Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 245
  1. #121
    Jan 19 2011
    DFW, Texas
    Quote Originally Posted by matman1t View Post
    The Results are in:
    05-06 Chrysler 300C or SRT 8 $280.00 (12 PIN) LADG5
    03 04 05 06 07 Cadillac CTS $353.10 (12 PIN) LADG5
    These of course are not confirmed to fit until I hold the part in my hand to verify.
    It looks like these 12 pin ballasts are a little harder to come by.
    And seeing these high prices, I think I'll first try to wire up the 12pin harness in my A4 to the cheaper 4pin Ballast.
    Interestingly enough, there are only 2 wires in the 12 pin harness. 12V positive and negative. All I need is to figure out which of the 4pins on the ballast connector they go to??? Any body know how many wires are in their 4pin harness, and where they go? This will increase my chances of success.
    or I'll be opting for a used ebay 12pin ballast for around $200.
    Has anyone been able to get a Mopar part number for the 12-pin ballast? I am trying to replace a dead ballast on my Saab 9-5 and Google has led me here. My car has wires running to each of the 12-pins, so I don't want to mess with converting it to 4-pin.
    Saab says that the part is on national backorder. An HID parts seller that I've been dealing with is bringing some of the LAD5G ballasts in, but can't give me an ETA. To add insult to injury, the ballast gave out toward the end of December 2010. My vehicle inspection expired at the end of December as well and I can't get the car inspected until I have two working headlights . I am stuck between a rock and a hard place here and I really don't want to pay $200 for a used ballast that might last 6 months.... [/rant]
  2. #122
    Jun 08 2010
    Did some searching and found the 4 pin connectors on ebay motors if anyone still needs one it was like 6 bucks.
  3. #123
    Dec 30 2010
    tn
    Quote Originally Posted by crash214 View Post
    I need 2. pm sent
    Also does anyone have the part# for the ballast? Maybe I'm blind, but I haven't seen one yet and I'm pretty sure I've read this whole thread twice. Awesome info though!
  4. #124
    Veteran Member Three Rings POPO's Avatar
    Feb 02 2008
    2001 Chevy Tahoe, 2005 Audi A4, RIP 2003 Audi A4
    Somerset, NJ
    I also needed a ballast and just grabbed one from a local Chrysler dealer for 147 plus tax. The part number is 05139061AA. Good luck to anyone else who needs this.
    2005 A4 2.0L Stroker- New South Vent Gauge|034 RSB|2.75" FMIC|GHL 2.5" Catback|PSi Concepts TD05H-20g|PSi Concepts Exhaust Manifold|Turbo XS EWG|Motoza tuned|
    RIP 2003 A4 1.8TQM
  5. #125
    Jan 19 2011
    DFW, Texas
    In case anyone doesn't want to use the 4-pin ballast, you can also buy the 12-pin ballast from Chrysler. Mopar part #68019173AA. I picked one up for $190 and it is the same Valeo LAD5G ballast that came out of my headlight.
  6. #126
    Established Member Two Rings baungS4's Avatar
    Jul 05 2007
    Queens,NY
    Does any one know which one I should get for my B6 S4?
    Thanks.
  7. #127
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    Quote Originally Posted by baungS4 View Post
    Thanks.
    easiest way to tell is to pull the headlight out, flip it over and pull the ballast off (6 screws on the ballast). Should have a p/n but you can post a pic.. may help in ID-ing the part to be sure.
    -Eric
    R 1 3 5
    2 4 6
  8. #128
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    For a bi-xenon conversion (halogen in my A4, bought bi-xenon housings) does anyone know where to get the additional parts necessary? I.e. Cable from ballast to bulb, screws, seal? Also, from my understanding, I need an extension cable for the passenger side?
    EDIT: Really, I guess all I need to know is the thread type and pitch of the OEM screws, and where to get the cable to the bulb. I'm sure I can make a seal.
  9. #129
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    Quote Originally Posted by PNW Avant View Post
    lowesta4 can set you up for most of the parts you need. I got everything from him for cheap, minus the extension cable.
  10. #130
    Established Member Two Rings jimbro's Avatar
    Mar 05 2010
    02 Denim Blue Avant
    HI State
    Speaking of bi-xenons, does anyone know if you can buy the plastic piece of the housing that the ballast attaches to. I have a condensation problem and i noticed that its cracked where this attaches to the main housing.
    02 Denim Blue Avant 1.8tqm
    PSS9 coilovers with H-Sport Sways
    APR Stage 2+
    APR DV
    Carbonio intake
    ER Sport
    Milltek HFC
    18" Audi/BBS CH028
    Future Mods: Water/Meth, Frankenturbo!
  11. #131
    Jan 29 2010
    north ga
    I'm looking for the same things.
