Results 1 to 39 of 39
    Veteran Member Four Rings Voltrons_Head's Avatar
    Sep 14 2009
    Philly
    MTM Cantronic install and testing
    Alright so I spent some time this afternoon figuring out the install and testing of the stage 2 MTM Cantronic. This isn't meant to be a DIY so I'm not going into full installation detail. Here it goes.
    The instructions that come with it are pretty bad. They are in German with English subtitles and literal translations. It's funny actually looking back on it though at the time it was a bit frustrating. The whole thing took about 1.5 hours including some confusion in the middle. My brother and I wound up calling Hoppen Motorsports where I spoke with Mike and he helped us out. Kudos to him for calling me back from his house as he wasn't working today. If I had to go back and do it again I think we could get it done in 35-45 minutes.
    Prior to doing the install I did some before runs with the Gtech SS that I ordered. I was extremely surprised how fast the car was from the factory. Here is the test environment. S4 prestige/stronic/ads in dynamic mode. 20" Hartmann wheels with 255/30/20's. The car had 1/4 tank of gas and two passengers weighing 225lbs and 180lbs. Temperature was 30 degrees.
    The best stock time was 4.76s 0-60. It was a number that I couldn't duplicate for the rest of the stock runs. The slowest time was 5.0s. It can consistently run 0-60 in the upper 4.8x's. I knew once I saw these times that I would need to include pics of the gtech screen. They are posted at the end of this write up.
    The best post install run was 4.31s. Not only could I not duplicate that number for the rest of the runs, I couldn't even get close to it. The next best number was 4.58s. That was more like it. Mixed in the middle were a bunch of low 4.6x's. The slowest time so far was 4.69s.
    So the end result being that pre-install the car consistently ran high 4.8x's and now it runs low 4.6x's. The net result being 2.5 tenths of a second decrease in 0-60. Needless to say I am very happy with it. The car is so obnoxiously fast now it's criminal. The 0-60 times don't really do the modification justice. It is faster in every real world test I can think of as well. I spent about an hour driving it home from my brothers house during which I went on highways, residential roads and a bit through the city. Every different driving scenario had a noticeable difference. Though I'd be naive to think that some of my "butt dyno" impressions aren't partly in my head.
    Here are the screen shots of the gtech.
    Established Member Two Rings AeroSmith's Avatar
    Aug 18 2009
    ...is out back.
    Saint Petersburg, Florida
    Re: MTM Cantronic install and testing
    Awesome.
    That's pretty much what I experienced in the S5 Cabriolet: a consistent 2/10 second improvement in 0-60 times.
    I notice your times start out fast and get a bit slower. Did you give the car/engine/SC a few moments between runs to cool down a bit? I noticed that helps.
    Thanks for posting.
    On order: 2013 A4 6MT/S-Line/Prestige, Glacier White Metallic
    2011 A4 Avant quattro S-Line/Prestige, Monaco Silver Metallic
    2007 Q7 quattro, 4.2 Premium, Black (for sale)
    2009 Toyota Prerunner Pickup, Silver
    Gone but not forgotten: 2001 allroad, 2007 S8, 2009 S5 Cab
    Sep 14 2009
    Philly
    I sorted them from lowest to highest so this isn't a good look at the fading of the performance. The only thing consistent was the fact the fastest times were both the first runs of the before and after.
    Sep 14 2009
    Philly
    What I found most interesting was how fast the before runs were.
    Veteran Member Three Rings rktskicar's Avatar
    Dec 12 2009
    Do me a favor, run a HP run on your Gtech. Run first gear up to about 3K RPM then shift to 2nd and punch it until redline at top of 2nd. Take a pic of your HP graph from your Gtech. Same thing holds for Aerosmith.
    Mine Stock, Gtech RR, seeing about 275 RHP in 2nd gear.
    Thanks,
    Bruce
    Sep 14 2009
    Philly
    No problem. I must say that looking at the HP measurements during the 0-60 runs didn't really do anything for me. They were all over the place when comparing the different runs. I'll have to crack the book open again and look at the HP run part to see what it's all about. Then I'll do the comparo for you.
    Dec 12 2009
    Quote Originally Posted by Voltrons_Head View Post
    The HP run is very different a than 0-60 run. The HP run is intended to measure HP over a single gear run.
    Bruce
    Dec 27 2008
    B8 S4*07 Z4 M Coupe*2009 BMW X5 3.5D
    Northern NJ
    Awesome post! Please keep us updated as you drive the car more. Im really interested to see how the car performs all around.
