Results 1 to 9 of 9
    Jun 22 2009
    Dundalk, MD
    Random BAT/OEM Performance Stuff for A4&S4
    Ok, here goes... I have
    (for A4)
    - about 4 feet of -10 Braided AN line
    - (1) -10 fitting for making oil return line
    - (1) 3" V-band assembly
    - (2) 2.25" V-band assemblies
    - (1) 01A Slave Cylinder
    - (1) B6 A4 Fuel Pump (basket not included)
    - (1) Tial 44mm WG input flange
    - (1) 2.5" Silicone 90 degree elbow
    - A bunch of 2.5" IC piping, clamps, silicone couplers
    - 2.7T Throttle Body
    - B5 S4 calipers/lines/pads
    (for S4)
    - (1) 2001 A6 2.7T Auto ECU
    - 2.7T Valve Cover Set
    - 2.7T Intake Manifold
    - 2.7T Y-pipe
    Senior Member Three Rings Chopstixs's Avatar
    Jan 22 2008
    2.8 Single Turboed A6/2011 Tahoe
    Va
    Re: Random BAT/OEM Performance Stuff for A4&S4
    Quote Originally Posted by Clint@R.A.I. View Post
    (for A4)
    (for S4)
    - 2.7T Y-pipe
    Stock Y pipe or bi-pipe
    Damage on valve cover set?
    Through out the years, People have used "Chopstix" to eat rice.........I do the same.
    C5 UNION MEMBER
    Jun 22 2009
    Dundalk, MD
    No damage I can powdercoat them for you, stock Y-pipe I can sandblast that as well
    Mar 02 2008
    Baltimore ,md
    You do powder coating there too?
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Hey Clint, how much for the S4 throttle body?
    Some fast things and some slow things
    ~Josh~
    Jun 22 2009
    Dundalk, MD
    David picked it up already
    Oct 15 2006
    From a couple to a few...
    Arlington, VA
    how much for the b5s4 calipers/lines? looking for my 3.0 cab.
    '02 A4 1.8TQ Avant
    Pioneer AVH-4201NEX
    '03 A4 1.8TQMS
    APR TIP/TB Hose, 034 RSB/End Links/HFC/Snub Mount/Rear Diff Inserts, Milltek Exhaust, Forge 007P DV, Valeo HD w/ SMFW, Bilstein/H&R, B6S4 F+R Brakes, Hawk HPS, TT386, Revo Stage II, STE PPD
    S4 Side Blades, Aero Wipers, RS4 Pedals, OEM HID, DIY Plasti-Dip Grill, Pioneer AVH-4201NEX, VMR701
    '04 Suzuki SV650
    Jun 22 2009
    Dundalk, MD
    Hey Byrav I'll do $220 if you can pick them up . I'll even drive down and meet u on the way
    Oct 31 2005
    Virginia
    Ok, thanks...If you ever happen to stumble across one let me know, I'm always looking for a spare.
    ~Josh~
