Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 286
  1. #161
    Veteran Member Four Rings A-BlacK_MambA-4's Avatar
    Jan 22 2011
    '05.5 A4 2.0T Tip Revo Stage 2; Wifes 2013 Chevy Cruze
    Ohio
    Quote Originally Posted by bryonm View Post
    I'm surprised that no one has thrown in a water pump DIY in this thread as well considering the two basically go hand in hand with the same time both are recommended to be replaced
    I'm more surprised you asked for a water pump DIY in this thread lol. You need someone to show you how to remove 3 allen head bolts after you've just dismantled the whole front end and have those 3 bolts and water pump right in front of you?
    -JOEL
    The Real Black Mamba
  2. #162
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Typically people do not change the water pump without doing the full timing belt job at the same time.
    Because timing belt kit: http://jhmotorsports.com/shop/catalo...0t-p-1212.html
  3. #163
    Senior Member Two Rings bryonm's Avatar
    Jun 02 2013
    Mililani, Hawaii
    Quote Originally Posted by A-BlacK_MambA-4 View Post
    Haha hey man I'm just speaking for other people if they didn't know where it's located once you get through all of that.
  4. #164
    Jun 15 2010
    London, Ontario
    FYI, if you need/want to remove the entire front end to access the six bolts (or when the last one strips out on you...) on the damper you do not need to evacuate the AC. If everything else is disconnected you can (carefully) rotate/slide everything else down under the engine.
  5. #165
    Established Member Two Rings eastons41's Avatar
    Jun 28 2014
    2007 Audi A4 S-line
    NC
    Not sure if anyone will know the answer to this one; however, I could possibly be moving to Germany by the end of the year (taking my b7 with me). The car has 57,000 miles and was wondering would it be cheaper to have the timing belt replaced here in the states or after she makes the trip over seas?
  6. #166
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    I would find a forum that is based in Germany, a regional forum for europe here (not sure one exists), find someone at Rammstein air force base, or just ask your local audi dealer to reach out to a dealership in germany.
    Cheapest? DIY. It really isn't that bad. I HAD to do mine in Dec/Jan when my tb broke. Trust me, you don't want that option.
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
  7. #167
    Aug 29 2013
    '06 A4 2.0T 6MT, '11 Q5 2.0t, 99 A6 Quattro Avant, 95 F-150, 73 Opel GT
    MA
    Quote Originally Posted by ClownTrigger View Post
    Thanks, and yes, they're M8x1.5 thread. Something to make your procedure a little simpler...
    Could someone please clarify the thread and pitch of the carrier lock pin slide bolts. M8 x 1.5 is an bit oddball size/pitch. I believe the OEM slide pins are # VAG 3411, and M8 x 1.25 and 10 inches long (8 mm and approx 250 mm long).
    I had zero luck locally finding any threaded rod in metric let alone M8 x 1.25 so I ordered 2 of these from Amazon ( http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 ) They haven't arrived yet, but I will update here once I can test them.
  8. #168
    Established Member Two Rings mjfrizz's Avatar
    May 06 2010
    St. Louis, MO
    Just wanted to say thanks to you Phil, and to everyone else, for all the tips & techniques. I have the Bentley manual, but this was still an enormous asset. Just like the 1st time I did this, I spent nearly half my time trying to get all the hoses apart.
    I wish I could get it done as fast as the rest of you guys, but then again, I quadruple check everything, and I have a blast doing this, so I take my time an soak it up.
    Biggest B!%$# was that thermostat, I remember it being easier on the B6.
    Happy New Year
  9. #169
    May 06 2010
    St. Louis, MO
    One question in case anyone can confirm... So u only loctite the timing belt cover bolts? The nut for the eccentric pulley and the other timing component attach hardware need no loctite? For some reason I thought when I did this on my b6 more stuff needed thread locker. thanks in advance
  10. #170
    Oct 16 2008
    South Florida - Ft Lauderdale
    Quote Originally Posted by mjfrizz View Post
    Correct, covers only
    Happy new Year too
    Phil
  11. #171
    Veteran Member Three Rings audi8844's Avatar
    Jun 17 2009
    Maryland - Eastern Shore
    If they were triple square, its because the timing belt was already replaced or some work was done to the pulley.