    Veteran Member Four Rings JetBlue's Avatar
    May 03 2004
    Carlsbad
    It makes sense that the car would be fastest in the first run since there is no heat soak. If you were to space the runs out by an hour they would probably be closer to your initial run for stock and non stock.
    "The American Republic will endure until the day Congress discovers that it can bribe the public with the public's money." Alexis de Tocqueville
    Sep 14 2009
    Philly
    There was a definite performance fade in the before runs while the after runs were much more consistent excluding the first run of 4.31s.
    Aug 18 2009
    ...is out back.
    As an aside, am I the only one who thinks that 0-60 in 4.6s is SERIOUSLY fast for a four door sedan that costs one half as much as an S8 (not to mention the V8 R8)? The V6T/S-tronic quattro is one SICK drive train.
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    maybe you can give a general feeling of any changes in gas mileage too. The 4.31 run must have been quite a ride on the butt dyno for feel eh.
    4.6 is rs4 territory in the end.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    Quote Originally Posted by L0U View Post
    4.6 is in Carrera S territory. 4.6 is FASTTTTT. It's unreal to think a ~4000lb car can pull off a 4.6 0-60.
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Sep 14 2009
    Philly
    I will once i reset the mpg meter. It is seriously jacked from all the 0-60 runs. I think it says 13.5 mpg now even after driving today.
    Sep 14 2009
    Philly
    Yeah man. I'm with you. I'm also glad that you got it done and posted about it because I was really on the fence and that is what pushed me over. It's a big difference though the power delivery has remained silky smooth. You blink and your doing 90.
    Sep 14 2009
    Philly
    The 4.31 reading, as much as I wish it was real, was probably an anomaly with the gtech itself. Or for whatever reason the car just had the perfect run that time. There have been quite a few more runs after I posted this and I'm able to do low 4.6x's even high 4.5x's but 4.31, no way.
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Quote Originally Posted by Ynnekdude View Post
    Don't worry, it's still only a ~333 hp car
    Senior Member Three Rings SupraBlur's Avatar
    Jul 16 2008
    Los Angeles, CA
    It IS definitely fast although 0-60 is always skewed when dealing with AWD because it takes into consideration a launch advantage. In other words, given a rolling start, the Carrera S is probably noticeably faster, as is the overall sensation of acceleration during normal (meaning not limited by traction) driving conditions.
    But yes, credit where credit is due, that is definitely faster than the V8.
    2021 Audi SQ8 - S Sport - Dragon Orange
    Previous Audis:
    2018 Audi SQ5, 2009 Audi S5
    Sep 14 2009
    Philly
    How do you feel about your AWE downpipe and Milltek exhaust? I'm exploring other tuning options. I know my options will be different than yours but I'm still curious to know. Thanks.
    Dec 10 2008
    Chicago
    Quote Originally Posted by NWS4Guy View Post
    I'm confused...
    Quote Originally Posted by SupraBlur View Post
    I think the Carrera S would likely be faster 0-60 and on a roll with a good driver. I was simply saying the S4 w/MTM tune is in Carrera S "territory" as a compliment to the OP as he has one fast automobile!
    Established Member Two Rings imolar's Avatar
    Sep 28 2009
    Washington
    I'm confused...
    I think he meant that with sarcasm and maybe even a shot at someone from other horsepower discussion threads, but don't want to put too many words in his mouth either.
    Sep 29 2009
    Quote Originally Posted by imolar View Post
    No, you got it pretty dead on ;)
    Dec 10 2008
    Chicago
    I guess I need to keep up on the horsepower thread then!
    Veteran Member Three Rings ahhhudi's Avatar
    Dec 15 2008
    north Chicago area
    Very impressive. This platform will have plenty to explore in the future and get significantly faster still.
    Current: 2015 B8.5 S4 - Sepang Blue w/Black Optic package. Sport Diff.
    Previous: 2005 B6 S4 - Dolphin Grey and 2001 B5 S4 - Black.
    How Many Speeding Tickets? Vote.
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    Quote Originally Posted by AeroSmith View Post
    nope...it is indeed fast...especially considering that it weighs 4000lbs.
    4.6 seconds is what the RS6 accelerated to 60mph in back in 2003...and back then that was ABSURD from a big 4000+lb 4 door. It was comparable to the Ferrari V12 GT car, and that made everyone laugh.
    Amazing stuff.
    Sep 14 2009
    Philly
    Yeah dude. It's faster than you can use on the streets. Stupid fast in fact.
