Results 1 to 40 of 42
    Senior Member Two Rings BIG EYE's Avatar
    Sep 22 2005
    A4 USP 3.0Q/A3 SLine
    San Diego
    Anyone running a 18x8.5 with a 35 offset on the front of a B6 A4?
    Courious about how much it will poke (or not).
    If you have a picture to show, and can comment on any fender modificaitons that where required, that would be great.
    TIA
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: Anyone running a 18x8.5 with a 35 offset on the front of a B6 A4?
    Zero poke.
    "Perfect" fit up front if you want to run 235s, but you'll want 10mm spacers in the rear for the sake of looking good.
    -Darrick
    Veteran Member Four Rings unknowna4's Avatar
    Oct 06 2005
    Soccer mom car
    South
    Quote Originally Posted by Capt. Obvious View Post
    Zero poke.
    "Perfect" w/ 235s if you're not stupid low as well.
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    i have 35 offset and i think they are perfect
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Veteran Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    i have 19x8.5 35et
    no poke, looks good besides 4x4 status
    b6 a4-sold
    2013 m3
    Veteran Member Four Rings Rommulus's Avatar
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Here is et38 on an 8.5" wheel.
    Veteran Member Four Rings CleanA4's Avatar
    Jun 23 2009
    B5 s4, 06 gsxr, lawnmower
    Chicago
    its the best fit on the audi a4 and looks great. I have a set with that size
    pics http://www.audizine.com/classifieds/...t=24101&cat=47
    Veteran Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    going 205's next year roughly 8mm front and 15mm rear spacers....b5 content i know but gives you an idea
    Sep 22 2005
    San Diego
    Awesome. thanks for the replies.....
    Do you think a 30 offset on a 18x8.5 will work, or will that 5mm make too much of a difference?
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Quote Originally Posted by BIG EYE View Post
    It will look ah-maz-ing! Depends on your ride height as to whether you'll rub. Are you running 225 or 235 tires?
    Sep 22 2005
    San Diego
    Quote Originally Posted by Rommulus View Post
    I'm not running anythign yet, because i have not purchased the wheels yet. I want to find out if they would fit first.
    I would probably run 225..
    Oct 06 2005
    Soccer mom car
    South
    That should work then.
    Sep 22 2005
    San Diego
    Quote Originally Posted by unknowna4 View Post
    Cool
    now one more question. Using the same size and offset in the rear, any idea what size spacers should be used to match the "poke"
    Oct 06 2005
    Soccer mom car
    South
    How low are you?
    Sep 22 2005
    San Diego
    How low are you?
    This is a pic of a friends car that has a very similar ride height as me. (i dont have any pics of my current ride height) but i am on coilovers so i can adjust.
    Sep 23 2006
    Houston TX
    Is your car in your avatar? You'll almost definitely rub a bit. Seems like if you're really low, ET32 on 8.5 width wheel is about as far as you can go with 235 tires. I've never rubbed once with ET32 on 19x8.5 but I'm about 24 3/4" all around. Not as low as what you just showed.
    Sep 22 2005
    San Diego
    That is my car in my avatar, but i am not that low. That was from the day i installed my coilovers. I cranked them all the way down before putting them in to see how low i could go...
    My daily height is pretty close (maybe a tad lower) than the Dolphin one posted above
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    I wouldn't add more than a 5mm in the rear. Overall et30 all around. Just my personal opinion.
    Sep 22 2005
    San Diego
    Thanks for all the help
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    et30 is fine. i had fat tires 255 and it was good
    Established Member Two Rings grndzro26's Avatar
    Feb 25 2009
    Vallejo, CA
    Quote Originally Posted by BOPOH View Post
    What suspension are you running?
    Sep 23 2006
    Houston TX
    Second picture doesn't look ET30 to me, you're sure those wheels are 8.5? I guess they must be since a 255 tire on a 8" wheel would overlap the lip more, but still, doesn't seem right to me. Maybe its the angle IDK.
    Edit: I saw the same wheels for sale in your sig. Still doesn't look quite right to me, strange.