    Original were HEX and Audi upgraded them to triple square
    Phil
    What size is this triple square? It looks like I need to order a bit for these...
    Jordan
    2008 A4 2.0t Quattro - JHM Stage 2 93oct, JHM HPFP, JHM TP & DP-Y, B7 S4 CB, KW V1s, RS4 Rear Sway, 034 Snub, 034 CC, Podi Boost
  12. #172
    May 06 2010
    St. Louis, MO
    Quote Originally Posted by audi8844 View Post
    That'd be 10mm trip square
  13. #173
    Jun 17 2009
    Thought so. Thanks!
    Jordan
  14. #174
    Jul 18 2012
    bridgewater, NJ
    this is crazy audi would not take all this apart for a timing bely, the more you take apart the more you break, the longer the job. I don't have a plane to use while my car is apart. Just do your home work and follow the min procedure (like don't remove the AC freon!)
    I followed another thread to replace the rear coolant flange, it was a 12 hr procedure, it is maybe 1.5 hours to do the job no need to remove vacuum pump, wiring looms, new hoses. I did not follow the user who said 2hrs... I took the defacto "worse than a timing belt approach" = 12 hrs.
  15. #175
    Senior Member Two Rings _muppet_'s Avatar
    Mar 22 2009
    Clarion PA
    I did my timing belt/ water pump/ and thermostat last night. I haven't bought a service manual for this car yet, as I haven't had the need to yet, this thread was very helpful. The job went smoothly, except I had to take the hard pipe off the thermostat one extra time when it was all back together, because it was dripping, I put a new o-ring on and all is well. I've had the kit sitting on a shelf for almost a year now. Since winter got here, my car hasn't been warming up all the way, so I thought it was time to do the thermostat.
    I bought this car with around 80k on it from a dealer and there was no mention of the timing belt ever being done. The car fax showed pretty frequent servicing at the dealer, and all of the prior service intervals had been marked in the book. When I took the cover off, I saw two little paint marks on the cam gear, and one on the crank pulley, and a couple specks of paint on the belt. I assume this means the belt has probably been changed in the past? I've never seen this on an original belt before? The car is now at 107k, and I thought I was probably pushing the limit. Either way the thermostat needed to be done, and the belt really isn't that bad to change, or that expensive, so I'm glad to have it done and know for sure that it should be good to go for a while.
    old belt marks
    new belt, and new snub
  16. #176
    Oct 18 2011
    2005 B6 A4 3.0 CVT, 2009 B6 A4 3.0 CVT
    Memphis
    Release hood latch cable help
    Working on the timing belt change and I've hit a bit of a snag. Phil's guide says to release the hood cable. Exactly how does one do that? I've looked and looked and can't see how to release the cable. Does the latch have to be unbolted and removed first? Any special trick. I've looked at Bentley and it didn't really help me understand it either.
    Thanks,
  17. #177
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by wesalexleft View Post
    Thanks,
    It just pops out. No bolts necessary. Pull out and back a little and it'll come out
    :: Seller feedback ::
    RIP: 2006 DG Avant Tip
  18. #178
    Oct 18 2011
    Memphis
    Huge shout out to Phil for the DIY!
    Hoping for opinions on one more step of the timing job however. Mine is an automatic. (Why they built them I'll never know, but I ended up with one.) So, I'm in service position, but I'd like to swing the nose to one side. My problem is on the passenger side, I have transmission fluid lines in the radiator, and on the driver side I have power steering fluid lines. It seems like everyone swings it to the driver side like Phil. Any reason I shouldn't remove the power steering cooler and plug the liners to swing it the other way? I don't see any other obstacles. These lines look easier to disconnect, plug, and easier to replace lost fluid. I've already dropped the AC evap to below the car, and don't want to try and set the nose on top of that.
    Mar 22 2009
    Clarion PA
    I thought there was plenty of room in service mode, but if you really want it out of the way, I don't see any reason that you couldn't disconnect the power steering lines.
  20. #180
    Oct 18 2011
    Memphis
    I'm so close to having full access, I figured the extra step might be worth it. Just wanted to be sure there wasn't something else I was missing before swinging it the other way. It looks like the transmission lines have enough slack to leave them connected.
    thanks,
  21. #181
    Oct 18 2011
    Memphis
    where does garage opener transmitter go?
