Results 1 to 24 of 24
    Established Member Two Rings esee135's Avatar
    Jun 21 2008
    B5 Vacuum Line Simplification DIY???
    Is there a vacuum line simplification DIY for the B5? Would it be the same as the B6? Just did the timing belt and the I have ALOT of ratty looking vacuum lines. Wouldn't mind simplifying the system a bit and lose more than a few check valves.
    Senior Member Two Rings BLK_A4's Avatar
    Dec 22 2008
    Fox River Grove, IL
    Re: B5 Vacuum Line Simplification DIY???
    This should help. http://www.audizine.com/forum/showthread.php?p=2877619
    I have done this to my engine bay. If you have any questions you can just PM me : )
    Senior Member Two Rings VirginiaBeachA4's Avatar
    Mar 15 2009
    Virginia Beach, VA
    Quote Originally Posted by BLK_A4 View Post
    off topic but you do notice that "friends" is spelled wrong in your sig right?
    '99.5 Jaspis Green (Minty) 1.8TQM
    - Forge diverter valve
    - vmaxx
    - Merc Alphards
    - resonator removed
    - K&N cone filter
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Quote Originally Posted by VirginiaBeachA4 View Post
    LOL , damn I cracked up so hard reading that
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings Coopa's Avatar
    Apr 20 2009
    gpz550 kz650 cafes
    Longmont, Co.
    Is there a permanent way to make the cel go away after this?
    Senior Member Two Rings RockyMountainB5's Avatar
    Nov 01 2009
    Boulder, CO
    Quote Originally Posted by Coopa View Post
    Somone with tuning software can do a Hex-edit on your ECU's flash memory to remove (really set to 0) the blocks of data that pertain to checking your emissions systems. If you simply remove the checks for the SAI and blah blah, the ECU assumes they are working and moves on - no CEL. You can delete checks for the oxygen sensors too.
    You can also pass emissions this way after doing a SAI/PCV delete - you just need a tuner to set "readiness" on your ECU.
    There is someone on audizine who says "set readiness on ECU $50" in his sig, thats what you want.
    2001.5 A4 1.8TQMS
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    IIRC his username is: k0mpresd - but he changed his signiture recently, just shoot him a PM to check
    Veteran Member Three Rings jsquillz22's Avatar
    Feb 22 2009
    b5 s4
    Chicago
    oooo burrn!!!
    hey buddy how them coils?
    OEM+
    Who Cares?
    Mar 15 2009
    Virginia Beach, VA
    Quote Originally Posted by jsquillz22 View Post
    oooo burrn!!!
    I wasn't trying to offend him.
    The coils are awesome. They don't feel as bouncy as everyone says they are.
    - vmaxx
    - Merc Alphards
    - resonator removed
    - K&N cone filter
    Feb 22 2009
    b5 s4
    Chicago
    i know the guy lives by me hes pretty cool.... his car is/was my twin! except he has brilliant black and i was rockin the ebony!
    an im glad u liek em
    OEM+
    Who Cares?
    Veteran Member Three Rings discontained's Avatar
    Jul 09 2007
    '01 A4 1.8t
    GA
    So I did this today. I got tired of replacing check valves and vacuum lines.
    Do have a question. I took the EGR off, and welded the hole shut (on the EGR bracket, not the block. lol) I didnt feel like spending $30+ and waiting for a part . I noticed my rear coolant flange is leaking coolant all over my transmission. Is there a way to fix it, or wouuld I need to buy a whole new flange? I know there cheap i think -/+ $10?, or is it just a bad o-ring. ( iknow thats off topic so let me get back on)
    I read most of those links on the DIY but got confused. The Oil breather ontop of the oil filter hosing, that line T's with the valve cover and dumps to the atmosphere or does it need to be sealed? Also the DV valve can i leave the line that goes from the DV to the TIP to atmosphere? It sounds hella cool when i went to the store to get some parts.
