Page 2 of 2 FirstFirst 12
Results 41 to 51 of 51
  1. #41
    Veteran Member Three Rings discontained's Avatar
    Jul 09 2007
    '01 A4 1.8t
    GA
    Re: I want it LOUDER!!!!!
    Here you go soundspeedstyle.. K&N Cone filter, 15lbs of boost, almost stock everything else.. damn that was along time ago, anywho. this is what mine sounded like on the stock DV
    http://www.youtube.com/watch?v=3io-IwIDpfQ
    For Sale $3,500 -'99 Audi A4 1.8T Quattro 5sp
    -2001.5 Audi A4 1.8T Quattromatic - BT .50 trizzle -RIP
  2. #42
    Veteran Member Four Rings ThatA4T's Avatar
    Jun 10 2009
    98 A4 1.8T Quattro, 66 vw bug Rat Rod
    Denver CO
    ^^^ thats what mine sounds like
    If I hit the switch, I can make that ass drop.
  3. #43
    Veteran Member Three Rings soundspeedstyle's Avatar
    Oct 01 2009
    Silver 2000 Audi S4 Vast stage 3
    Centralia, Washington
    i cant check it out rite now i am at work but i will in 20 mins when im off :>
    2001 A4 1.8t Quattro stage 2 - sold
    2000 s4 stage 3 - sold
  4. #44
    Registered Member Two Rings B5turbo's Avatar
    May 05 2009
    b5 1.8t
    freeport, ny
    Quote Originally Posted by andyrew View Post
    Dont like it? Duct tape the holes.
    fail in the making dont do it
    B5 A4 1.8 T
    located in Freeport, NY
  5. #45
    Jun 10 2009
    Denver CO
    Quote Originally Posted by B5turbo View Post
    whats wrong with that? dont we all use duct tape to fix our audis? haha thats the worst idea ive ever heard
  6. #46
    Jul 14 2009
    phoenix md
    make sure you order the breather tube and not just the cone filter
    and that's what mine sounds like too in the vid.. surprised the camera picked that up!
  7. #47
    Veteran Member Three Rings b5andm3's Avatar
    Aug 22 2008
    Central Maryland
    http://www.youtube.com/watch?v=t_8tEmjqaO0
    That is before my BT upgrade.
    2000.5 A4Q - 2871r / 1.9L Stroked / IE Rods / JE Pistons / 3.5" TBE Exhaust / Forge MBC / 630cc Injectors / Walbro 255lph Fuel Pump / VR6 MAF / Unitronic Tune / CM FX600 / ECS N75 Race Valve / ECS 9lb Alum Flywheel / Forge TIP / Forge DV / ARP Head Studs / BBS LMs / RS4 Front Bumper / Hagus Mirrors / Brembo BBK / RS4 Shift Knob / JL Audio Speakers, Subwoofer & Amplifier / Clarion NX409 / HR Race Springs / Evolution Racewerks FMIC
  8. #48
    Veteran Member Three Rings SpeedWorksAuto's Avatar
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    I have never seen a heatshield like that w/intake on BT. GL with that. Lucky just to fit the intake in there.
    2001 A4 1.8T - 2.7TT Swap w/ custom Single Turbo setup
    http://www.audizine.com/forum/showth...-build)/page16
  9. #49
    Dec 05 2007
    Quote Originally Posted by soundspeedstyle View Post
    I thought when you go bat the only tune that is any good is a mafless tune.
    No. There are MAF tunes and MAFless tunes for the wideband (AWM+). The MAFless tunes are just simple as it cancels out the most difficult thing it comes to when trying to make a nice idle, cause no misfires, etc. People would say that MAF tunes are better (for precise load calculations), but MAFless tunes are just waayy much easier. If you look at the build threads of individuals, the most annoying part is making a custom intake setup. Making proper bends that fit, having proper flow, and proper location of the MAF can be a task when there is little to no room to work with.
    I was the one that mentioned that you would need to do a whole other intake setup when you go BT. Which is true, because you would more than likely have a 3" or 4" compressor inlet. I made that comment before I realised you would be going MAFless. But since you are going MAFless on a BT tune later, and want your current dv to be more audibile, then do a custom setup now with a heat sheild. Then when you get your MAFless tune, just sell your custom intake setup, slap on a new different sized filter matching the compressor inlet of the turbo charger, and call it a day. As I stated, you ideally want everything to be the same size when it comes to an intake.
  10. #50
    Apr 22 2007
    Riverbank, Ca
    You dont trust the allmightly power of duck tape?
    Actually i've done it before, and as long as you cover as much as you can (like the whole box) and overlap its pretty much good.
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
  11. #51
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    I am using the same filter with my GT3071r that I did when I was k03s. You dont have to buy-sell-buy, unless you get a compressor housing that has a really big intake.