    I bought S4 Bi-Xenon Housings recently
    The ballasts from my Single Xenon A4 housings wont work, I need:
    A set of 5GL Ballasts
    a set of D1S bulbs
    the screws from a 5G ballast will fit the 5GL ballasts right?
    and I was hoping I wouldn't need the extension cable, I've read that you can get by without it, its just a bit of a stretch for the cable that there
  12. #132
    Jan 29 2010
    north ga
    I'm beginning to think that this is the cheapest option if you need all the pieces (including a set of D1S bulbs)
    http://cgi.ebay.com/ebaymotors/OEM-V...Q5fAccessories
    the price to buy here from ebay is $100 less than buying straight from the HID concept website
  13. #133
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Good work - I like. But, they are used vs new ballasts.
    Two new LAD5GL ballasts would be ~$240 right now plus shipping, from moparpartsamerica.com.
    Whats the price for two new bulbs and two new cables? That's the question. If it's within ~$50 total price...I'd splurge for the new ballast.
  14. #134
    Jan 29 2010
    north ga
    ahhhh, good eye. I did not notice they were (USED) ballasts in the Ebay auction. Explains why it was $100 less.
    I'd also spring for the newer ballasts. I remember somebody posting over in the B6/7 S4 section about where on Amazon.com to get a set of D1S bulbs for like $60, but I don't see it still available right now. From what I'm looking at, by the time you've bought a set of bulbs, you've probably spent nearly the price for the "kit" from ebay, but still lack the cable from the ballast to bulb, and the 6 screws on each side along with the rubber seal. Not to mention piecing all the things together from multiple sources would be a pain since you'd have to pay for shipping from 2 to 3 different places instead for just one.
  15. #135
    Veteran Member Three Rings AvantinUSP's Avatar
    Jul 28 2008
    Just get some aftermarket bulbs i.e. ddmtuning, they're $50. and I would buy new ballasts from mopar..I've had several used ones go out.
  16. #136
    Jul 28 2008
    They are the same screws, and I believe you could get them at the hardware store.
    for the harness cable you may not need an extension, try it first.
  17. #137
    Jan 29 2010
    north ga
    Quote Originally Posted by AvantinUSP View Post
    this is what most of us would likely do, although if the cost is the same, or even less buying it all together as a "kit" then that's what I'd prefer to do. Not having to deal with multiple sellers and paying shipping costs 2 or 3 times would be a lot less trouble.
    Yeah, I've realized this now (I CC'd my Bi-Xenons last night). I was planning on swapping everything from my Valeo 5G ballasts to new 5GL ones when I get them, but I'm re-thinking everything and I think I want to leave my old A4 housings as-is so they are plug&play for the next owner when I sell them. Because of this, I'll need everything to do the swap.
    The small Torx screw used is the same one used all over the housing.............I found out I have a couple more screws missing on the inside of the housing too.
  18. #138
    Established Member Two Rings whodatt's Avatar
    Oct 30 2007
    02 Audi A4
    Madison, WI
    can you provide the link? It looks like I may need a new ballast soon. Thanks.
  19. #139
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Got the cables, screws, and seals from a forum member for $60 shipped.
    Add ballasts from Mopar for ~240 + Shipping
    All that's left are bulbs, which hopefully I can get for around $100 or less.
  20. #140
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    just swapped out my halogen for bi-xenon, but it looks like i need a harness extension for the right (passenger side). the left side works nicely though! perhaps i'll play with it again tomorrow since i was running out of light.
  21. #141
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by 1.8Turbo4me! View Post
    What year is your car? trying to figure out if I need this too. Where are you going to buy it?
    Do you get an auto leveling error code? I'm pretty sure I read that I shouldn't - just want to make sure though.
  22. #142
    Jun 10 2009
    Mine is a '03. Didn't find any online so I figured I make my own. Searching for the part numbers, I found Manguyen's old DIY: bi-xenon harness extension thread: http://www.audizine.com/forum/showth...ness-extension
    Though only one harness and wire were in stock at my nearest audi dealer, I used my old halogen harness/housing and wire and just connected them together. It turned out exactly the way Manguyen's harness (pictured) looked but with electrical tape and heat shrink.
    I then use more electrical tape to wire them together. (my harness)
    as for the auto leveling error, i didn't get that since i didn't have that on my old halogen.
  23. #143
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Though only one harness and wire were in stock at my nearest audi dealer, I used my old halogen harness/housing and wire and just connected them together. It turned out exactly the way his looked but with electrical tape and heat shrink.
    From the DIY:
    Female Harness: 1J0 973 735
    Male Harness: 1J0 973 835
    Wiring for female end: 000 979 133 (A) (the A is for gold plated)
    Wiring for male end, with pins: 000 797 134 (A)
    I can find both harnesses on genuine audi parts.com, but I can only find the top set of wires. The other set is not listed as a valid part number.