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Just adjust so you don't rub. Should be damn close to the fender and lookin sick! (18's look small if your lowers are painted tho)
    High speed Ferrari movement...
    Oct 08 2007
    Columbus, OH
    lowered on TEIN coilovers
    Feb 25 2009
    Vallejo, CA
    Do you know what your fender height is set at?
    Oct 08 2007
    Columbus, OH
    Not here to thread jack but for all you unbelievers
    these are OEM RS6 wheels 18x8.5 et30
    im selling them because i got RS4 reps that show off my BBK much better
    Oct 08 2007
    Columbus, OH
    here you go i found it
    RS6 18x8.5 225/40/18
    Sep 23 2006
    Houston TX
    Ah cool, this explains it thanks:
    Dont get fooled, i have -2* front and -3* rear cambers, otherwise it would stick out. Fenders are also rolled, minimal rubbing does exist, BUT not as much as my 245/35/19
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    19x8.5 ET33 is flush to the fender with no rubbing.
    With ET30 you will kiss the fender lip every so often. That is why I shaved 3mm off the hub on the Keskins shown in the pics to make them ET33.
    Veteran Member Four Rings AudiA4Turbo22's Avatar
    Dec 06 2007
    '03 Audi A4 1.8TQ Tip, '14 Mbz E63 S-AMG, '02 GMC Sierra Denali, '75 DJ5 Postal
    I had them on my NS race setup with 245/40 tires and the offset was perfect at 35
    -Kirk
    AZ's First 2.0 Stroker 3076R Powered Tiptronic B6 Built by RavenMS. Powered by PSI Concepts & GIAC
    BetaAlphaTau Member #58
    May 21 2007
    Florida
    Quote Originally Posted by AudiA4Turbo22 View Post
    245!? yikes. i wouldnt be ballsy enough to run that big of a tire on my NS race springs. 235 MAYBE but to me, my 225's are pretty close.
    2018 Navarro Blue Q5
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    i had 18x8.5 et40 with 245-40-18 NT555 and ~1.4* camber front and rear and they rubbed! went down to a 235-40-18 and no more rubbing.
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Veteran Member Four Rings Sablea4's Avatar
    2018 Suburban, Husqvarna riding mower :P
    Charlotte, NC
    my et 30 sit flush in 8.5
    Current: 2017 Audi Q7 Premium Plus. Carrara White with Nougat Brown interior. APR Stage 2, RocEuro intake, BMC filter
    Sold: 2005 Audi A4 Ultrasport Avant red with manual transmission USP CLUB MEMBER #6
    Sold: 2004 VW R32 Deep Blue Pearl
    Sold: 2010 VW CC Shadow Blue Metallic manual transmission
    Sep 22 2005
    San Diego
    Quote Originally Posted by Sablea4 View Post
    What size tires are these?
    Charlotte, NC
    those were 235/40/18 bfg kdw 2's
    I currently run 225-45-18 bfg g-force sports
    didn't rub with either set except with ALOT of weight in the car. Like 500lbs worth of steel plus tool boxes.
    Sep 22 2005
    San Diego
    Nice....any pics from the same angle of the 225/45's?
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    some pretty sick cars in here =)
    had to put some useless info.
    Senior Member Three Rings topcat's Avatar
    Apr 09 2007
    2002 A4 1.8T
    Atlanta
    18 x 8.5 ET30
    235 40 18 Toyo S Drive
    Veteran Member Four Rings EBG 18T's Avatar
    Mar 27 2005
    The Cold North
    edited:
    i am running 245-40-18's on 18x8.5w/ 37 or 38mm offset (VMR) Fits flush and no rub.
    18x9 (RS6 reps) were shaved to 33mm. No rub with the button clip on front wheel wheel removed.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Sep 22 2005
    San Diego
    Quote Originally Posted by EBG 18T View Post
    i am running 245-40-18's on 18x8.5 w/ 33mm offset (was 37mm prior to wheel hub shave). Fits flush and no rub.
    I could be wrong, but i believe if your wheels have a 37 offset and you shave off 5mm, your new offset will be 42, not 33....
