Results 1 to 32 of 32
Hybrid View
    Active Member Three Rings DuncanC's Avatar
    Oct 07 2008
    Visit me on EuroAddiction.net
    Edmonton, AB
    Removing B7 headlight
    Any tips for getting the 3rd T-25 that is 6" down a skinny little hole? I went and got a long extension with a small enough bit holder to fit down the hole but I can't get it to line up. You can't see what your doing, your can't get a finger in anywhere to guide it in..
    Can somebody confirm its a T-25 for sure? Any tips at all?
    In, Out and Around...
    Re: Removing B7 headlight
    referring to the one in the blue box?
    if so, iirc i just did this last week or two weeks ago and i used a t30 (extended 7").
    Veteran Member Three Rings NERO Quattro's Avatar
    May 28 2009
    Brilliant Black B7 A4 2TQ
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    I'm pretty sure its a T25 if it's not then it's a T30 I can't remember which one I used. Also be very patient it took me a really long time to get it lined up. Also you don't have to remove the screw just loosen it. If you have really skinny arms and hve the bumper off you might be able to reach up from underneath and guide it. Watch out though my friend got cut up a bunch trying to do it. I would just try your best to have the extension go straight down, and you can feel when it is on top of the screw or not. Be patient you'll get it eventually
    Oct 07 2008
    Edmonton, AB
    Its the blue one. And that is the DIY I've been following.
    I still haven't been able to get it.
    are you just removing the bumper or the bumper and headlight?
    Oct 07 2008
    Edmonton, AB
    Bumper is already off.
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    you can also use a really long flat head, as long it fits
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    Quote Originally Posted by ngng View Post
    Ding-Ding...
    That's what I use.
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
    Established Member Two Rings diablooffire03's Avatar
    Jun 21 2008
    N. New jersey
    It wont ever come loose using a t25... Try using a t30 because thats what size it is. I just took mine out the other day and shipped them to our pal that made the DIY for the leds.
    05.5 Audi S4
    01 Lexus IS300 Turbo
    08 IS250AWD SOLD
    94 6spd single Supra SOLD
    Oct 07 2008
    Edmonton, AB
    Baa.. I'm quiting for today and going to drink beer and watch hockey. I was hoping to get it done in two days but unless tomorrow's battle goes better I'll be at it for 3. Got the bumper off, Airbox out, Maf removed, Coils removed, Intake Manifold unhooked and unbolted but left in place so no dust can get into the heads overnight. If I could get the headlights out and slide the rad forward I would be in ok shape.
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by DuncanC View Post
    what are you trying to do?
    if you can't get that bolt, take one of the bolts you've removed to the store, find a long ass flathead that fits and use that
    Oct 07 2008
    Edmonton, AB
    I'm in the process of:
    -Headlight mods (LEDs and resistors)
    -Intake spacers
    -LW Crank Pully
    -Snub Mount
    -Valve cover gaskets
    I have given up on my current tools and will be buying a long ass flathead in the morning.
    Mar 09 2005
    Santa Clara, CA
    -Intake spacers
    -LW Crank Pully
    -Snub Mount
    oh damn, have fun with that. lol, i did all of those with the front end off and it was a still a pita. make SURE you have the triple square, and not torx bolts or you WILL strip your crank pulley bolts
    Established Member Two Rings NudarkshadowlL's Avatar
    Mar 10 2009
    07' Daytona RS4
    Scottsdale, AZ
    In order to do the clear corner mod, is it really necessary to remove the bumper? I mean is just the three torx bolts and then the harness holding in the light housing right?
    yes. you have to remove the bumper.
    Oct 07 2008
    Edmonton, AB
    Removing the bumper really isn't as big of deal as you'd expect. It comes off no problem. Took longer to get the car on jack stands and the wheels off.
    Oct 07 2008
    Edmonton, AB
    I love AZ. Thanks guys! Got a long flathead this morning. Took the grinder too it so it fit in a T-25 perfectly. (yes, they were T-25s on my car not T-30s) and bang, done is 30 seconds.
    Headlights are out!
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Headlights are out!
