    Senior Member Three Rings georgio3gr's Avatar
    Jul 14 2009
    Greece
    automatic gearbox problem...
    A friend of mine just bought an A8 1998' model 4.2 V8... The car was owned by a grandpa and had not been moved for almost 5 years. He changed gearbox oil but it has a problem with it... He selects "D", he starts the car and after a while, as the car moves, the gearbox selects by its own the "N" mode (the gear stick is stable at the "D" selection) and the car is reving without moving... The engineer said that he probably has to change all the gearbox... He found a used gearbox from an audi S8 1999" model but the engineer is only sure that it fits his engine, not sure if it has different gearbox ecu and can or cannot cooperate with his A8 engines' ecu... What do you think?
    1) Is the problem he has, a problem with his gearbox or with the gearbox ecu? 2)Does he have to change his gearbox with S8 gearbox and S8 ecu and can it cooperate with A8 engine ecu? If yes does he have to reflash gearbox ecu?
    3)What are the differences between A8 and S8 automatic gearboxes?
    p.s.: I would appreciate your help... Any exlpanation you want about all above i said, please ask me because i'm not so good with my english. I would also like to add that he connected the car with audi computer but it does not find any problem...
    Active Member Two Rings S4 FoSho's Avatar
    Sep 05 2009
    07 S4 MT6, 08 Toyota Tundra DC
    G-OCean, NY
    Re: automatic gearbox problem...
    Unfortunately I cannot help you with your problem. I did, however, want to let you know that your English is quite good for a non-native speaker. In fact, your grammar is better than some people who actually are native English speakers.
    2007 //S4 MT6 Dolphin Grey Metallic
    [H&R Coilovers][Hartmann HRS4-242 19x8][35% F&R Tint, 20% Rear Window][Carbonio CAI][Slightly VAG'd][RS4 Pedal Set][3M Clear Bra]
    Jul 14 2009
    Greece
    Quote Originally Posted by S4 FoSho View Post
    Τhanks a lot... You see it's been a lot of years since i stopped the english lessons so i do my best...
    p.s. Your car is very beautiful... I have a dolphin grey non-Sline B7 and i love this colour...
    May 16 2008
    South Texas
    Sorry the S8 gearbox won't work, you will need to find a gearbox with the same code as yours.
    Jul 14 2009
    Greece
    Quote Originally Posted by Scotty@Advanced View Post
    Thank you very much for the answer...
