Results 1 to 21 of 21
Threaded View
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    PLEASE HELP: Fueling or Ignition (or neither...)?>>>UPDATED
    So my search for a solution to this problem still continues, but instead of boring people with all the back & forth of the original thread, I figured I just start a new one in hopes of getting some fresh ideas. Here is a link to the original thread if anyone wants some background info:
    http://www.audizine.com/forum/showthread.php?t=139876
    And here are a few video clips I took with my digital camera so you can see what is happening:
    http://www.youtube.com/watch?v=5DG8827TB8o
    http://www.youtube.com/watch?v=eT5cx...eature=related
    So essentially I have been experiencing this slight surging/chugging sensation for a while now (~2yrs), which seems to directly correspond to fluctuations in my VAC (as seen in the videos above). It seems to happen intermittently and doesn't matter if the car is hot or cold; full of gas or not; etc., etc. It does, however, seem to get much, much better (if not completely disappear) when ambient air temp is below 60 deg. (F). For instance, it was 55 deg. (F) this morning and the car didn’t act up once even though it has been driving like shit all summer.
    In an attempt to find the problem I've replaced/tested/tried all of the following, with little or no change in overall behavior:
    * Multiple pressure tests at a local shop AND on my own (w/ soapy water); One (1) minor leak found at the bottom of the Y-pipe (fixed), but no change noticed
    * Replaced the TBB w/ a SAMCO
    * Replaced the DV's and rebuilt several times (cleaned, greased, swapped springs, etc.)
    * Realigned the Throttle Actuator Valve (several times)
    * Replaced both the fuel & air filters
    * Swapped out the MAF, ICM's, and N75 w/ new ones
    * Cleaned MAF w/ entire bottle of MAF-cleaner
    * Replaced all the plugs twice (Iridiums, then Side-Fires) and coil packs w/ new Meyles
    * Resistance-tested all O2 sensors and all of them around 10.4 Ohms (<than 20 is still good)
    * SeaFoam treatment to intake & fuel tank
    * Bypassed the N249 valve and replaced the 5-Way Check Valve that connects it it
    * Replaced all the turbo inlet & outlet hoses w/ the Zena Racing kit and new clamps (except the first two turbo outlet hoses)
    * Obviously logged the car at nauseum, sometimes finding misfires, other times nothing.
    Despite the rough idle and slight chugging in VAC (cruising speeds), the car still pulls pretty hard at WOT (although a recent dyno session had my A/F around 13 : http://www.audizine.com/forum/showth...nce+dyno+Stage)
    Unfortunately my current diagnostic methodology of replacing parts via "trial & error" has become exhausting and expensive... I have been seriously considering a different tune, but the problem seems to exist whether I'm in chipped mode or stock mode; leading me to believe its not necessarily tune related. I also don't think its mechanical (e.g. bent valve, low compression, bad wastegate, etc.) as the problem comes & goes as it pleases. Therefore I think it may be either electronic/sensor related, but IDK for sure.
    Any thoughts/help/guidance is appreciated...
    TIA!
    UPDATE: Through some logging sessions I found that my Pass-side O2 was on the way out, and just threw a CEL the other day. I have a new BOSCH ready to install and will advise if this helps any... *fingers crossed*
    UPDATE2: Replaced the pass-side O2, and the problem still exists Recent logging session shows the pass-side O2 still reading a little lean (slightly leaner than the d-side O2), but still within normal I guess (~0.82-0.84V @ WOT)
    UPDATE3: FIXED!!!! If you have this problem, replace your throttle body to save time and money!!!
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
