Results 1 to 7 of 7
    Veteran Member Four Rings e.van's Avatar
    Mar 09 2004
    1999 A4 Avant 1.8T quattro, 1976 BMW 2002
    Cleves, OH
    Manual Auto Code WTF?
    Okay I know I posted my CEL came on Saturday. I took it to work today and ran it through the OBD reader.
    Came back with the following code.
    ECT / Performe Sensor
    My boss told me this is a sensor on automatic transmissions , and even if it weren't, my tranny still works perfectly fine.
    1999 Cactus Green A4 Avant 1.8TQM
    Black DEPO eCodes | 3000K & 4300K HIDs | City Lights
    Dual-Rear & Front Fog Mods | 1-Touch Windows
    LLTek Mesh Grille | 710 N | Dump-Truck Exhaust
    OEM B6 5-Spoke Wheels | Neuspeed Race Springs
    I think it's obvious that I don't care how fast my car is.
    Jun 04 2004
    fairfield cnty, CT
    Re: Manual Auto Code WTF?
    Umm what was the numeric code it gave?
    and the "ECT" ususally means "engine coolant temperature" sensor.
    Mar 09 2004
    Cleves, OH
    I don't remember the number. I cleared it and it stayed off, so it's no longer a problem.
    Registered Member Four Rings
    Mar 05 2004
    '98 A4
    Lil Titz, Pennsltucky
    I'm guessing that the code was probably P0116 which is for engine coolant tempurature circuit range or performance. Your boss is a moron. Take off the coolant temp sensor and clean it off. Sometimes that can take care of the problem for a while. When that part goes bad however, it will leave your car sitting with you not being able to start it.
    You should never delete a code until the problem is fixed. It is still a problem.
    Any other questions, come here first, not to your boss.
    Mar 09 2004
    Cleves, OH
    It was that code I think, where is the coolant temp. sensor located / what shape does it have? BTW thanks for the info.
    Jun 04 2004
    fairfield cnty, CT
    here:
    http://www.audiworld.com/tech/eng47.shtml
    Mar 09 2004
    Cleves, OH
    Thanks a kagillion! Temp hasn't really been erratic between cold and normal, but it usually doesn't heat up to normal unless it's at idle.. Guess this'll fix the problem.
