Results 1 to 25 of 25
    Veteran Member Three Rings TheHeggi's Avatar
    Aug 03 2008
    05.5 2.0t A4 + 02 CBR600 F4i
    Redlands, CA
    ANOTHER cold start thread
    So last winter I never noticed a hesitation on cold starts, but this winter, diff story. Pretty much every cold morning, it takes a few seconds to start and starts very slow instead of firing right over, AND it doesn't sit at ~1250rpm to warm up, it drops to 750rpm within 10 seconds...
    -Newer battery
    -New BSH PCV Stg 1
    -Had the updated ECU flash before the APR flash
    -Original coil packs, HPFP, and cam follower/cam
    I have noticed NO other problems in drivability, and it fires right up when warm. Should I be worried about it being the cam follower? It's not dying after starting or sluggish at all during acceleration, but would it be worth peace of mind to at least take a look at the follower? Thanks!
    05.5 DG 2.0TM FWD
    [Stasis SS][RS4 Rear Sway][APR 91][AEM intake][034 HFC][podi/stepper boost gauge][Satin Black B6 USPs][S-Line front bumper][RS4 Grille][Satin Black S4 blades][DIY Ti vinyl][DEPO projectors w/6000k]
    Sep 02 2008
    Boonies VA
    Re: ANOTHER cold start thread
    First winter with my A4 here, and the cold start is a joke. I have the exact same symptoms as you, a few seconds and slow to start when its cold, but once warmed up its not a problem and it drives fine.
    White Wagon
    Senior Member Three Rings WasGTIguy's Avatar
    Jun 09 2009
    Orangeville, Ont
    My 3.2 fires right up even in -35c with windchill. Buuuuttttt, the idle drops down after a few seconds too.
    Veteran Member Four Rings bez101's Avatar
    Oct 06 2009
    sheffield
    same here in the uk -6 and thats cold for us on the uk cars dont know bout us cars we have a secondry heater that kicks in around -1 and mine goes stright to 750 rpm
    Established Member Two Rings Pato610's Avatar
    Oct 02 2006
    Boston, MA
    I am having the same issue with cold start (located in Boston, car parked in driveway outside over night). I replaced my battery 2 weeks ago through audi dealer because they said it was "reading low" whatever that means. I have to hold the ignition key turned on for a good 5-10 seconds before the engine turns over.
    Jun 09 2009
    Orangeville, Ont
    Quote Originally Posted by Pato610 View Post
    In my A4 I just have to turn the key and let go, it rolls automatically until it starts. Do all B7s do this?
    Aug 03 2008
    Redlands, CA
    Quote Originally Posted by WasGTIguy View Post
    No...
    05.5 DG 2.0TM FWD
    Aug 13 2009
    Tampa, FL
    I'm having the same issue. Any tips for this?
    Senior Member Two Rings A42S4's Avatar
    Apr 09 2008
    BFE
    same here.. fires right up...check your anti-freeze
    2012 Phantom Black A5 | Premium Plus| St Pkg | Nav | B&O | Carbon Inlays | Adv Key | APR tuned | 20% tint
    Gone: 06 A4 ÜberS-Line/APR tuned/10% tint/19' BBS CK/HID Fogs 6K/Vag-Com/STaSIS exhaust/RS4 sway/Carbonio Intake/LED -licenseplate mod/CIM vent gauge/StopTech Stage II
    DUH! an Audi
    los angeles, CA
    i thought i was the only one, happened to me once or twice
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    probably because it is too cold outside for the secondary pump to turn on so because air is not being for in by the pump, the engine is warming itself up by dumping plenty of gas in itself. my b6 does still if i havent driven in more than a day.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Senior Member Three Rings jeradw's Avatar
    Jul 18 2009
    2008 A4 (his) 2010 Tiguan (hers)
    Wisconsin
    Is it normal for the RPMs to drop to 750? In the garage I have noticed they start at 1200 and then drop down to 750 after about 30 seconds. After sitting out in the cold all day it starts at the same spot, but takes a little longer to drop down. I've always assumed this is normal...once it warms up, then it drops down??
    Veteran Member Three Rings clemsongt's Avatar
    Mar 09 2009
    05.5 A4 2.0TMT RIP: 88 MX6 GT
    Irmo, SC
    Heggi, and everyone else for that matter, are y'all making sure to 'prime' the fuel pump before trying to crank the engine?
    If you turn your key to the 'ON' position (just before the 'START' position) and wait until the noise you hear stops, your car will not take as long to start up. It might still take longer than a warm start, but it makes a big difference.
    I have also had the recall done on my coilpacks, and I think this has made a slight improvement on the cold starts. The issue is largely fuel related, so changing the coilpacks is not going to get rid of the problem.
    HTH
    Disclaimer: In no way shape or form is the comment above representative of an automotive expert. It is merely the understanding and/or opinion of an automotive enthusiast, and as such, the knowledge he/she possesses may or may not actually be the truth.
    Oct 02 2006
    Boston, MA
    I had a "new" cold start issue this morning. I haven't driven the car in 2 days, parked in the driveway @ 20 degrees.