    Necro bumping this thread to say thanks for the tip on the long, skinny flat head - after 1.5 hours of dicking around with taped together socket extensions and wobbles and whatnot, I went to Sears and grabbed the longest, thinnest screwdriver they had for like $4 - worked on the first try, I didn't even have to grind down the screwdriver head, and had both headlights off in <2 min. That third bolt is such a PITA, but actually very easy with the right tool!
    Current: 08 R8 6MT, 14 Cayenne GTS, 98 Saleen XP8
    Past: B7 RS4, '12 Audi TTRS BT Build | 2006 Audi S4 HPDE Build | 2006 Audi A4
    Visit my blog: NicksCarBlog.com
    Veteran Member Four Rings blai76's Avatar
    Aug 25 2011
    planes, trains and automobiles.
    San Francisco, CA
    Quote Originally Posted by nnnick View Post
    I did the same thing one afternoon, and ended up losing a bit in the recesses within that hole. My blue tape job failed me .
    I ended buying the following on ebay for $17 that evening several months ago, to get the job done:
    SK tools T-30 X 5.92" Suregrip Torx Screwdriver
    $17 is a lot for a single driver, but hey its SK! Needless to say, if I knew I could grab a $4 skinny long flathead from Sears that very evening though, I would have happily gone that route...
    Bob
    2008 B7S4tip Avant, 1998.5 B5A4tip 2.8L V6 (retired)
    Jun 18 2009
    Phoenix, AZ
    ^^^ Yup, was just going to post something like that. I got this years ago when I had my B6 S4 - http://www.craftsman.com/craftsman-p...p-00947214000P
    It's the perfect length for that last headlight clamp screw, and I use it a lot. And yes they're all T30's.
    2017 Camaro SS 1LE
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Quote Originally Posted by FWP! View Post
    Ohh, that is baller being T30. Mine was just the Craftsman Cabinet Tip Screwdriver 3/16 x 8-IN - only like $4 and they had it in stock at the Sears by me, worked like a charm, but might pick that bad boy up just to round out the collection of insane parts only Audi would require to do simple maintenance like accessing the headlight bulbs :P
    Jun 18 2009
    Phoenix, AZ
    lol, it's ALWAYS in my tool kit when I go to work on the car.
    2017 Camaro SS 1LE
    Aug 25 2011
    San Francisco, CA
    Ditto! That, and a 16" extension to a wobble joint to a 10mm deep socket, for taking the bumper off, lol.
    Bob
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Quote Originally Posted by blai76 View Post
    Ditto to that as well - I leave that in my car on the passenger side door in that little cubby near the bottom #b7problems
    Oct 07 2013
    Bellevue WA
    Can someone clarify for me if I need to remove the front bumper just to swap out the drivers side headlight unit for mt B7 RS4? My current unit is fogging up with water vapor so I assume I need to replace the entire headlight unit. Two of the torx screws are easy but that third one down the skinny shaft is near impossible to get to. Is bumper removal necessary to continue?
    Veteran Member Four Rings eurojunkjon's Avatar
    Mar 12 2017
    2013 S4
    Burlington, wi
    Quote Originally Posted by zhaniaudi View Post
    It does but it’s super quick and easy to get it off
    Nov 12 2015
    Oregon
    Grab yourself either a long 3/16 screwdriver or a long T30 screwdriver and loosen the bolt that way. You will need to move the bumper forward at least a little bit in order to get out the headlight so you might as well remove the bumper all the way. It only takes a few minutes once you figure out what bolts are supposed to be taking out.
    There are two or three that hold the bumper to the fender and you need to get them though the fender liner. A couple T30 bolts up top and the bumper comes off.
    Sent from my SM-N920V using Tapatalk
    My build log
    Oct 07 2013
    Bellevue WA
    Quote Originally Posted by VinnysS4 View Post
    Tempted to give this a try. One man job? Does the front need to be lifted up?
    Nov 12 2015
    Oregon
    Front only needs to be lifted if you have bolts on the under side holding it up. Like a skid plate. I do it myself without help. It's nice to have help tho. 2nd set of hands are always good.
    My build log
    Veteran Member Four Rings Jdsb6s4's Avatar
    Aug 27 2016
    GL450, GLA250
    Schwaben sells some great tools for the job.. check out ECS
    AM Tuned Supercharged Audi S4 Avant track car. Under Construction
    Tuned by Jackal Motorsports
    Time Attack driver
    jasons__s4 IG
