Page 5 of 6 FirstFirst ... 3456 LastLast
Results 161 to 200 of 245
Hybrid View
    Veteran Member Three Rings the sheriff's Avatar
    Nov 03 2005
    portland, or
    nevermind.....just realized that one of the locking clips wasn't quite locking into place therefore it was presenting some resistance.
    Senior Member Three Rings Hammie's Avatar
    Jan 02 2010
    Miami, FL
    Has anyone purchased the "D1S cable" (ballast to bulb) from a local chrylser dealer? What part number do you use?
    USP WHEELS FOR SALE HERE
    Ocean Blue '04 A4 1.8T/ USP/ stock-ish
    Brilliant Black 2014 S8/ sold
    Feb 18 2011
    Portland, ME
    Thumbs up
    If anyone is looking for a cheaper place to find an LAD5GL... I have found this website. http://hidconcept.com/index.php?l=product_detail&p=39
    However, I have yet to order from them, so I won't vouch for it. That being said, I'm aware of what is needed to be done as far as wiring goes when swapping from the LAD5G to the LAD5GL, but I am curious of the models are the same dimensions? When I called Mopar, they said the LAD5G (68019173AA) is 6" long, which sounds about right, but the LAD5GL (5139061AA) is 9" long. That being said, it would seem like they don't fit. Can someone that has actually done the swap confirm that they are are same dimensions? I don't mind swapping connectors, but I would like everything to go back together and work like factory.
    Veteran Member Three Rings AvantinUSP's Avatar
    Jul 28 2008
    That's not cheaper. Moparpartz.com is.
    Mar 27 2008
    Denver
    Quote Originally Posted by AvantinUSP View Post
    They still selling them? I searched like 3 times and it said no results every time.
    Veteran Member Four Rings Lastsummer's Avatar
    Nov 25 2011
    2021 B9 Audi SQ5 Black Optics
    Grayslake, IL
    So after doing a bit too much reading up on this issue for the past 2 days, Ive come to the conclusion that my ballast is bad as well. I have an 02 A4 and I swapped out the bulb, that didnt work, tried it in the working side, that worked. How hard is swapping out the balast?
    Also, when I went to purchase new bulbs, every site said that the 02 A4 took the D1S bulb but upon removal of mine, the bulb clearly says on it D2S... thoughts on this? Is this correct?
    Aug 26 2005
    Quote Originally Posted by Lastsummer View Post
    Very early VIN number '02 A4s have D2S HID bulbs, all later VIN '02s> have D1S, so your A4 with D2S bulbs is correct for your early VIN number. The ballast is located on the bottom of the headlight, remove 6 screws after unpluging the input and output connectors inside the housing. Specific to your early VIN D2S setup, the ballast and ignitor/lamp connector are joined together and must be replaced together.These early 4G type ballasts are very hard to find, so updating the parts with the current 5GL thin ballasts is the way to go. You can update to a newer "Thin" LAD 5GL" type ballast, but you will need the same connector cable used with the ballast>D1S later type xenon headlight, and the Valeo twist-on ignitor that has the D2S connector built in. The ballast>HID lamp cable fits both the D2S twist-on ignior with connector for the bulb, and the D1S integrated ignitor lamp module. These parts are available from specialty vendors on eBay. PM me for additonal assistance if needed.
    Vorsprung durch Technik
    Nov 25 2011
    Grayslake, IL
    Diagnosticator... I sent you a PM in response to your reply.
    Also, I just came across a pair of headlights (HIDs and complete assembly) for a 2003 A4. Is that something I can swap in place of my current headlights or are the connections different as you mentioned before? The guy is willing to part with the pair for $200 so Im highly considering it if its possible to do so.
    Established Member Two Rings DoubleATO's Avatar
    Jul 14 2011
    Norwich, Connecticut
    Edit: can someone link the way to a 4 port plug that will work for this conversion to a GL? I called LLtek and they are out and will never get the adapter from 12 to 4 anymore. Valero doesn't make it any more according to them.
    Completely Stock. Or is it.....
    Jul 14 2011
    Update: I Installed my Ballasts last night. I had G and the new ones were GL. I took a hack saw to the 12 port plug and cut it into a 4 port. Its easy and a clean way to do it. Just make sure you cut the correct side of the 12 port so that the port and the plug line up with each other because they are indexed.
    Dec 01 2007
    Orange County, NY 10918
    Ok so i did all this today and HID's dont work???? I have 03 S4 Single Zenon's with 12 port plug. My A4 has port plug ballasts. What am i doing wrong to not get them to work. ? When i put them back into my OEM lights it all works. THe S4 lights no worky!