    Engine sluggishly turns over, then the check engine light came on. I turned off the car and started it again, and it started fine, but check engine light remains on. The display showed the green "OK" when the car turned on the second time, and I drove it to work no problem. 30 mile highway drive, I cycled through all the gears, hammered on it up to 6500 rpms once the car warmed up, no performance issues (APR93 + Test pipe are only engine mods)
    Any idea why the check engine light is on?
    Senior Member Two Rings a4b7smallturbo's Avatar
    Dec 10 2009
    2005.5 a4 b7 2010 q5
    Dade miami fl
    this is my first winter with the b7 honestly when its cold as hell my e break sometimes gets stuck.... also just take a little bit til its finallly warm but once it is its ready to go
    Veteran Member Three Rings gyroscope's Avatar
    Mar 19 2007
    06 A4 S-Line Quattro, 98 K1200RS, 21 GTI SE DSG
    Queens, NY/Poconos, PA
    I've always primed my fuel pump and the dealer replaced the low pressure fuel pump yesterday because I got stranded and the car wouldn't start.
    Went out to start it this morning and it took at least three tries and the car still makes a grinding noise immediately after being started. Car only has 15k on it. Kind of dissapointed in Audi for this design flaw.
    Aug 03 2008
    Redlands, CA
    Quote Originally Posted by clemsongt View Post
    HTH
    Yessir, I've done it since day one. I knew what that sound was immediately, I do it with all the cars I drive.
    I actually primed it 3 times this morning and it may have helped. Hard to tell, but it SEEMED to have started easier, idled at 1200rpm for a little, and my CEL that came on yesterday from starting it, disappeared. I just turned the key, waited until ALL the noises were done, then turned it back off and did that 2 more times....may be worth trying for some of you other guys. No guarantees, but it MAY have helped. I'm going to try it parked in the elements tonight instead of the garage, that will be the deal breaker, I'll be sure to follow up here.
    05.5 DG 2.0TM FWD
    Aug 03 2008
    Redlands, CA
    Re: ANOTHER cold start thread *UPDATE, HELP*
    So I replaced my cam follower, low pressure fuel sensor, and have new coil packs, but the problem is STILL there. CEL only comes on at a cold start. I "primed" the fuel pump twice this morning and it still took an extra second to turn over. 4 hours later I come out (raining, windy, cold) and don't prime it, it takes a little longer to start, starts, and 3-5 seconds later a CEL pops up. It is very consistent in it's behavior and is directly linked to a cold start. The CEL will go away by tomorrow for sure. Could the low pressure fuel pump possibly need to be replaced? Is it not getting enough fuel to the engine on a cold start, throwing the code? Any insight? This is truly frustrating
    05.5 DG 2.0TM FWD
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    TheHeggi - is your A4 a quattro or FWD? When you say "primed" the fuel tank, is that the noise that's coming from the back? The sound that I hear on mine might be related to the pump that balances the fuel in the tank as there's a hump in the middle due to the rear differential. The sound isn't present on FWD cars since there's no need for that pump.
    As for your CEL, really need to figure out what code it's throwing, could be anything.
    There's also a separate thread on quattroworld where one of the guys there had issues starting the car, basically hard to start when the engine is cold. He took his car in and he mentioned that his ECU was reflashed (no further details on this) and his cold start issues in the morning appears to be resolved, but time will tell.
    Mike
    Aug 03 2008
    Redlands, CA
    Quote Originally Posted by Tanner View Post
    Mine is FWD. The sound I'm talking about is the high pitch "electric" sound that comes from the hpfp. It goes for about 15+ seconds after you turn your key to the "on" position. Then you can hear what sounds like a piece physically closing when it stops.
    I am willing to bet that the CEL is the one posted in my other thread, P310B (low pressure fuel regulation out of specification), I thought I had posted it in this thread, my apologies.
    As for the ECU flash, I've read that as well, and I had my ECU updated/reflashed before my APR flash. Could it be the same issue, but caused by the APR flash since they may have the old(er) values and whatnot stored as the "stock" setting? That and the lpfp are all I can think of at this point...
    05.5 DG 2.0TM FWD
    Mar 09 2009
    Irmo, SC
    Definitely need to get the code read...Find someone with a Vag-com or take it back to the dealership. If a normal OBDII reader can't read it, then something else can that reads the history.
    Markham, ON
    The buzzing you hear is something else, not sure if it's the sound of the intake manifold controller or not, but the HPFP runs off the cam so it's not doing anything until the engine turns over.
    As for the low pressure fuel regulation out of spec you might want to read this for what it's worth...
    http://www.justanswer.com/questions/...eceiving-p310b
    Mike
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Cold start seems like a sign of fuel pump failure to me....
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Aug 03 2008
    Redlands, CA
    That could be the correct sound, I was almost certain it was coming from the hpfp, but intake manifold motor does make sense...
    Thanks for that link, that's EXACTLY what is going on with mine, but I did replace the sensor with that part #, so it looks like the next step is the fuel filter...hopefully I don't have to go to the in-tank pump...this sucks. Thanks for the help guys
    05.5 DG 2.0TM FWD
    Aug 03 2008
    Redlands, CA
    Anybody know the part number or location for the fuel filter on a FWD?
    05.5 DG 2.0TM FWD
