Nokians for new winter tires if you replace them now, or later when you have to replace them due to wear.
    "gutting the cat makes the turbo loudddd.. everyone in my work complex thinks i'm bt. little do they know a minivan could dominate me." - CrtchRktRcr
    Jan 06 2007
    Audi A4 1.8T
    Chicago
    Yea the other 3 are in pretty good condition. So would it be better to replace the rear 2 or just that one tire. And what kind of tire should I get?
    Oct 15 2006
    From a few to one...
    Arlington, VA
    i thought the lm30 was the replacement for the lm22. maybe im wrong.
    edit: correction, i think it's the LM-60, not the LM-30. sorry about that. here's a link on tirerack to see if the treads are similar. http://www.tirerack.com/tires/tires....port%20Package
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Established Member Two Rings Demon's Avatar
    Jun 01 2009
    Chicago
    LM 60 is new LM 22 tire, we just sold the last set yesterday. How old are those tires since winter tires have expiration date