    When you reused the harness from your halogen, I assume you had to cut it out then?
  24. #144
    Jul 28 2008
    PNW Avant, have you actually tried fitting them in? I have an 04 and I didn't need an extension, though mine came with stock xenons.
  25. #145
    Jun 10 2009
    From the DIY:
    yeah, forgot to mention. the wiring for the male end is actually 000-979-134-A. i think Manguyen flipped flopped the middle numbers by mistake. the parts fella corrected me as well.
    but i did cut my wires from the halogen.
  26. #146
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Ah, good point!
    No I haven't checked yet. Thanks for the heads up!
  27. #147
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Mopar Parts America FTW!
    Part number 5139061AA
    $120+ $19 shipping per ballast
  28. #148
    Mar 17 2011
    Phila
    got the Valeo LAD5G for my 03 A4 from oemxenonpart <[email protected]> out of China, $215 deliverd in 5 days great price! Just wanted to post this so others don't have to go thru what i did until I bit the bullet and decided to order from China. Mopar may have had the equivalent to the LADG, but i didn't want to take a chance that it was the wrong part. I sent a picture to oemxenon and he confirmed that he had the Valeo with the 12 pin cable.
  29. #149
    Oct 19 2008
    VA
    Wanted to post this up for everyone. Help IDENTIFYING YOUR HEADLIGHT/BALLAST-****> clicky click
    *Special thank you to Ilko for posting this in his for sale post as this is great info!
    -Eric
    R 1 3 5
    2 4 6
  30. #150
    Mar 27 2008
    Denver
    Chrysler dealer wants 175$ Looks like I'll be ordering mine off moparparts.
  31. #151
    Oct 19 2008
    VA
    yea man its a great deal, as soon as I found this out it was on like donkey kong! The only have the LAD5GL though as far as I know (4 pin)
    -Eric
    R 1 3 5
    2 4 6
  32. #152
    Oct 19 2008
    VA
    -Eric
    R 1 3 5
    2 4 6
  33. #153
    Mar 27 2008
    Denver
    That's what I have so we're all good there. Now I just need a pay check! So tired of having this headlight out. It's been going on for wayyyy too long.
  34. #154
    Active Member Two Rings eurojetta's Avatar
    Oct 16 2006
    Langley, BC Canada
    Where do you guys recommend getting bulbs? Is the $239ea on ChryslerPartsDirect.com a good price?
    Andrew [dasfuls]
  35. #155
    Jan 29 2010
    north ga
    bought a set of Phillips D1S a couple days ago of Amazon, either $47 or $54/each depending on what seller you're going for. I'm taking a gamble and going with the cheaper (random seller)
    http://www.amazon.com/Philips-Xenon-...2136232&sr=8-1
  36. #156
    Oct 19 2008
    VA
    interested in how these turn out? these OEM 4300K I assume?
    -Eric
    R 1 3 5
    2 4 6
  37. #157
    Mar 27 2008
    Denver
    I got my bulbs off DDM for 50$ for the pair. A lot of people on here hate DDM but they've lasted me a while so far.
  38. #158
    Jul 05 2009
    Quote Originally Posted by JeffM03 View Post
    yeah, you can use your 4-port, but you have to switch the two wires (brown and red) around to connect in the right area.
    Like this:
    I have the same question here I have the 4 port plug with a 12 port ballasts. How would I connect them? The 4 port plug will not go into any slot of the 12port connector. Any help out there I need to do this ASAP
    Also I would assume the little 3 pin connector from ballasts to bulb is the same or all year Audis.
    Any one know where I can get the connector from bulb to harness like within 1-2 days and would love to get info on how to make my 4 wire connector connect into the 12 pin socket. Thanks
  39. #159
    Jul 05 2009
    Bump come on Ziners help me out^^^^^
  40. #160
    Aug 26 2005
    The screws are course threaded for unthreaded holes, the screws form the threads when tightened into the holes, and bite into the plastic of the housing. 6-32 screws will work as well IIRC. Optionally, use an 8-32 tap and cut 8-32 threads into the plastic holes, and use 8-32 X 1/2" long SS socket head cap screws. For a gasket, get a sheet of 1/8" thick rubber stock, and trace out the ballast outline and use a straight edge to draw the inside lines, then carefully cut out a pair of gaskets using a x-acto knife or similar. Guide the cuts using a straight edge with the cutting blade tight to the straight edge aligned on the traced outlines. For the screw holes, cut out small "v" or 1/2 circle U notches in the outside edges of the gasket placed to clear the screw holes.
    Vorsprung durch Technik
