Results 1 to 8 of 8
    Feb 22 2008
    Perth Australia
    best tyre size for A4 15inches Factory rim
    hi there
    i have a question. my factory Tyre size is 205/60/15. if i change it to 205/55/15 or 205/50/15, would it become a problem or any disadvantage? what is the best size tyre in 15 inches for A4?
    cheers
    PHD
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Re: best tyre size for A4 15inches Factory rim
    I would just stay factory size IMO.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Jun 30 2008
    Erie, Pennsylvania
    For winter narrower is better so I run 195/65/R15 on the stockers. That's really the best winter traction setup. I don't see any problem with running 205/55's but the wheels will look small with less sidewall. And the speedo will be off. And your spare tire wouldn't be the right size (AWD issues). So I'd just stick with the stock size, or the alternate narrower size.
    Senior Member Three Rings jpcallmotor's Avatar
    Jan 11 2009
    B5 A4 1.8T
    Chicago
    I use 205/55/15 for the summer season and a narrower winter tire 195/65/15 in the winter.
    205/50/15 would fit but is too small for the A4.
    Next time you get fuel, check the inside of the fuel door, the suggested tire sizes are posted on the inside.
    Feb 22 2008
    Perth Australia
    alternatively, i can get a set of audi TT(1999) factory 16 inches alloy wheels, would it fit audi a4?
    Senior Member Two Rings malanca's Avatar
    Sep 20 2009
    A4 B5 1.8T (AEB) Quattro Avant | Opel A Corsa C20XE
    The Netherlands
    Quote Originally Posted by phd View Post
    No, won't fit. TT has 5x100mm while the B5 has 5x112.
    K03-0073 | APR 2.5" exhaust | Clutchmasters FX400 240mm | Milltek 200cpi | APR intake-hose | Autobahn88 FMIC | 240 chp | Eibach Pro-Street-S coilover | TAROX brakes
    Feb 22 2008
    Perth Australia
    if i put 215/60/15 instead 205/60/15, would it be big Drama? or would they fit? hit the guard?
    Established Member Two Rings Demon's Avatar
    Jun 01 2009
    Chicago
    Just curious. Why you want to change your factory tire size? Most ppl have different wheel or tires just for winter and for summer,Should not mess around w/ factory tires size on 15s, leave it same
