Results 1 to 13 of 13
Hybrid View
    Oct 05 2009
    Help! I lost my mailbox key INSIDE my car :(
    I was holding to my mail box key when it accidentally slipped in between the "Coin holder compartment door" and the Vent system.. as shown
    I basically need to remove the "door" to get back my Key. Any ideas what I should do ?? :(
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    Re: Help! I lost my mailbox key INSIDE my car :(
    you have to remove your radio then ac controls and last your whole ash tray unit
    Oct 20 2008
    Denver
    Quote Originally Posted by plokm View Post
    x2
    remove the HU and then remove the climate control. then pop off the gear shift cover and you'll see 2 bolt screws. remove those and the whole cig. lighter/assembly will come out.
    GL
    Oct 05 2009
    holy crap... i must not put stuff there around that area next time.... arghh!!!
    Is the AC unit easy to take out once the radio is out ? Or do I need keys (like the Radio keys)
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by gizmo99 View Post
    the HU is the only thing that's held down, everything else pops out gently.
    Veteran Member Three Rings kharsnett's Avatar
    Oct 24 2006
    Indianapolis IN
    i knew where the key went even before i opened this thread lol sorry about your luck
    B7 A4 Non sline Sline Edition, High flow fog light holes, Titanium license plate screws, Cross drilled lug bolts, greasy axle, Coolant relief valve on cylinder head, Pressure relieving boost hoses, Cylinder Head Exchange program, Custom cam grind, used fuel pump follower, variable geometry front Control Arms, Automatically shifted manual transmission, 87 octane APR tune, detuned 83 Octane APR tune, Custom high flow Flex section, Custom built spark plugs, Ebay sponsored!
    Jun 01 2008
    Apopka, FL
    X3. When I first did it during a heater core replacement, there were 50million personal cards stuck in there. Which is probably why it wouldn't open up by itself.
    Oct 20 2008
    Denver
    once you remove the HU with the "radio" keys you can just reach back and pop the climate control to the front. comes out just as easy
    Feb 19 2007
    Louisiana
    You might can try removing the trim then unscrew the two bolts and slide your hand in the crack the get the key
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    you must remove the headunit with the radio keys,then the heating and air unit,then if its really deep inside you must remove the ashtray....
    Oct 05 2009
    Here's a write up of what I did, hope someone will benefit from this. 10 minute job
    1) Get your ratchet ready,
    2) Insert Radio Keys and pull radio out
    3) Remove Gear box Trim (easily pops out) so that the bolt is revealed.
    4) remove the two bolts on each side
    5) Push out and remove the Air Control Unit
    6) I had to hold up the raido + Ac Unit with one hand [its better if you get a friend]
    7) with the Ashray door open, pull out the ashtray
    8) shake the ashtray in place [with wires connected] so that whatever gets stuck comes out
    9) try not to put small objects in that area again
    DUH! an Audi
    los angeles, CA
    awesome!
    Senior Member Three Rings crew's Avatar
    Oct 02 2009
    1966 Mustang, 1988 F150, 2006 A4 2.0t (SOLD), 2013 Focus ST
    I managed to remove and replace the ashtray without ever touching the radio or HVAC controls.. if that helps. It's just patience, maneuvering and steady pressure. I know, that's what she said.. haha
    -Matt
    Quattrophenia (PSN)
    flickr
    MTN Custom Leather
