Originally Posted by
Tanner
TheHeggi - is your A4 a quattro or FWD? When you say "primed" the fuel tank, is that the noise that's coming from the back? The sound that I hear on mine might be related to the pump that balances the fuel in the tank as there's a hump in the middle due to the rear differential. The sound isn't present on FWD cars since there's no need for that pump.
As for your CEL, really need to figure out what code it's throwing, could be anything.
There's also a separate thread on quattroworld where one of the guys there had issues starting the car, basically hard to start when the engine is cold. He took his car in and he mentioned that his ECU was reflashed (no further details on this) and his cold start issues in the morning appears to be resolved, but time will tell.
Mine is FWD. The sound I'm talking about is the high pitch "electric" sound that comes from the hpfp. It goes for about 15+ seconds after you turn your key to the "on" position. Then you can hear what sounds like a piece physically closing when it stops.
I am willing to bet that the CEL is the one posted in my other thread, P310B (low pressure fuel regulation out of specification), I thought I had posted it in this thread, my apologies.
As for the ECU flash, I've read that as well, and I had my ECU updated/reflashed before my APR flash. Could it be the same issue, but caused by the APR flash since they may have the old(er) values and whatnot stored as the "stock" setting? That and the lpfp are all I can think of at this point...