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Are you saying you cut a 12 port plug to work in a 4 port ballast?
    Dec 01 2007
    Quote Originally Posted by PNW Avant View Post
    yes
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    yes
    Shoot! I would double check your connections then, as I think it's well documented that the conversion works.
    Aug 04 2008
    truckee, ca
    I have done this its brilliant and I switched the 12 to 4. Saved me big money, thanks.
    Senior Member Two Rings MaRsTaInAgE's Avatar
    Sep 18 2006
    08 Audi Q7 S line Black
    Normal, Illinois
    Anyone have any resources on going from the 12 wire to the four of the LAD5G to LAD5GL other than hacking it? Thanks.
    Aug 26 2005
    Quote Originally Posted by MaRsTaInAgE View Post
    You can order the 4 terminal plugs for the LAD5GL ballast, without wires. Then carefully extract the red and brown wires from the 12 terminal housing and insert into the 4 terminal housing. If the 4 terminal plugs come with a red and brown pigtail wires, just extract the pigtails and insert the wire terminals from the 12 terminal plug directly, no need to splice the pigtails. Make sure the curved spring contact that bends against the pins, is not to loose, if needed gently add some curve to the spring contact of the terminal for good contact with the ballast pins.
    Apr 21 2012
    DC
    I read you can get your 12 pin ballasts rebuilt/refurbished by this guy Phil (fly300kts). Is there a reason no one is talking about this as a viable solution?
    Established Member Two Rings famguy's Avatar
    Oct 29 2011
    Norway
    Quick question.
    Does anyone know if they have ballasts that fits A4 B5 too??
    Veteran Member Three Rings TwinTipSkier's Avatar
    Nov 18 2009
    2012 VW Sportwagen 2.5S
    Tampa, Fl / Boston, Ma
    5G to 5GL successful! 12 pin to 4 pin. Ecstatic.
    -John
    IG: johns550cc
    | '12 A4 Avant Brilliant Red | Thread |
    | '02 A4 1.8TQMS -gone |
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    for what its worth, just picked up a set of bi xenon housings, restored the lenses, and bought the ballasts and bulbs from HID concept. I know it would have been less if I pieced them together, but $400 shipped for 2 ballasts, 2 bulbs, 2 cables and 12 screws wasn't bad at all, considering I got them all together, and in only two days.
    anyway, thank god for this thread.
    and for anyone who is contemplating going from halogen to xenon/bi-xenon, don't hesitate. Its the best $650 I've ever put into my car.
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Nov 18 2009
    Quote Originally Posted by A4OrlandoB6 View Post
    Yup, I went with HIDconcept as well.
    -John
    IG: johns550cc
    Nov 18 2009
    Guys, help me out. Did the conversion successful only a FEW days ago only to find dipped beam out again today. Pull it out once home, and about a pint of water pours out the back. I know some dough is about to go, IE: new housings, and ballast.
    but
    In a desperate last thought in which not to spend thousands, could a reverse halogen housing swap work? That's how fed up I am.
    -John
    IG: johns550cc
    Veteran Member Three Rings vjborelli's Avatar
    Apr 18 2012
    Boston, MA
    I just had to replace my ballast after getting it wet while washing the engine. $140 after shipping from Wholesalemopar
    Works perfect.
    http://www.wholesalemopar.com/parts_catalog.html
    CHRYSLER - 300
    Part # 5139061AA
    Jan 18 2013
    LOUISVILLE KY
    Quote Originally Posted by vjborelli View Post
    Works perfect.
    CHRYSLER - 300
    Part # 5139061AA
    Is this a 12 pin connector or 4?
    Sep 16 2010
    Central Wash
    Quote Originally Posted by quattrojeff View Post
    It's the 4 pin connector. I just did the swap on one of my Ballasts recently. My 03' actually has the early ballasts orginally. Follow the swap instructions and simply cut your 12 pin connector down to 4 pins and plug it in!
    Nov 11 2010
    Rochester, MN
    Quote Originally Posted by rollerton View Post
    Right on, brother! My early '03 has the 12 pin ballasts, too. I did the mod and now all is well.