    Putting the bumper cover back on. All was going well until I saw a wire that I forgot to reconnect. I believe it's the garage door opener transmitter. I'm hoping someone can tell me where this belongs so that I may have a chance of getting it back in place without complete bumper removal. Of the three electrical connectors if Phil's pictures, it's the small round gadget that has a white with yellow stripe and a brown with yellow stripe. It is NOT THE 4 pin connector, or the 8 pin connector, or the washer fluid connector.,but the remaining one. Last resort is I relocate it, but I'd like to put it in place if possible/reasonable.
  22. #182
    Oct 18 2011
    Memphis
    Bump for the new day...is this the Garage Opener transmitter, and if so, where should it go?
    thanks!
  23. #183
    Aug 18 2009
    A Unicorn
    Portland, OR
    It's the ambient air temperature. There is a little bracket in front of the radiator that it snaps into. On top of the little power steering cooler loop
  24. #184
    Aug 31 2011
    Lathrop
    x2
  25. #185
    Oct 18 2011
    Memphis
    Thanks! I took a quick look at lunch, and with the right tools, I think I can get it back in place without removing the bumper.
  26. #186
    Established Member Two Rings frankvan's Avatar
    Feb 08 2012
    B9 S4, B7 RS4, B8 A4, Cherokee, Sprinter Camper, Volvo XC60 T6, Ducati Panigale
    St. Albert
    Half way through this and i have to give a big thanks to Phil for this DIY. Total lifesaver.
    Only problem I've had is I destroyed the small coolant line that goes across the front of the TB cover to the turbo.
    And just to add my $0.02:
    I unplugged everything from the top of the front clip and removed intercooler hoses, rotated it under the engine slightly and supported on a block. This gave me 100% visualization of the 6 crank pulley bolts. Only thing I drained was coolant which I have to anyways since I'm doing water pump and thermostat.
    Speaking of draining coolant, I twisted, turned, pulled, pushed the drain cock at the bottom of the rad to no avail. In the end just removed the metal clip and disconnected the bottom hose, drained real quick then.
    My 6 crank pulley bolts were Allen head not triple square (2006 B7).
    Only other issue I've had is the hard metal line on the thermostat.
    BTW, should I be concerned with a little oil in the intercooler lines? It's a low point in the system so any that blows by would settle there.
  27. #187
    Aug 29 2013
    MA
    Quote Originally Posted by MadhatterPDC View Post
    I forgot to loop back and confirm that those threaded rods worked great. So there you have it, M8 x 1.25 and I will mention that those rods weren't very strong... but that worked out perfect once I disconnected everything across the top, the nose then swings down and gives you great access. Of course, if the six crank pulley bolts don't give you any trouble, I could see this job being done with only moving the nose forward 3-4 inches.
    My current daily: 2006 A4 Quattro 2.0T with 6MT and OEM Sport Suspension
    Wife's daily: 2011 Q5 2.0T
    Beach Car: 1999 A6 Avant Quattro 2.8
    RIP: 1995 A6 Avant
  28. #188
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by frankvan View Post
    Did mine yesterday and was about to post the same thing. Mine turned fine, 0 coolant came out so I just pulled the hose.
    Ditto. I think they were 6mm Allen?
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
  29. #189
    Feb 08 2012
    St. Albert
    Yup, 6 mm.
  30. #190
    Active Member Two Rings Anton's Avatar
    Sep 15 2012
    North Jersey
    Did the belt today with the Europaparts kit. Everything worked fine . We got stuck and spent the most time on the hoses. Removing those three from the thermostat took a bit of time, mostly the middle and lower, with the middle being the metal line. The actual timing piece was very straightforward and we looked at Phil's DIY for a reference but nothing to tricky with these engines.
    Right before I went to change the belt, sounded like my exhaust fell off. Sure enough checked afterwards and the clamps in the middle that hold them, one of the pipes coming from the cat was just hanging, just rust all over :(. Will have to look into this tomorrow.
    http://s288.photobucket.com/user/Ant...1b3ma.jpg.html
    http://s288.photobucket.com/user/Ant...hhel6.jpg.html
    http://s288.photobucket.com/user/Ant...dpeeb.jpg.html
    http://s288.photobucket.com/user/Ant...8nmd8.jpg.html
  31. #191
    Apr 28 2013
    Hamilton Ontario
    Is it nesisairy to disconnect battery to unplug impact sensors on bumper?