    For Sale $3,500 -'99 Audi A4 1.8T Quattro 5sp
    -2001.5 Audi A4 1.8T Quattromatic - BT .50 trizzle -RIP
    Oct 08 2007
    Jersey City
    you might need to replace the flange bc the plastic tends to warp etc form all the heat but the O-ring may not be seated correctly or it just needs to be replaced. Check out the link below - i wouldnt use silicone like the one guy said
    http://www.audizine.com/forum/showthread.php?t=328706
    i replaced my flange & O-ring during the summer, sanded the back of the block & been good ever since
    Jul 09 2007
    '01 A4 1.8t
    GA
    Quote Originally Posted by thenofjboy View Post
    ahh i must have missed that thread lol. Thanks man..
    Nov 01 2009
    Boulder, CO
    Quote Originally Posted by discontained View Post
    I think this means you are venting the excess pressure in your lines to atmosphere instead or recirculating it - same issue as the BOV, if you dont recirculate at least some of the air the car wont run right - although i have no idea what tune you are running.
    2001.5 A4 1.8TQMS
    Registered Member Four Rings
    Aug 10 2009
    Manassas, VA
    Quote Originally Posted by RockyMountainB5 View Post
    Question about this....could you make your own splitter valve by just putting a T in going to TIP/atmosphere?
    -John
    BAT B6 A4: GT3582, built AEB head, supertech hardware, inconnel valves, port and polished, IE rods, Spa manifold, Fully rebuilt 01E with JHM kit, s4 drivetrain, custom 3" exhaust, Bilstein PSS9, 3.0L A4 brakes, and the list goes on..
    Waiting to install: S4 Rear Bumper, B6 S4 Rear Brakes, 18z front calipers, USP front lip, USP Door Blades, Black Interior, JHM Short Shifter
    Looking to buy: 034 Rear Swab Bar + End Links, Black S4 Recaros, S4 Door Blades, Black B7 Center Console
    Jul 09 2007
    '01 A4 1.8t
    GA
    I dont have TIP anymore :D!
    The hose that runs from the DV to the TIP is still hanging there. I drove it arouund today and it seems like 5% faster, I am on GIAC tune. It sounds pretty cool ha, i gotta get a video of it.
    Veteran Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    should be doing this soon...just gotta find time between school and work 7 days a week.
    Dec 22 2008
    Fox River Grove, IL
    Oh haha god i feel like an idiot!! Thanks i will change that now. . But jsquillz when is the k04 going in? I wanna see how much more power you make.
    Feb 22 2009
    b5 s4
    Chicago
    maybe if you pick up your phone!
    OEM+
    Who Cares?
    Oct 08 2007
    Jersey City
    any point in still keeping that hose then? maybe put a mini filter on the DV......i dunno haha
    Jul 09 2007
    '01 A4 1.8t
    GA
    lol thats what im trying to figure out...
    Nov 01 2009
    Boulder, CO
    Well, i was trying to say that your ECU thinks that air is being recirculated - i have heard of people running BOVs at 100% (essentially what you are doing), and it causing all sorts of CELs and rough running. But if it works.....then more power to ya. I believe that the standard was to run the line coming from your DV back into the TIP, however.
    Since you just did this i have a question.....Did you attach your intake manifold rear bung to your brake booster, and what affect did that have on the feel/strength of your brakes?
    2001.5 A4 1.8TQMS
    Oct 08 2007
    Jersey City
    i gots a 98 - so i don’t have much crap at the back of my manifold like you other guys do with the 01 models but either way that line that connects from the back of the manifold to the brake booster is very important - it shouldn’t be touched.
    when i removed all that mess & check valves, i capped the port on the side of the intake manifold near the TB & the port on the bottom as well but i left the one on the back of the IM attached to the brake booster (thers a type of check valve in that hard line)
    Jul 09 2007
    '01 A4 1.8t
    GA
    To answer in bold.. I didnt feel much difference, I just put new pads on the other day and they feel.. less spongy. However it could be my mind playing tricks on me!