    Jun 02 2008
    then...what's a Porsche Panamera Turbo? 0-60mph 3.2 seconds
    Veteran Member Three Rings John4378's Avatar
    Mar 19 2009
    Houston, TX
    Quote Originally Posted by sakimano View Post
    $132,600 base MSRP vs. $48k for S4
    500HP vs. ~333HP (Porsche understates their HP as well so no use guessing)
    0-60mph is 4.0 / 3.8 with sport chrono package....not 3.2 vs. 4.9?
    For about $80-$85k difference in price I'm sure you can make that S4 more powerful and faster than a Panamera Turbo (which is also one fugly car IMHO).
    Now, I can pick up a 2004 low miles 996 Porsche Turbo or GT2 for low $60k range...I'd much rather do that if I didn't have to worry about a car seat, lol.
    Dearly Departed - 2008 A4 Avant 6MT S-Line w/ APR Stage 2, 034 HFC
    2006 Lotus Elise
    2005 Ducati Monster S2R
    2006 Ducati Monster 695
    2009 A4 6MT S-line w/ APR chip, AWE exhaust, AWE FMIC, Eurocode HFC
    2011 Ford Explorer - Family Swagger Wagon.
    Dec 15 2008
    north Chicago area
    Quote Originally Posted by John4378 View Post
    Ok, so maybe not 3.2.... but certainly 3.3 out of the Panamera Turbo (and in the 11s for the quarter)...stock...
    http://www.caranddriver.com/reviews/...urbo-road_test
    ... faster than their 911 Turbo.
    But enough of the tangents... back on topic...
    B8 S4... MTM...
    Senior Member Two Rings s-4man's Avatar
    Nov 11 2009
    Range rover evoque Audi TTRS Polaris ace 900 sp
    montreal
    who cares about 0-60 times... the diff is like a bumper when comparing 4.3 to 4.6! lets see some 1/4mile times!
    Mar 19 2009
    Houston, TX
    The times I quoted for that Panamera Turbo came from Porsche's website...that's all I got.
    I already have a car that does 0-60mph in 4.1 seconds if I really need to, since my Lotus has the ForcedFed 275 turbo kit on it
    2006 Lotus Elise
    Dec 15 2008
    north Chicago area
    Quote Originally Posted by s-4man View Post
    I say forget about the 1/4 mile test as well and do it the way Europeans do and run it for 1 kilometer. That would be really nice.
    Nov 03 2009
    Stuttgart, Germany
    Quote Originally Posted by ahhhudi View Post
    I say do it like the Europeans do and run it on the Nurburgring. ;)
    Can't wait to get mine...
    - Jeremy -
    Veteran Member Three Rings i_eat_staples's Avatar
    Aug 03 2004
    Wilsonville, OR
    awesome, cant wait to see what unfolds for the b8 platform. Whatever happens, i'm sure it will be more exciting than the b6/7 platform for the first ~5 1/2 years it was out :P
    '07 rs4
    '91 spec miata
    NW Quattro - NW Premier Audi Club
    Sep 03 2009
    yeah...bring on the gtech 1/4 mile. if stock was 13.2....did mtm break into the 12s?
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Sep 29 2009
    Well if it doesn't there is a serious issue with it I would say.
    Sep 14 2009
    Philly
    Once I can find a place to run her up over 100 from a stand still I'll post the results.
    Dec 12 2009
    Save your Gtech run and post up HP vs time curve as well.
    Thanks,
    Bruce
    "I think the car is too damn quiet and smooth. It doesn't seem like you're hauling ass until you look down at the speedometer."
    Stock ECU, Sprint Blue 6MT 010 B8 S4, Premium +, B&O, sport diff, black Nappa, BBS CH, 255/40/18 Bridgestone RE960 AS
    Milltek resonated cat-back & DPs
    01.5 6MT ASP Stage 3 B5 S4 (4/01 to 9/09)
    Dec 17 2008
    Charlotte, NC
    Come down south I know some spots
    Thanks for posting the gtech stuff, very interesting! What a great car this new S4 is!
    Ol' Whitey - 1996 A4 2.8 quattro 5MT Arctic White w/ Remus
    #2 - 2008 A4 2.0T Quattro 6MT Quartz Gray - w/ AWE exhaust (1/08 - 1/11)
    #3- 2011 A4 6MT Quartz Gray - Prem Plus, B&O, Titanium - Full Gen1 AWE dual exhaust, Eurocode Everything, 3M Clearbra, Piano Black Dash Surround, MY10 rear headrests, Huper Optik, S-line Stoneguards
    #4 2014 Audi S4 6MT - Monsoon + Black optics Neuspeed exhaust, Eurocode bits
    Audi Brand & Audi Sport Specialist at Northlake
    B8 Titanium Club Member #4