  32. #192
    Sep 15 2012
    North Jersey
    Quote Originally Posted by VEEDUBB1 View Post
    I did not disconnect the battery at that point but I did after taking the alternator off because you have a positive line from the battery and causes a nice spark if you touch it with any of your tools
  33. #193
    Mar 05 2014
    Connecticut
    Wow Phil... I cannot thank you enough for this amazing write-up!! I owe you a beer somehow.
    Smooth sailing all the way through with only a couple minor snags:
    - My lack of proper tools that I had to purchase along the way
    - Top coolant hose on thermostat was difficult to get off that metal pipe. Had to destroy it to remove it and wait for a new one to arrive. Good thing we have an extra Audi!
    Steve 2013 Audi S4 || 2007 Audi A4 2.0TQ 'vert || 2004 Volvo XC90 2.5T AWD || 1994 Saab 9000CSE NT 5spd.
    Past: 2003 Audi S8 || 2002 Audi A4 1.8TQ 5spd || 2000 Audi S4 6spd. RS6'd! || 1992 Audi S4 w/ B5 6spd. || 1987 Porsche 951 || 1994 Saab 9000 Aero 5spd.
  34. #194
    Oct 16 2008
    Quote Originally Posted by QuattroPower88 View Post
    I am up for the beer and you are most welcome, glad I was able to help
    Phil
  35. #195
    Senior Member Two Rings brew_daugus's Avatar
    May 28 2013
    PA
    Big thanks to Phil for the DIY and Europaparts for the kit. Those who did this in the service position without at least rotating the front end under the car I commend you. No way I was getting the crank pulley bolts otherwise. Interesting note, if you strip the head on one of those crank pulley bolts, don't sweat. Drill the cap off and it will unscrew by hand (ask me how I know). Also if you killed a power steering pump this winter like I did then this is a great time to do it, especially if you moved your alternator.
  36. #196
    Senior Member Three Rings 4ty-phive's Avatar
    Jun 12 2009
    Stay tuned...
    Chesapeake, VA
    I just finished mine about an hour ago. I'm so proud of myself. Thanks for all the assistance that this community provides. Awesome feeling.
  37. #197
    Established Member Two Rings Supersquid's Avatar
    May 23 2014
    Olympia, WA
    First, thanks SO much for the outstanding tutorial!! This community is a wealth of info. Hope to contribute in the future. For the now, though...
    Got some time to start this job last night. Stopped just short of completely removing the front end.
    Might have to suck this one up, but I'd like to completely swing the carrier (as Phil has done) to have the best access. How are you guys dealing w/ the air conditioner hose on the lower passenger side of the radiator? I don't see a way to swing the carrier with that hose connected.
    Also, the coolant pipe/hose going across the front of my timing belt cover (into the turbo) is mostly metal, and has very little play to work around. The ones I see on here are completely rubber. Hoping I don't have to remove that as well. Anyone else hit this snag?
    Cheers!
    2005.5 A4 Avant 2.0; Stock
  38. #198
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Supersquid View Post
    I wish I had a picture to show how I do it. I used to do it the same way with my B5. I don't evacuate the R134, I just sort of take the condenser (you have to unplug that sensor by the passenger side headlight first) and turn it 180 degrees to the left so it's upside down facing the car, then I can bend it back along side the passenger corner of the front bumper. The rubber hoses flex quite a bit when you do it, but I did that same thing about 6 times on my B5 and never lost any refrigerant.
  39. #199
    May 23 2014
    Olympia, WA
    Thanks! I ended up slipping the carrier down and just working from that position - plenty of access. Also, pulled the turbo coolant hose/pipe a couple inches by removing the bracket - just enough to slip the TB cover off. Voila!
    Hit the six pulley bolts w/ some lube, held the crank w/ one socket and the others w/ another socket. They broke free relatively easy.
    Resumed work (after work) this evening and got to installing the water pump and realized I don't have a seal . I'm reluctant to reuse the old one (although it looks okay). Off to Audi tomorrow morning.
  40. #200
    Jul 31 2011
    Good call on not reusing the water pump seal, though I would have expected a new one to come with the kit. Was it not included or did you misplace it?