    19" B8 S5 Peelers
    Dec 17 2011
    celje
    I'm confused with power input connector. In another thread, they are talking about, 5GL has 6pin power connector. In this thread they are talking about 4pin power input connector on 5GL ballast.
    thread: http://www.audizine.com/forum/showth...using-question
    I have early D2S using 4G ballast (6pin connector). Do i need to replace power plug connector if i buy 5GL . Question mark for 4G on the picture was not answered or is the description on the picture wrong. Very confusing, please clarify
    Sep 16 2010
    Central Wash
    Hmm. Not sure. I don't think many of us have seen a D2S bulb in a B6 chassis. If it's a 4-pin connector then you might be OK, but I'm not familiar with the 4G ballast. You might have to post a picture of the connector to get an opinion here. Or simply go have a look and compare yours to the 5GL ballast pics in this thread.
    Dec 17 2011
    celje
    I'm searching for 4pin power adapter, ETKA says (8E0 971 671) probably direct fit to connect to a 12pin plug harness, other end has 4pin that goes to 5GL ballast). Probably power input adapter to transfer from 5G to 5GL. Can't verify, but clearly is power input adapter for 5GL.
    picture of 4G ballast:
    this is the specification of headlight:
    Checking at ETKA it's like this:
    - 2B (5G ballast), 2C (5GL ballast), 2 (4G ballast)
    - harness from ballast to bulbs is the same for 5G and 5GL (2A - 3D0 971 671 A).
    - harness for power input to ballast 5GL (2E - 8E0 971 671), for 2D ETKA doesn't give you any results
    - 4G ballast, give's result (repair kit), it can be done with 5GL but headlight has 6pin power plug, original you need D2S Igniter bulb holder. But you can swap to D1S
    2B (5G) and 2C (5GL) gives the same part number= part number for 5GL ballast. If i understand correctly the whole thing:
    --- If you have 4G ballast, buy repair kit (costs around 500€),
    --- if you have 5G ballast, buy 5GL ballast and power input harness 2E - 8E0 971 671.
    Established Member Two Rings 16 bit lolitas's Avatar
    Apr 04 2011
    Waco, TX
    Thanks for this thread! I just switched the brown wire on my 4 port and moved it up one spot and connected to the correct spot on the 12 port and it worked!
    (Sorry for bumping an old thread)
    Veteran Member Four Rings jubei4769's Avatar
    Feb 09 2012
    79 VW Rabbit / 09 Triumph Daytona 675
    Kailua, HI
    so i have 12pin ballasts with my oem xenons and just picked up a set of ecodes from europe and they are 4pin. can i repin the ecode plug to accept my old 12pin plug so i can reuse my old ballasts?
    Senior Member Two Rings junxing's Avatar
    May 12 2010
    Chesapeake, VA
    bumping an old thread but I found the LAD5GL on amazon for $100. I just replaced one of the ballast in my car with this.
    http://www.amazon.com/Valeo-088794-I...pr_product_top
    2003 Audi A4 3.0 Avant quattro Atlas Gray/Platinum Gray/6SPD
    -VAG-COM available in the Hampton Roads area
    Senior Member Two Rings KR_A4's Avatar
    Aug 10 2010
    Toronto, ON
    Now all somebody needs are these...
    http://www.audizine.com/classifieds/...and-new&cat=55
    Currently in the middle of restoration for storage.
    APR II+, Forge TIP, Forge splitter, Miltek non res, AWE intercooler, Boxter Brembo BBK, Koni SS coilovers, 034 F+R upper adj control arms + Density lower control arms + full mounts.
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    So I'm crossing my fingers that my right headlight out is just the bulb, but otherwise I can't find a cheap replacement ballast like you guys did in the past. I will do some more looking, but maybe they caught on to what we where doing.
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    I have an lad5gl oem ballast for sale if you need.
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    Advance auto has the ballast online for $157, order online and use discount code TRT30 to get %30 off. Total with free shipping came to $110, same as the Mopar ones.
    Senior Member Two Rings meisladrs's Avatar
    Jul 14 2013
    Huffy 10 speed And rollerblades , dead hipsters
    Denver ,Co
    Europaparts has them for 99 ordered 2 the other week
    Jul 21 2013
    Westchester, NY
    Quote Originally Posted by meisladrs View Post
    My ballasts just burned on my B6 S4. I am looking to order from EuropaParts since they are the cheapest ones out there compared to the molar websites now.
    Did you try them on your headlight? Any issues?
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Bringing this back to the top.
    Have these really gone up to 263$? for the early 2002 12pin, and listing the 4 pin at $424.71 part number 5139061AA
    And can anyone confirm the part number for the early 02 5G ballast, 68019173AA
    There has to be a cheaper place to buy this. The cheapest i found it for was moparamerica for 246
    any help is much apprecaited
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
