Results 1 to 10 of 10
    Feb 07 2008
    The boonies, near Seattle
    When posting in this forum please read this first!
    In order to help you better, please provide the year, make and model of the car you are asking about. Simply asking for an ipod solution or a speaker replacement solution does us no good if we don't know what car we are talking about.
    This will help us help you
    -dre
    Sep 02 2008
    Boonies VA
    Re: When posting in this forum please read this first!
    Very good point!
    White Wagon
    Established Member Two Rings LERecords's Avatar
    Nov 24 2008
    05 Yamaha FZ6, 07 A4 S-Line
    +1
    Mar 11 2008
    B7RS4 & e46Ms
    FYI for anyone... If you state that you "really like the factory Bose system", I probably won't answer your question...just sayin.
    FRRG AZ Ring
    Active Member Two Rings andre.e.adams's Avatar
    Jan 17 2010
    Minneapolis
    Don't many people not REALLY like the factory Bose system? The new B&O with VAG-COM'd increased bass is another story. BTW I just made the mistake of not giving the details of my car...n00b i b
    Mar 11 2008
    B7RS4 & e46Ms
    Let me also add that the search function works wonders...Please search before re-posting.
    kthxbye
    FRRG AZ Ring
    Jun 13 2011
    69 911. big engine, brakes, suspension.
    New York City
    I see my post regarding replacement speakers is locked. Did I do something stupid?
    Registered Member One Ring Christiaan King's Avatar
    Aug 02 2017
    South-Africa
    Hi guys i bought myself the Audi B6 A4 1.8t and with it came a new and very nice sound system.But i noticed only the front speakers are connected or playing no radio also.I looked around and found some kind of amp in the boot so now i kneed to know how or where to rewire or plug in the rest.My froantloader is a 7"wide av system display/DvD Player XTC 9500DV.And the amp in the back is the following 8E5 035 223 Amplifier B6/6314 i dont even know how to test it to see if it works!?!?Please help me im really frustrated with no amp and sub.....
    Sent from my LGMS631 using Audizine mobile app
    Junior Member One Ring MazAudi's Avatar
    Dec 10 2017
    London UK
    Hi I got a similar problem as Christiaan.
    Audi A4 B6 2.4 2003.
    Front dash speakers work fine
    Door speakers - nothing at all
    Rear speakers just about hear it on full volume and distorted.
    Standard single din CD Radio head unit.
    Previous owner cut the cables on the connector to HU.
    I want to know where the amp is hiding, (If I have one) apparently its in the boot behind the passenger seat behind the trim.
    Please can someone point me in the right direction
    Aug 02 2017
    South-Africa
    Hi its actually behind the trim to your right side in the boot.Close by the fuel management module.It's mounted in the upper right corner there and bassically it's rather smaller than i imagined and very basic,only a single plug in module.To be honest i never really got a reply or really checked after one week of silence but from what iv'e learned i can tell you the Boss system basically splits the front and back halfs in 2 so from your front unit the 2 mits in the doors should play and the dash speakers.Then in your back window is a 40ohm speaker together with the 6x9's or also 2 mits in the back doors the all receive power from the back boss system as far as iv'e seen only one cable pass to the front unit i gues for the power source.But honestly i left everything as is and installed a 7"XTC froant loader with my boxed sub and amp in the back,layed my own cables from front to back with a fuse on the cable from the battery.Only using the front mits sub and amp and it's way beter on it's own.But if you prefer the boss system remove your bacm seat and work from there to trace the cables thats the point where all come together from front to back.Good luck......
